#141 |
__________________
96 Cobra Vert NEW SETUP: 60'-1.830, 11.7 @ 121.73. Hellion Single Turbo @ 10psi. UD pullies, timing adjuster, Meziere WP, Bassani Quiet Thunder w/cats, 4.10's, AL driveshaft, 315/35/17 BFG DR's. New Driver-97 Pacific Green Cobra. Forged, 2.1 Kenne Bell, T-56, 3.73. 12.6 @ 112mph |
| Sponsored Links | |
Advertisement |
#144 |
I need to get some decent pics of mine. But you get the idea.
__________________
Mike 1986 Capri street car w/ a/c, p/s & p/w Custom built T6 80mm s400sx based kit Shaunthony's built (Twin Trouble and Anthony Fury) 9.31 @ 146 1.39 60' on drag radials @ 3735# Kurgan tuned AEM EMS 80mm 718rwhp new 88mm 921rwhp No new track times yet |
#147 |
BUMPPPPPP!! haha
Not a complete engine, sorry. Just figured I'd bump this thread up. Almost done with my turbo setup, redone the piping for a third time. lol I'll I got left to do is weld up the downpipe, cut hole in the fender for the exhaust to exit, and wrap the hot side with header wrap.
#149 |
I haven't updated this thread. I went from this in the Cobra vert. To this in the Hardtop.
__________________
Fastest Ethanol Powered Street Car in the World SN-95 7.64 @ 187 315 Radials E-98 TT 427 TH-400 3400 lbs. Baseline Supsension, Ed Curtis |
#153 | |
__________________
Built by Lujan Motorsports Boss 306, S400sx3 80mm, Glide, AEM. ???@27lbs..... |
#154 |
Here's my beater.
![]() 11:1 compression, 347, TFS 170 heads, TFS 1 cam, Cobra upper and lower, PTK Turbo Kit @ ~ 8 psi. Dyno'd 450 rwhp @ 6 psi with P1SC. No numbers yet on turbo.
__________________
White 95 GT - 347 - PT76 PTK @ 7.8 psi - T3550 - TwEECer - Zeitronix WB - Greddy Profec B Spec II - AIS Meth Kit Black 04 RX8 Last edited by strokercharged95GT; 12-21-2009 at 04:41 PM. |
#157 |
Trader Feedback: (15)
Not if you have enough octane. Hell you could run 13.0, 24* timing and 20lbs IF you have octane and cooling.
You see the nozzle on the intake and the boost juice in the jug? Meth injection is cool, but running e85 is direct port alcohol injection.
__________________
94 Mustang GT MS1 and a Turbo Keep motors alive, drive on E85. |
#160 | |
__________________
'93 taurus SHO '99 SVT Lightning i'm zach
#164 |
Here is my Ponydown 351W kit with a T70. Still working on cleaning up the wiring, vacuum lines and spark plug wires.
__________________
89 LX 359W Turbo Last edited by Jim5pt0; 01-03-2010 at 08:50 PM. |
#165 |
Trader Feedback: (43)
[IMG]
[/IMG]
__________________
R302-All forged 331 stroker Afr 205`s 9.2-1 comp Cartech Twinturbo dominator kit 66mm`s 903rwhp @ 24lbs ran out of injector so stay tuned for higher numbers!!!!!!!!!!!!!!!! |
#167 |
i`ll get a picture of it tomorrow, but i made a bracket that mounts to the front cover
using the two bolts that hold the stock timing pointer, and it`s solid motor mounts on the car so i made a tab welded it to the bottom of the frame rail and got an adjuster rod.
__________________
#168 |
5.4L 2v, Almost the entire car is is DIY. No kits.
__________________
2002 Modular Shootout, 2v Power Adder Champion 1999 GT Perf Red 35th 5.4L 2V DIY Turbo 2002 Ford Mustang GT Vortech V3 Stock 3.6 Pulley CXRacing Intercooler Last edited by Edward Clark; 01-04-2010 at 11:30 PM. |
#169 | |
great job on that build, the turbo setup looks sweet. You may have a pm about this later
__________________
01 GT MMR950 soon to be on the road again...
#175 |
I feel like I should change my intake.. LOL
Custom-built, 70mm MP turbo, GT-40 heads, Explorer intake, E-cam. Made 488whp/502wtq on 13psi. ![]() ![]() ![]() ![]() Whhhhat? It's stock.
__________________
'88 LX -New mill coming soon. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Tags |
| turbo |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
[/IMG]
Linear Mode
