#1 |
On 3 turbo dyno vid
Here is a quick vid on the dyno. Car is bone stock 5.0 with 140k on the motor. Made 433rwhp and 556rwtq. Pretty happy.
__________________
88' 5.0LX, Bone stock motor, C4, on3 turbo. |
| Sponsored Links | |
Advertisement |
#3 |
Yep, total budget build. I only have $4k in the car total. The only mod to the motor is the intake. Bone stock! I just need to get a paint job now.
__________________
#4 |
WELL MY DYNO NUMBERS MUST BE WAY OFF THEN...LOL..How much boost you making?...What dyno is it? I have way more motor work then...Maybe mine is off....lol
__________________
Turbo installed!!!! 87 GT Vert.On3 turbo making 14 psi,Trickflow TW 170cc heads,TF street heat intake,70mm TB,stock cam,1.6 roller rockers,Snow performance stage 2 meth kit,42# injectors,340 lph fuel pump,tunning with Moates QH,Art Car c4 3000 stall.3.55's |
#6 |
I want mine re-dynoed..LOL...Now i have to find another dyno shop to throw it on and see what they get...
__________________
#8 |
and through an AOD?... wow
__________________
95 Cobra - Comp Billet HP7679 DIY Turbo and 331CI A4 Car Kurgan tuned - juuuuuuuust a little over 385RWHP.... RIP - Jerry"BabyLove" Glover ....1952 to 2012... KMS West O.G. --- Sacramento |
#9 |
I have had it on 2 different dyno's both within 5hp and 10tq of each other. They are both dynojets. I have the 13psi spring in the tial gate but I only see about 10 cause im at high elevation. We lose boost cause of that. And I want to thank Chris at Power Adder Solutions for all the help with tuning. What a great guy!
__________________
#12 | |
I'd check your dyno charts too, as I'd bet they applied SAE correction to them. If you are at a higher elevation, full SAE should NOT be applied to turbo applications as it will artificially inflate the HP and TQ numbers. Remember, the turbo is in essence creating its own atmosphere...so you can't fully apply atmospheric correction (elevation). You will lose some HP/TQ, but the amounts are FAR less than a N/A vehicle would lose.
__________________
1997 Rio Red Cobra Vert Gone but not forgotten, 1989 TT notch... Best 1/4: 11.35 @ 125.84mph (1.77 60') 489rwhp/527rwtq |
#13 |
Something is off NO?..I have way more motor and i see 14 psi...i make less...lol..unless the dyno they used sucked...LOL...
__________________
#16 | |
Congrats.
__________________
Car/92 5.0/ Engine stock block/ and bolt-ons.. |
#17 | |
__________________
#19 | |
Supercharges and blowers are completely different beasts and have no way to regulate their pressure levels. They absolutely will lose pressure with elevation. You simply can't use SAE correction on turbo'd vehicles at higher elevations. I'm not sure if it's possible to turn of just the DA correction or not, but it's possible to just the STD values. While they may not be 100% on, they will likely be far more accurate. |
#20 |
I made 440 HP and 500lb torque on a stock 67k mile motor with GT40 head and explorer intake running 110 octane with 10lbs of boost. Dynojet. Oh and I have a T5.
__________________
#22 |
True but i think my motor is in very good shape...I know my tune is set up safe..so i know its leaving HP on the table...
__________________
#23 | |
So SAE numbers are Golrified numbers?
__________________
#25 | |
__________________
#26 | |
If you aren't paying attention, it is possible that some places won't apply SAE correction while others will. Look at your dyno read-outs and see if they are SAE or STD. |
#27 |
All my runs are SAE corrected. My last turbo car was dynoed about 150 times on 4 different dynos in 3 different states. They all were SAE. Millhouse you have me 2nd guessing things, but I only use the dyno as a tool. The tack is where it matters to me. I will be going there next weekend.
__________________
#28 | |
__________________
#29 | |
They are probably inflated because of the SAE correction. In the end though, you are looking for how the vehicle is performing at the track. |
#30 |
Millhouse have you ever had a turbo car that you went to 7000 ft to sea level. My diesel truck is turbo and at higher elevation looses boost every time. So you my friend are wrong dont care what your physics say. That is just what happens and not cool the guy telling you his car looses boost and you not even being there says no it dont.
#31 | |
There are only a few reasons you would lose boost at higher elevation. Either you have a crappy or defective wastegate (remember wastegates reference off of gauge pressure), your turbo is exceeding it's max efficiency rating, or perhaps you are just not staying in it long enough to reach full boost (you will have more lag at higher elevations). With a good wastegate and a properly sized turbo, there is no reason to lose any pressure at elevation. At 5000 ft, the absolute air pressure is 12.2 psi. If you are running 10psi of boost at sea level, instead of seeing an absolute of 24.7 psi(14.7psi sea level +10psi gauge), you would see 22.2 absolute psi (12.2psi at 5k feet + 10psi gauge). Your gauge is going to read the same 10psi regardless of elevation, as it is reading gauge pressure. The wastegate too operates off of gauge pressure. There are some electronic gauges however that are calibrated to sea level. In those cases, you actually would see a skewed psi reading at higher elevations. It would be an incorrect reading however, as the gauge pressure should remain the same. |
#32 |
Higher elevation = thinner air = less air to be compressed. Therefore less air volume coming through compressor = less air volume being discharged = yup less boost. You cannot compress what is simply not there.
__________________
I'm not a magazine racer, my car is actually fast. I also have a Honda civic but, mine has a bigger, uglier driver. |
#34 |
Your totaly right! Doesn't matter about turbo or blower if the air is thinner it takes more work to make the same PSI or HP. Not bashing anyone but untill you have been at elevation you don't know how much it affects the car.
__________________
#35 |
This thread is full of fail. Millhouse is 100 percent correct. On a turbo application 10psi is 10psi over absolute air pressure it doesn't matter what the elevation is. If your turbo isn't making the same boost at higher elevation it's out of it's efficiency range. Nice posts Millhouse.
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
