Hello.....ON3 - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > Power Adder Forums > Turbochargers
Old 03-29-2012, 07:00 PM   #1
flashman's Avatar
Hello.....ON3
http://forums.corral.net/forums/loun...l#post10907945
Figured you would like to see this.
I recently purchased a 1992 Mustang Notch three weeks ago. I did a lot of research and the 70 mm On 3 Performance turbo kit was exactly what I wanted for my Mustang. I called On 3 Performance on 3/19 and I talked to a guy named Mike. Here is the number I called: 614-439-0057. The number is listed on their website. I talked to him for 20 minutes about the kit and everything I would need to make the kit work on my Notch. So, I went ahead and placed a order over the phone. I ordered the 70 mm turbo kit, fuel pump, 42 pound injectors, oil relocation and y pipe. The total came to a little over $2,500. I gave Mike my debit card information and he called me back about 30 minutes later. He said my card had a limit on it. Called my bank and I found out it had a $1,000 daily limit. I called Mike back and he said he could break it over three days. He said he would have to charge me $10 for each charge (not a problem to me). I called them back on the 3/22 because I only seen one charge come out for $900. Mike said that everything is fine and he will process the rest over the next two days. He said my turbo kit would be mailed out on 3/23. Monday came and I still only seen the one charge. I tried calling two times on Monday and I got the voicemail both times. I left a voicemail Tuesday morning asking what is going on. They never called me back. I called back mid day on Tuesday and Mike answered. I asked him about my order and he said he has no record of my order. I said WHAT! I have talked to you several times and you took $900 out of my account. Said to hold on a minute and he stumbled around for a few minutes. "I am pretty sure your kit shipped out on Friday." I asked for a tracking number. "Ah, long pause. My UPS site is not updated yet. I will call you back in 30 minutes once it is updated". He never called me back and I called back at 4:30 on that day. Left a voicemail for them to just cancel my order and refund my money. Called back four times on Wednesday with no response and left a voicemail each time. It is 3/29 and I still haven't heard back from this company. I am going to be contacting the Better Business Bureau and the Ohio Attorney General. I am not trying to bash this company. I have read great things about this company and this is why I placed my order with them. I just wanted to share this issue and want my money back.
__________________
89 coupe- some parts
best time-11.67
best mph-120.57
best 60 ft-1.63
flashman is offline
Old 03-29-2012, 07:22 PM   #2
MY 93 GT's Avatar
Ok....i guess i got lucky..i called placed an order paided by credit card...recieved it 4 days later...I did call tho to get a tracking number which they did email me...I hope everything works out for him...
__________________
Turbo installed!!!!
87 GT Vert.On3 turbo making 14 psi,Trickflow TW 170cc heads,TF street heat intake,70mm TB,stock cam,1.6 roller rockers,Snow performance stage 2 meth kit,42# injectors,340 lph fuel pump,tunning with Moates QH,AOD mild stall.3.55's
MY 93 GT is online now
Old 03-29-2012, 11:23 PM   #3
Ordered my kit last week(3/21), ON 3 kit with 76 mm ceramic ball bearing upgrade turbo, and every accessory possible. I received all the hard parts(turbo, hotside, coldside, mounting stuff, BOV, etc) yesterday(3/28). Now just waiting for the Wastegate and the fuel system components. I ordered mine from Power Adder Solutions. Not sure if that makes any difference, but it worked for me. Good luck.
wytwolf is offline
Old 03-29-2012, 11:24 PM   #4
i ordered a 76mmturbo and paid over the phone at the time was backordered and came to me faster than stated and has worked great .i got my on3 hotside used from a member had pin hole in header and bad flex coupling
allenpeake is offline
Old 03-29-2012, 11:47 PM   #5
smurfmobile8586's Avatar
It doesn't look good
__________________
smurfmobile8586 is offline
Old 03-30-2012, 12:34 AM   #6
I don't understand how any legit company can do this.
My buddy was going to order an on3 kit this week. I showed him this thread and he immediately called b&g lol
__________________
TWIN TURBO!! Because bottles are for babies and superchargers blow
megasquirt tuned to 14psi. 25psi tune coming soon
luckythirteen13 is offline
Old 03-30-2012, 12:41 AM   #7
Savier's Avatar
Ordered mine over phone. Never talked to them again got my kit in 3 weeks (Canada)
__________________
92 Notch, 347 H/C/I
Savier is offline
Old 03-30-2012, 02:46 AM   #8
sweat90lx's Avatar
it does. Chris at PAS will answer the phone every time you call and not give you any runaround BS.
__________________
12.7s motor, 11.7s spray, turbo 400/460. 11.2@128
sweat90lx is online now
Old 03-30-2012, 09:29 AM   #9
mghoward74's Avatar
That goes to show you that Chris knows how to do business.
To the OP: I wouldnt worry about it too much. If you paid with a cc or debit card, it will show up your bank statement. There' s your defense
Good luck
__________________
mghoward74 is offline
Old 03-30-2012, 12:45 PM   #10
never had an issue with mine when i called and ordered mine. Turbo was on Backorder and when it showd up my kit was shipped.
Hope it all gets worked out.
boostedstang98 is offline
Old 03-30-2012, 07:34 PM   #11
So On3 was online yesterday and today and decide not to respond to this thread. Hmmm.
__________________
Deployment gift to myself
R.I.P 1999 SVT Cobra - On3 6psi 382rwhp 380ftlbs
2001 5.4 Gt - MMR Shortblock, Tork Tech 5.4 Kit, Stage 3 P&P Heads, Stage 2 Blower Cams, Ported and Pullied Eaton, Solid front end suspension, IRS and some more.
Ortiz99 is offline
Old 03-30-2012, 07:59 PM   #12
read my mind
__________________
Old 03-30-2012, 09:09 PM   #13
arieso94z28's Avatar
Ordered my kit on 3/19 also and he said it was on back order and they would call me with a tracking #. Haven't heard from them yet, so I'm crossing my fingers that I will hear from them next week sometime.
arieso94z28 is online now
Old 03-31-2012, 03:01 AM   #14
Subscribed...
To the OP, good luck gettin your money back...
__________________
97GT
0HP/0TQ
Blown HG...
Chingus is offline
Old 03-31-2012, 06:09 AM   #15
Never ever! Deal with on3 directly...they screwed me too...order there stuff from jegs and you will be ok
fox_stang is online now
Old 03-31-2012, 01:05 PM   #16
another happy customer
Forums at Modded Mustangs
__________________
2001 true blue bullitt...turbo
RickRoss is offline
Old 03-31-2012, 01:13 PM   #17
MIKE92NOTCH's Avatar
because they're not a legit company. he's just the middle man for some china made crap steel.
it's been shown over and over and over and over again that it's not a quality product. but the price makes guys see a "deal too good to be true". but guess what, it's not true!
__________________
95 Crystal White GT
8.50 chassis with a 12 something drivetrain
MIKE92NOTCH is offline
Old 03-31-2012, 02:59 PM   #18
They are a legit company. As far as I know there is only two guys who work there. They are younger and I am not sure if they work there full time etc. They might go to school etc. His dad owns the right stuff they make brake lines etc.
Disc Brake & Brake Conversion Kits, Stainless Brake Lines, Fuel Lines | Right Stuff Detailing
__________________
The Fastest Yellow 95 GTS turned into a Cobra in the world!!
5.0 GT40x heads,Gt 40 intake,Custom cam, Kb Blower 8-10lb,Blowzilla Bypass,FMS headers,Bassinni X pipe and cat back, cobra r hood, cobra front and rear bumpers,chrome cobra r wheels and a whole bunch of other stuff I am forgetting
eazycj is offline
Old 03-31-2012, 03:03 PM   #19
flashman's Avatar
They actually deleted the thread. Whats up with that.
__________________
best time-11.67
best mph-120.57
best 60 ft-1.63
flashman is offline
Old 03-31-2012, 04:29 PM   #20
mghoward74's Avatar
Smoke & mirrors
Smoke & mirrors
Problem solved, delete a thread, and it never happened...lol!
__________________
Old 03-31-2012, 05:43 PM   #21
Im as legit as any other company out there, if you choose to not do business with me, thats your choice. There are plenty of other turbo companies out there, Im just one of the options. I have had issues with Mike, he is not with my company any longer as of Friday and thats another story. Funny thing is that other companies have followed in my footsteps now seeing that my kits have satisfied so many customers :-) I find the select few guys in this thread still are worried about what Im doing after what 4 or so years now?
I have never taken peoples money and not provided a part. This guy that made the first post has followed me since day one, I have nothing to say about him. Im not going to just waste my time in threads intended to just stir up a fight. The guy was refund, wasn't even mad, talked to him 2 times yesterday. Oh well, back to being productive
__________________
On 3 Performance.com
5.0 Fox, SN 5.0, 4.6 2v, 3v, 4v Turbo Systems, NEW Forward Facing 2v & 4v, 5.8 Swapped Foxbody, S197 4.0L V-6 Kits Now In-Stock
90 Coupe 4v Single Turbo, 99 Cobra 9.4psi(526/550), 02 GT 10psi(440/496), 2011 5.0 GT Twin Turbo
Shop Line - Monday Through Friday 10am-4pm Eastern 614-439-0057
On 3 Performance is offline
Old 03-31-2012, 05:46 PM   #22
James, the sn kit is on back order, I do not have an exact shipping date on that setup. I have no idea why Mike would have told you tracking would have been received by now. Pm me your number and Ill chat with you on this order
__________________
Old 03-31-2012, 05:50 PM   #23
I am on my phone so can't copy and paste the link but there is a guy in the Lounge that posted an hour ago who seems rather mad with Mike at On3. User is Matt something or other. You might want to contact him to solve that issue too.
Sent from my iPad Nano
__________________
--Aaron Rouse http://www.happyhacker.com/
2003 F250 PSD - Daily driven "rod knocker"
2009 335d - Backup "rod knocker"
1985 300SD - Money pit "rod knocker"
Old 03-31-2012, 05:51 PM   #24
There's always gonna be a few unhappy customers....I ordered my kit last week or so from these guys and they were very helpful over the phone. I believe I talked to Chad? Anyways, not sure when my kits coming but I can't wait
justinschmidt1 is offline
Old 03-31-2012, 05:54 PM   #25
MY 93 GT's Avatar
Wow sorry to Hear about Mike...Like i said im happy with your business ethics i had no problems..The kit seemed awesome...Not bolted up yet i will keep you posted on how that goes...
__________________
Turbo installed!!!!
Old 03-31-2012, 06:00 PM   #26
sweat90lx's Avatar
Matt@CMM
Getting screwed by ON 3
Sorry Mike but as I told you on your voice mail, I have been nice long enough. It has been over a month and you took $2,000 from me and you have yet to take the remaining $900 out of my account and I still have no turbo. I have no emails from you, no voice mails, nothing so unfortunately im going to take further action up to and including credit card fraud and grand larceny. As you may or may not know, in Massachusetts anything over $250 is grand larceny which is a felony.
Id like to refer you to Massachusetts General Law which from here on will be referred as (M.G.L)
M.G.L Chapter 266 Sec 38: Larceny, wrongful detention of money by carriers:General Laws: CHAPTER 266, Section 38
M.G.L Chapter 266 Sec 37 C: Fraudulent use of credit cards to obtain money, goods or services; false embossment of credit cards, multiple possession, presumption; arrest
General Laws: CHAPTER 266, Section 37C
M.G.L Chapter 266 Section 33 Larceny; false pretences relating to contracts, banking transactions or credit
Section 33 Larceny; General Laws: CHAPTER 266, Section 33
I'd like you to rectify this by Monday April 2nd 2012 BY 5:00 pm, its as simple as charging my card the remaining $900 and shipping the turbo out (which would make my total $2,900) and Ill delete this thread and go back to business as usual, it's up to you.
I have all legal paperwork needed that are stamped and ready to mail out Tuesday morning if I do not hear from you by the above date and time.
__________________
Old 03-31-2012, 06:02 PM   #27
Hah, I meant a link to the thread do he could contact the guy.
__________________
Old 03-31-2012, 06:21 PM   #28
No one is getting screwed, is this a joke or what? I dont know what you have worked out with Mike but it doesnt matter. You are more than welcome to pm me your number so I can find out who you are. I have no reason to hold someones money, certainly there is an issue with the payment but its not a big deal. Its really much quicker and easier to talk with me instead of finding all these laws that you have done. I just have to verify nothings been shipped out and I can put the money back on your card.
You will have to contact me though as Mike is not with my company and I have no clue the issue and cannot figure it out
__________________
Old 03-31-2012, 06:25 PM   #29
Justin, just looked at your order and its on the shipping board right now. I just started answering the phones yesterday but if you called, it would have been me. The order had a note to wait for the oil restrictor on your turbo and ship it all at once. Ill have the restrictors I believe on Tuesday and I pulled your stuff actually earlier today to get boxed up. Any other questions let me know
__________________
Old 03-31-2012, 06:33 PM   #30
Sweet. Thanks for the update. Hopefully it all goes together smoothly...ill be sure to brag about how awesome the kit is and do a nice install write up.
I'm waiting on lots of other parts so i said to.wait for the oil restrictor to come in before shipping.
I'm really curious to see how that 67mm bb unit performs, especially with my.combo. stg 3 ported pi heads, hp292 Cams and the edelbrock Victor Jr manifold
Old 04-01-2012, 12:44 AM   #31
sweat90lx's Avatar
point got made.
customer service needs improvement and I think On3 realizes it and is trying to improve.
__________________
Old 04-01-2012, 01:27 AM   #32
seems like everything is being taken care of on On3's side.....so why the continued drama?
__________________
95 Cobra - Comp Billet HP7679 DIY Turbo and 331CI A4 Car
Kurgan tuned - juuuuuuuust a little over 385RWHP....
KMS West O.G. --- Sacramento
chinopsu is offline
Old 04-01-2012, 10:07 AM   #33
Without a "drama thread" like this then On3 might not been so quickly informed about things such as Matt who posted up in the Lounge of all places not even 24 hours ago. Sometimes people over reacting results in others being able to more promptly find out about things.
__________________
Old 04-01-2012, 10:16 AM   #34
Buds91LX's Avatar
I just wanted to chime in. I live in Cleveland. I drove down to On3 on Friday 3/30 and picked up one of there FF cobra set ups. After going over turbo options and looking every thing over, Chad spent a good hour plus just chatting. He has a lot going on for 1 guy right now. His shop is top notch. His shop cars are aw some.
He has a lot of inventory, and he has a lot of other things to offer and sell then just the turbo set ups. If he updates his web sight to show the things he offers to go along with his kits you would be amazed at what he has going on.
When I got home and opened up all the boxxes, I had a small problem, Email with him back and forth Friday. I sent the part back and when he gets it he will send another one.
You all just need to relax and give him a chance to find out what and where Mike may have drop the ball. I am sure Chad will make it right for anyone that needs it.
Keep up the good work Chad
Gene
__________________
Rio Red 97 cobra. Full turbo build. 78MM
91 Vortech LX. 15#boost. Sold
silver Whippled 03 cobra. Sold
DSG Whippled 03 Cobra Sold
Buds91LX is offline
Old 04-01-2012, 02:39 PM   #35
Just sent you a pm Chad. I appreciate you willing to take the time to talk with me as this will put my mind at ease. Looking forward to ur call.
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
