For Sale Dart Block 363 SBF, ALL FORGED, AFR205s - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 70 Old 09-08-2010, 11:06 PM Thread Starter
streetwarrior's Avatar
I ended up selling my Mustang before putting this in the car. Everything except the Moroso electric water pump is brand new. Everything is listed below, can be assembled if wanted. Local pickup/will deliver max distance 100 miles from 46368 (NW Indiana). Email cgs607 at gmail dot com for correspondence. Thanks NMRA!
Dart SHP 4.125" 8.2" deck block
AFR 205s, 58cc chambers, upgraded 8002 springs, Titanium retainers
Erson Cams custom hydraulic roller, 8660 steel core (CMC)
Rollmaster Billet CS3040 timing set
Jesel Sportsman SS Series 1.7 shaft rockers
Moroso electric water pump (lightly used)
Melling Select M1068 oil pump
Cometic 4.155" bore, .036" compressed thickness MLS gasket
King HP series rod and main bearings
Mahle PowerPak 4.125"x1.165" kit (SBF165125F06)
Eagle 4340 3.400" stroke crank
Eagle 4340 5.315" rods
New aluminum timing cover- SOLD!
Parker Funnel Web intake, drilled, tapped, and welded with fuel rails for EFI or carb- SOLD!
Machining and mockup, zero balance rotating assembly to better than 0.13 oz-in on CWT Multi-Bal, deck and square block to 8.180" deck height (zero deck), measure all tolerances and install freeze plugs
Custom crankshaft grinding on lathe to machine counterweights to clear rod/piston combo (reduced weight)
ARP 12-point head studs
ARP stainless header bolts
Aeromotive A1000 fuel pump
Aeromotive A1000 carbureted regulator
Romac 0240/SA neutral balancer
sheetmetal valve covers and original Ford steel core valve cover gaskets
Morel Race Series hydraulic roller lifters, #RS962
Proform Fox-body pan and pickup
You can see from the parts list there is well over $9k invested. The cam was custom spec'd from Steve Tanzi at Erson, specs: 232/240@.050", .618"/.617", 290/298 advertised. Cam was put on Cam Doctor so these are actual specs not just what the cam should look like. With an 820cfm Pro Systems E85 carburetor, Erson conservatively expected 575+HP at the crank with this setup. Help me get this thing moved. PM for latest price since some parts are sold, need this gone but won't give it away.
streetwarrior is offline
post #2 of 70 Old 09-12-2010, 02:14 AM Thread Starter
Will separate, $4500 for shortblock with oil pump, pan, balancer, flexplate, and head studs, $3k for AFRs, Jesel SS rockers, custom cam, timing chain, Morel lifters, intake, fuel pump, regulator, etc. PM if interested. Thanks!
post #3 of 70 Old 10-08-2010, 07:29 PM Thread Starter
Buyer fell through. First $7000 takes it and I will deliver up to 200 miles from 46368 for free.
post #4 of 70 Old 10-10-2010, 12:11 PM Thread Starter
Sunday bump before kickoff...
post #5 of 70 Old 10-10-2010, 05:20 PM
jb9150's Avatar
Would you sell the water pump seperate?
91 Hatch loaded full weight power everything, 408W, afr 205's, custom grind comp, Pro Systems 950HP, Lentech strip terminator, Ultimate Converter Concepts 5000 stall full manual with brake. 11.12@125 so far.
jb9150 is offline
post #6 of 70 Old 10-12-2010, 08:19 PM Thread Starter
Sure. Give me $150 through Paypal, and it will go out tomorrow. Seems most guys interested in the motor don't want an electric pump anyways... Paypal cgs607 at gmail dot com, I will reply in email and get it out same day! Thanks!
Chris
post #7 of 70 Old 10-12-2010, 09:22 PM
jb9150's Avatar
pm sent
jb9150 is offline
post #8 of 70 Old 10-12-2010, 09:26 PM
jb9150's Avatar
got any pics of the valve covers? jeblair3@hotmail.com or 7164107499
jb9150 is offline
post #9 of 70 Old 10-13-2010, 07:40 AM
pm sent
SteveVA is offline
post #10 of 70 Old 10-13-2010, 11:47 AM
SSPSTANGBANGER's Avatar
Trader Feedback: (25)
Wanna sell just heads without rockers? If so pm me a price please shipped to 77363.
thanks
[SIGPIC][/SIGPIC]
2014 Premium GT A6 -Cobra Jet N/A-121mph 1/4 - going turbo 2014 FRPP Coyote R-block Bullseye S380R bat-mo-wheel
2011 GT/CS RIP
2011 GT Premium Silver/Blk M6 bolt-ons(wife's)
SSPSTANGBANGER is offline
post #11 of 70 Old 10-13-2010, 04:17 PM Thread Starter
Can't sell just the heads, I have a pending offer for the longblock. All items except Moroso pump are ABSOLUTELY BRAND NEW NEVER USED. It looks though that the following will be for sale as well with pics following:
Erson custom hydraulic roller cam 8660 steel CMC core, 290/298 advertised, .365" lobes, 232/240@.050" 108LSA .621" lift w/ 1.7 rockers cost $290 sell $225 shipped
brand new EFI aluminum timing cover SOLD!
Parker FunnelWeb intake carbed or EFI w/ fuel rails (will not separate) cost over $300 SOLD!
Aeromotive 11101 fuel pump and Aeromotive 13204 fuel regulator (will not separate) over $450 invested $370 shipped
Moroso water pump (lightly used but works great) SOLD!
Sheetmetal valve covers w/ OEM Ford steel/rubber gaskets (best around!) over $175 invested SOLD!
post #12 of 70 Old 10-13-2010, 04:29 PM Thread Starter
Almost forgot... have a polished aluminum alternator bracket as well. Never used, SOLD!
post #13 of 70 Old 10-13-2010, 06:12 PM Thread Starter
Alternator bracket sold to jb9150. Thanks!
post #14 of 70 Old 10-13-2010, 07:47 PM
TooFast98Cobra's Avatar
Trader Feedback: (54)
are those procomp valve covers? If you have the valve cover studs also maybe we can work something out....
TooFast98Cobra is offline
post #15 of 70 Old 10-13-2010, 10:06 PM Thread Starter
I do have valvecover stud kit as well, stainless studs and stainless nuts. I don't know what brand they are, bought them locally. Stud kit goes with, very nice, has allen head opening in top of stud. Also has OEM Ford 5.0 v/c gasket, best you can buy. LMK, Paypal is cgs607 at gmail dot com, payments received before 5PM will ship same day, just like JB9150s did.
Sale pending on water pump, will follow list of request if sale doesn't happen. Will take offers on cam, but be reasonable. This isn't some cheap Comp Cams induction hardened core, this is steel core flame hardened. Make a great addition to any serious street car, lift with 1.6 rockers is .584" both sides.
post #16 of 70 Old 10-14-2010, 11:34 AM
COP_STANG's Avatar
Trader Feedback: (26)
payment sent for water pump!
410W / C4 / 275's /100 shot on pump gas 93
9.95@133.97 1.37 60' 6.31 1/8 mile (10.4 on motor)
COP_STANG is offline
post #17 of 70 Old 10-14-2010, 01:21 PM Thread Starter
Water pump sold, valvecovers, gaskets, and stud kit SOLD! to TooFast98Cobra!. Thanks Bill!
post #18 of 70 Old 10-14-2010, 02:06 PM
Great guy to deal with here, thanks again man, some one buy this jem of a motor
post #19 of 70 Old 10-14-2010, 05:53 PM Thread Starter
Water pump shipped to cop_stang; valve covers, v/c gaskets, studs shipped to TooFast! keep em comin, more stuff to sell! Thanks guys for buyin, enjoy!
TooFast thanks for the kind words... all your ARP stuff is on the way! LMK if I can help...
Yeah, and somebody buy this motor, easy mid-hi 10s setup here that can drive every day and get deep into the 9s- it's ready for a 250 shot of juice!
post #20 of 70 Old 10-15-2010, 06:12 PM Thread Starter
FunnelWeb sold to SteveVA.. you guys will be seeing his taillights now! LOL
post #21 of 70 Old 10-16-2010, 10:00 AM Thread Starter
Timing cover sold to spyderman... enjoy!
post #22 of 70 Old 10-19-2010, 11:11 AM
ALSO IF YOU WANNA SELL THOS JESSEL ROCKERS AS WELL ILL TAKE EM
STILL HAVE THESE
90titaniumstang is offline
post #23 of 70 Old 10-22-2010, 08:22 AM Thread Starter
ttt.... Surely somebody wants to go easy streetable 10s next spring?
09 G8 GT
post #24 of 70 Old 10-24-2010, 01:24 PM
Nice motor
Hey I know that you said that you were wanting to keep the fuel pump and reg together, however I am building a fuel injected motor and I can't use the reg.. Will you sell the fuel pump by itself.. If so how much?
Drake05 is offline
post #25 of 70 Old 10-26-2010, 10:22 PM Thread Starter
A1000 pump has been sold to TooFast98Cobra, A1000 regulator still for sale. $100 shipped, 100% brand new! Retails for $155+. Paypal cgs607 at gmail dot com and will go out same day before 5PM.
09 G8 GT
post #26 of 70 Old 10-26-2010, 10:44 PM Thread Starter
Just for $heits and giggles, I priced everything out through Summit today. Came up with $8,872 (everything not sold in thread is included) substituting a Comp timing chain and ATI balancer for the Romac/Rollmaster stuff, and Comp hyd roller lifters for the Morels (obviously a match in price only to the Morels). This is without the $1,231 spent at the machine shop to make sure it's top notch. So, instead of $10,000+ out of your pocket, $7000 will make this yours!! Give yourself a great Christmas present and a guaranteed ticket to the mid 10s next spring! PM me if you need a whole list of everything included in this. Will meet halfway up to 250 miles from 46368 to get this done.
09 G8 GT
post #27 of 70 Old 11-04-2010, 01:10 PM Thread Starter
to.... the.... muffin.... top!
09 G8 GT
post #28 of 70 Old 11-04-2010, 08:31 PM
94cobra2615's Avatar
What is the compression?
94cobra2615 is offline
post #29 of 70 Old 11-04-2010, 08:46 PM Thread Starter
11.26:1, flat tops with 6.6cc valve reliefs, 58cc chambers and .036" head gaskets.
09 G8 GT
post #30 of 70 Old 11-04-2010, 11:28 PM
blazer1970's Avatar
Trader Feedback: (50)
Still have the regulator? If so I will take it, what is your paypal?
Jeff
1985 GT
408W XSR ported heads & Vic jr intake, 950 prosystems carb, 1 3/4" supercomps,
Comp cam custom hyd roller, Astro A-5, 4.10
blazer1970 is offline
post #31 of 70 Old 11-05-2010, 01:13 PM
Wanna sell the heads now?
[SIGPIC][/SIGPIC]
2011 GT/CS RIP
post #32 of 70 Old 11-05-2010, 02:19 PM Thread Starter
Sure, I'll sell the heads and rockers if one of your friends wants the shortblock. Fair enough?
09 G8 GT
post #33 of 70 Old 11-05-2010, 07:23 PM
Well darn. Compression is too high for me. Thanks
post #34 of 70 Old 11-07-2010, 11:09 PM Thread Starter
You could always either get another piston with some dish to it, or stick a .100" gasket in there. Probe makes a piston for this with a 20cc dish, which would drop compression to 9.66:1, and I've had other people inquire about the pistons, so I can keep those if you want. I've still got the balance sheet, so all the shop would need are the pistons to weigh them, and the crank to rebalance. Probably less than $200 since the rods are already weighed and the crank balance is documented. The machine was a CWT Multi-Bal, which is top of the line equipment.
09 G8 GT
post #35 of 70 Old 11-19-2010, 01:22 PM
bump for a great seller!!!
