For Sale Trick Flow Track Heat 170, 1.7 RR, Stage 1 Cam, Typhoon Intake, 24lb, FMS VC, Studs - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 30 Old 04-09-2017, 11:17 PM Thread Starter
*SOLD**Trick Flow Track Heat heads upgraded dual springs (good shape, have some dings in 1 combustion chamber, and small erosion between 1 combustion chamber-see pictures)
**SOLD**Trick Flow Hydr. Roller Stage 1 Cam
**SOLD**Trick Flow 1.7 stud roller rockers
**SOLD**BBK 70mm T body w/home made EGR delete
**SOLD**FMS Black Valve Aluminum Ribber with breathers
**SOLD**Professional Products Typhoon EFI 5.0 Intake Upper and Lower (copy of Edelbrock Performer), some home porting
Ford Racing Stainless Shortie Headers for 79-93 Mustang 5.0 $125
**SOLD**Stock TFI Distributor with newer wires, MSD cap
Nearly new Nitrous Express plate for Edelbrock/Typhoon Performer EFI intake with jetting, hardware. $375
5.0 HO Factory Forged Piston Shortblock. I blew a head gasket, block seems fine, turns over well, bores look good, however it does have 1 low compression hole. Newer OEM lifters, Mustang Pan, with balancer, water pump, timing cover, etc $225
**SOLD**ARP SBF Head Studs, good shape, includes all nuts/washers
**SOLD** Low Mileage 24lb Injectors
**SOLD**BBK EFI Regulator
Stock Fuel Rails $20
**SOLD**Stock Mass Air 19lb Mustang
Located in Reno, NV. Happy to provide more pictures/answer any questions. Sold as is. All prices plus shipping and Paypal.
91 LX Hatch... Slow 5.0
1slowhatch is offline
post #2 of 30 Old 04-09-2017, 11:19 PM Thread Starter
More pictures.
post #3 of 30 Old 04-15-2017, 07:14 PM Thread Starter
To the top.
post #4 of 30 Old 04-18-2017, 03:34 PM
Pm'd
87NotchBack5.0 is offline
post #5 of 30 Old 04-18-2017, 05:46 PM
luizGT91's Avatar
Trader Feedback: (28)
heads with rockers and tfs1 shipped to 78520??
thanks
" A lot of people on here take their cars to the track run it the way it is, don't change anything on it and it doesn't run the number they want. So they eiither spray it or build something bigger just to run a number they should on motor in the first place. " GilroyRacing
luizGT91 is offline
post #6 of 30 Old 04-19-2017, 11:42 PM
mustang30212's Avatar
Trader Feedback: (117)
PM sent on valve covers.
mustang30212 is offline
post #7 of 30 Old 04-20-2017, 04:11 PM Thread Starter
All PM's returned.
post #8 of 30 Old 04-20-2017, 04:12 PM Thread Starter
thanks
Sent you a PM.
post #9 of 30 Old 04-25-2017, 08:48 PM Thread Starter
All PM's replied. Lots of interest, but no payment yet! Here are the push rods and head studs.
post #10 of 30 Old 04-26-2017, 02:13 PM Thread Starter
Head studs sold. All PM's replied. As requested, I've attached a picture of the headers.
post #11 of 30 Old 04-26-2017, 08:43 PM Thread Starter
More pictures.
post #12 of 30 Old 04-26-2017, 08:47 PM Thread Starter
More..
post #13 of 30 Old 04-29-2017, 01:34 PM Thread Starter
Bump.
post #14 of 30 Old 05-02-2017, 03:28 PM Thread Starter
PM's replied.
post #15 of 30 Old 05-03-2017, 04:44 PM Thread Starter
All PM's replied.
post #16 of 30 Old 05-03-2017, 06:54 PM
PayPal sent for valve covers. Thanks
FN FAST is offline
post #17 of 30 Old 05-03-2017, 08:07 PM Thread Starter
Valve covers sold!
post #18 of 30 Old 05-05-2017, 02:23 PM Thread Starter
Lots of PM's, but all still available. Bump it up for pay day!
post #19 of 30 Old 05-09-2017, 07:01 PM Thread Starter
To the top.
post #20 of 30 Old 05-13-2017, 03:08 PM Thread Starter
Bump.
post #21 of 30 Old 05-19-2017, 01:54 PM Thread Starter
Also have an MSD coil. Everything still available. Lots of PM's, but no $$ coming through.
post #22 of 30 Old 05-23-2017, 08:40 PM Thread Starter
PM's returned. I've had several ask about the chambers. I believe their part #is 52410010... which should be a 61cc chamber Track Heat.
post #23 of 30 Old 05-25-2017, 11:53 PM Thread Starter
Listed updated. Upper, lower, t body and spacer are sold.
post #24 of 30 Old 05-31-2017, 07:44 PM Thread Starter
PM's replied.
post #25 of 30 Old 06-04-2017, 07:44 PM
Pm sent
skulljab is offline
post #26 of 30 Old 06-10-2017, 06:41 PM Thread Starter
All PM's have been answered. Here are some more pictures and items. I am now parting the short block. Make offer on anything you can use.
post #27 of 30 Old 06-11-2017, 01:14 PM Thread Starter
Cam and lifters sold. All pms replied.
post #28 of 30 Old 06-13-2017, 02:19 PM Thread Starter
Bump. All PM's replied.
post #29 of 30 Old 06-17-2017, 02:33 PM Thread Starter
SOLD:
24lb injectors
BBK adj fuel pressure regulator
Stock 19lb mass air meter
Stock distributor with newer OEM TFI module, wires, MSD cap
MSD Coil
Stock balancer
Stock pullies
Timing Cover w/pointer/hardware
post #30 of 30 Old 06-21-2017, 08:29 PM Thread Starter
**SOLD TFS Heads and Rockers**
