I swapped the brakes on my 90 gt to a setup off a 94 v6 car. I'm having to run 1/2" spacer to clear the calipers with 15x3.5" street lites. Is that normal.
And yes, most likely. I also have Billet Specialties. Street Lites. They have minimal caliper clearance. I have the numbers wrote down someplace on them actually.
Not an apples to apples comparison, but I had to run a hub-centirc 5mm spacer with mine, to clear my Cobra brakes. Still super close, too. But it works.
At the end of the day, it's just math. B.S. with give you the caliper clearance of whatever wheel you have. You can look up caliper depth of your brakes, and figure out what you need to do. That's all I did.
Here's my 15x3.5 1.75bs on my '04 Mach 1 with a GT brake conversion. I cut the caliper bracket support of and run a 5/16 billet spacer. Zero issues, tons of street miles.
Just run the spacer, that's what everyone has to do. The wheel doesn't have enough caliper clearance cut into it to clear the brakes unless you want to buy the $600 each 17x4.5" wheels with the 2" caliper clearance.
Related Threads
Ford Mustang Forums
9.8M posts
200.7K members
Since 2001
