For Sale Aftermarket and Stock Parts - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 03-26-2017, 08:34 AM Thread Starter
Red face Vortech Stuff/Niche Wheels/Exhaust Tips/Stock Parts
Prices include shipping.
Aftermarket parts:
- Vortech 8-rib 3.33" supercharger pulley (brand new) - $100
- Vortech accessory belt (to use for a SN95 Vortech supercharger setup, brand new - for use with all accessories) - $50
- Throwout bearing (brand new - came w/ RAM clutch package) - $45
- 3 inch diameter stainless steel exhaust tips (used) - $50
- "COBRA" license plate frame - $30
Factory parts off a 1994 Cobra (in alphabetical order):
- Accessory belt (for use with all accessories) - $20
- Air intake system with MAF - $100
- Belt tensioner assembly/bracket - $100
- Belt tensioner - $50
- Dash clock (doesn't work, might be a simple electrical problem?) - $30
- Distributor rubber cover - $30
- Distributor cap and rotor - $30
- Fuel pump - $50
- Harmonic balancer - $50
- Motor mounts (2)- $50
- Oil pan protector - $35
- Rack and pinion bushings (4) - $25
- Rear upper control arms w/ hardware - $50
- Rear lower control arms w/ hardware - $50
- Strut dust boots (front - 2) - $25
- Sway bar endlinks (front - 2) - $20
- Throwout bearing - $25
- Transmission mount - $25
- Water pump pulley - $50
94cobraWA is offline
post #2 of 15 Old 03-30-2017, 11:54 PM Thread Starter
post #3 of 15 Old 04-05-2017, 10:06 PM Thread Starter
to the top!
post #4 of 15 Old 04-15-2017, 12:30 PM Thread Starter
post #5 of 15 Old 04-28-2017, 10:17 PM Thread Starter
to the top
post #6 of 15 Old 05-09-2017, 11:52 PM Thread Starter
post #7 of 15 Old 05-17-2017, 03:20 PM Thread Starter
bump
post #8 of 15 Old 05-27-2017, 11:42 PM Thread Starter
to the top!
post #9 of 15 Old 06-01-2017, 10:06 AM
ok i want the crank pulley for sure possibly the trans mount and injectors
is the trans mount the factory one or a aftermarket replacement
what size are the injectors (just verifying 24lbs or larger)
also do you have a injector wiring harness
thanks matt
uplandviper is offline
post #10 of 15 Old 06-01-2017, 11:32 PM
If the Crank pulley is still available i will buy it. It is the stock cobra 5.85Inch pulley right? Thanks JJ
JJhirsch is offline
post #11 of 15 Old 06-02-2017, 10:04 AM Thread Starter
fuel injectors, crank pulley, vortech pulley and belt all sold!
post #12 of 15 Old 06-03-2017, 04:30 PM Thread Starter
Niche wheels sold!
post #13 of 15 Old 06-04-2017, 10:43 PM Thread Starter
oil cooler sold!
post #14 of 15 Old 06-09-2017, 07:43 PM Thread Starter
friday bump
post #15 of 15 Old 06-19-2017, 10:49 AM Thread Starter
bump
