For Sale Probe Shaft Mount SBF Rockers with Jesel/arp hardware - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 11-04-2010, 11:20 PM Thread Starter
Blown302stng's Avatar
Trader Feedback: (104)
Had these on my afr 205 heads.. The did very good for me.. I am parting out the motor and no longer need them. They have prob 75 street miles on them and 25 passes.. We upgraded the bolts that hold the base down with Jesel/arp bolts. Also will incuide some shims
Item Code 11312
Vendor Name Probe Industries
Product Type Rocker Arms
Application AFR, Dart, Edelbrock Heads
Engine Displacement (cu.in.) 289/302/351
Engine Family FORD-LINCOLN-MERCURY - Small Block 302 Based V8, Small Block 351 Windsor Based V8
Material 2024-t3511 Extruded Aluminum
Finish Natural
Rocker Arm Mounting Style Shaft
Rocker Arm Ratio 1.6
Bearing Type Torrington - Needle Bearings (Caged)
Bearing Load Capacity (ft-lb) 2200
Notes Will Not work with Brodix Track 1 Cylinder Heads
400 shipped
Blown302stng is offline
post #2 of 7 Old 11-04-2010, 11:29 PM
MdntRanger50's Avatar
Trader Feedback: (50)
PM sent
'91 Ranger, 306, 270HR14, Tri-y, RamAir, T5, 3.73, Aeromotive Sys, QH, LM2, Tunerview II, A9L, BE & EA
'89 Mustang coupe, 5.0, AOD, HO cam, 70mm Turbo, 60lb inj, 340lph, 3.27, QH, LC-1, A9P, Tunerview II
'98 Ranger 2WD 5.0, GT40, HO cam, 4R70W, 3.73, QH, SLL4
MdntRanger50 is offline
post #3 of 7 Old 11-05-2010, 01:29 AM
How's it going. Do you still have the rockers for sale and were you pleased by the quality.Looking into buying some probes.
TWINTURBOCOUPE is offline
post #4 of 7 Old 11-05-2010, 11:48 AM Thread Starter
Yes the rockers are still for sale.. the quality looks good to me.. I never had any issue out of them.. I am running a solid roller turbo cam with a good little bit of lift and 8k rpms where easy to turn with this setup
post #5 of 7 Old 11-05-2010, 02:45 PM Thread Starter
These are pending sale.. a guy called me last night 10 min after i listed them
post #6 of 7 Old 11-06-2010, 03:46 PM
PM Sent
post #7 of 7 Old 11-09-2010, 02:26 PM Thread Starter
sold
