Fox Mustang Wheel Offset and BS Question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-19-2017, 11:25 AM Thread Starter
otherjohnson's Avatar
I'm planning to add 03 terminator A-Arms to the front of 91 LX. I know that I need a lot of BS and Offset to clear 13" brakes and these front control arms. Would 17x8s with the following specs still fit under the fenders:
5.7" BS; and
32mm of Offset.
If not, how much more BS and offset will I need?
(I should also mention that I have a SN95 rearend out back).
Thanks in advance!
Red 91' LX Vert, AOD, 306 with GT40P Heads and Explorer Intake, Isky Cam, Mid-Length headers, and Magnaflow exhaust. Full suspension in the works.
otherjohnson is offline
post #2 of 5 Old 05-19-2017, 12:42 PM
Sounds like you are looking to put OEM SN95 17x8 wheels on the '03 arms on a OEM Fox K-member. From what I remember the SN-95 control arms are about 3/4" longer than the Fox arms the SN95 spindles will add a little track width too. I think you would be ok. Not 100% though. I may be a little tight.
tjm73 is offline
post #3 of 5 Old 05-19-2017, 04:25 PM Thread Starter
Excellent. I was going to roll the fenders. The terminator arms should improve my turning radius. Does anyone know if I will need to modify the fenders to take advantage of the new arms?
I don't want to have to use steering rack limiters. Thanks!
post #4 of 5 Old 05-19-2017, 04:33 PM
I just drew some known dimensions in Autocad and I don't think it will work.
tjm73 is offline
post #5 of 5 Old 05-19-2017, 06:25 PM Thread Starter
The wheels won't fit with the A-Arms or I will have to use steering rack limiters?
Thanks!
