For Sale For Sale: Ford A4 Block and 331 Rotating Assembly - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 24 Old 08-20-2013, 07:48 PM Thread Starter
For Sale:
Ford A4 Block never bored
331 Complete rotating assemble brand new still in the boxes. Here is a list of the parts.
Eagle Crank 430232505400
Mahle 0928880400 (8) MS HVSS SB Ford Invertdome 1165
06457808 (8) Pin .927 x 2.288 x .165 wall, 1189
06441489 (16) Circlip .927 x 1.6mm w/o tang
4035MS-15 (1) 4.030 x .005 1.5, 1.5, 3.0 mm File Fit
CRS5400C30 ESP H-Beam Connecting Rod
Clevite CB-1227P
Clevite MS-590H
Piston Specifications are:
1.165 compression height
4.030 bore
16cc bowl volume
with 58cc heads 9:3.1 compression
with 64cc heads 8:7.1 compression
$3,500 for everything. If you have any questions, call me at 603-231-4528
Thanks,
Charlie
95 Mustang GT Vert
2006 Fun Ford Epping Best of Show
2005 Fun Ford Epping Best of Show
2004 Fun Ford Epping Best 94-04
onebad95 is offline
post #2 of 24 Old 08-20-2013, 07:49 PM Thread Starter
More Pics
95 Mustang GT Vert
onebad95 is offline
post #3 of 24 Old 08-20-2013, 08:36 PM
Chucks, you selling everything? Why don't you just give it to me, I'll give it a good home!
To potential buyers, I've seen this stuff in person, it's legit. GLWS Charlie!
69clark is offline
post #4 of 24 Old 08-20-2013, 08:45 PM
yeahloh95's Avatar
great parts will make someone a nice strong combo , wish i had the cash for it
best ET 11.31@125.53MPH , S-trim making ??? rwhp Afr165s comp cam , holley system max , d&d k-member and control arms, coil over kit, RECARO "SRD"S 13" Brakes on front 12" on rear .Shaved trunk lid .metco lowers and avo coil-overs on back .weight 3300 lbs
yeahloh95 is offline
post #5 of 24 Old 08-20-2013, 10:18 PM
Cantbuyitright's Avatar
Trader Feedback: (51)
Block
Sell the block separate? And if so what's the specs?
Scott
Cantbuyitright is offline
post #6 of 24 Old 08-21-2013, 05:28 AM Thread Starter
I want to sell the whole package. Unless someone asks for the rotating assembly. Then I'll separate.
95 Mustang GT Vert
onebad95 is offline
post #7 of 24 Old 08-21-2013, 07:08 AM
Pm me price of rotating assembly shipped to 19014 pa
bangshift is offline
post #8 of 24 Old 08-21-2013, 08:54 AM Thread Starter
Pm sent
95 Mustang GT Vert
onebad95 is offline
post #9 of 24 Old 08-21-2013, 09:35 AM
I'm jumping in line for the block if you separate.
Nasty$Nate is offline
post #10 of 24 Old 08-21-2013, 09:31 PM Thread Starter
Bump
95 Mustang GT Vert
onebad95 is offline
post #11 of 24 Old 08-22-2013, 08:04 AM
5ltrchevyeatr's Avatar
Trader Feedback: (156)
how much for the rotating assembly?
you wanna play, you "GOTTA" pay
5ltrchevyeatr is offline
post #12 of 24 Old 08-22-2013, 04:47 PM Thread Starter
Block specs
Deck: 8.2" nominal
Bores: unfinished (3.980")
Main bores: finished 2.430"
Lifter bores: finished
Freeze plugs installed
Wet sump provisions
Oil valley smoothed for better oil return
Cylinders are o ringed
95 Mustang GT Vert
onebad95 is offline
post #13 of 24 Old 08-22-2013, 05:02 PM
Block
Originally Posted by onebad95 View Post
Block specs
Deck: 8.2" nominal
Wet sump provisions
Will you pm me a price for the block Sir,
Scott
post #14 of 24 Old 08-23-2013, 09:46 PM Thread Starter
Bump for the weekend
95 Mustang GT Vert
onebad95 is offline
post #15 of 24 Old 08-25-2013, 11:55 AM Thread Starter
Ttt
95 Mustang GT Vert
onebad95 is offline
post #16 of 24 Old 08-28-2013, 07:44 PM Thread Starter
Ttt
95 Mustang GT Vert
onebad95 is offline
post #17 of 24 Old 09-01-2013, 06:44 PM Thread Starter
Ttt. This set up needs a home.
95 Mustang GT Vert
onebad95 is offline
post #18 of 24 Old 09-05-2013, 06:45 PM Thread Starter
Ttt
95 Mustang GT Vert
onebad95 is offline
post #19 of 24 Old 09-08-2013, 06:29 PM Thread Starter
Ttt
95 Mustang GT Vert
onebad95 is offline
post #20 of 24 Old 09-13-2013, 09:11 PM Thread Starter
Ttt
95 Mustang GT Vert
onebad95 is offline
post #21 of 24 Old 09-13-2013, 09:56 PM
In on the block if you'll separate.
The Professor is offline
post #22 of 24 Old 09-20-2013, 09:17 PM Thread Starter
Ttt
95 Mustang GT Vert
onebad95 is offline
post #23 of 24 Old 09-21-2013, 09:05 AM
89BlackGtVert's Avatar
Let me know if you change mind on block!
Sent from AutoGuide.com App
1989 GT Vert.. Major Changes for 2013 Wish me luck
Old setup from 2012 On3 Turbo, Trick Flow 170 Heads, Edelbrock RPM upper & Lower, Trick Flow Stg 2 cam, UPR K-member and control arms and Strang front and rear coil over, and UPR upper and lower rear control arms, MM frame connectors Fully Built AOD, 512whp
89BlackGtVert is offline
post #24 of 24 Old 11-30-2013, 05:59 AM Thread Starter
Reduced to $3,200 plus shipping.
95 Mustang GT Vert
onebad95 is offline
