#1 |
Fuel pump question?
I bought the on3 turbo kit and i bought there 340 lph fuel pump...does anyone use it? And i forgot to ask them What brand is it?
__________________
Turbo installed!!!! 87 GT Vert.On3 turbo making 14 psi,Trickflow TW 170cc heads,TF street heat intake,70mm TB,stock cam,1.6 roller rockers,Snow performance stage 2 meth kit,42# injectors,340 lph fuel pump,tunning with Moates QH,AOD mild stall.3.55's |
| Sponsored Links | |
Advertisement |
#2 |
I've used the knock offs and the areomotive ones with very good results
__________________
Mike Post 847-347-5331 www.DynotuneMP.com www.performancepartsunlimited.com Pro-Grip Pulleys/ www.Carbiniteracing.com 2001 NMRA Renegade Champion 2002 NMRA Renegade runner-up 2005 WFC 8 Renegade winner 2009 Outlaw True Street Champion 7.75@182 SCT, Diablosport, PMS, BS3, F.A.S.T. and F.A.S.T. XFI |
#5 |
On3 said its there own...Its in the tank already hope it is good....lol
__________________
#6 |
I'm a bit of a skeptic anyways, but I would advise you to spend a little more money on an inline pump. You have a couple of choices I use and recommend the Anderson big pump. I look at it like this: it's cheap insurance. And when is this car gonna be done? Now I'm getting anxious!
__________________
I'm not a magazine racer, my car is actually fast. I also have a Honda civic but, mine has a bigger, uglier driver. |
#7 | |
Im thinking that the shop will know if i have enough fuel? being there tunning it and i have a AEM wide band..and im sure there going to have a fule pressure gauge hooked up to check to make sure it doesnt drop..I hope it works out if not thanks for the advice i can let them know that... And your getting anixous???...LOL.... Ive been without the car for like 3 weeks i think maybe 2...lol. i cant wait to get it back..But then i dont want to rush anyone i would rather have it done right..Its alot of work they have to do...Heads,intake new timing chain,MAF conversion,Re-locate the snow meth kit,wire in the Wide band,turbo install,tunning,im probably forgetting something...lol
__________________
#8 |
you should make anywhere from 530-575 rwhp.....if tuned properly
probably need a lil more fuel system though.....but it's a good starting point enjoy
__________________
KMS West member, SoCal Chapter Tuned by Bob Kurgan April 20,2012 at GTR 410w, AFR 225's, solid roller, 91mm, Bigstuff3, 120's, E85, TeamZ... |
#9 |
Wow you think that much HP?....i was thinking more of the lines of maybe 400-450 ?
__________________
#11 |
__________________
#12 | |
Trader Feedback: (29)
You'll probably need 60 lb/hr injectors. My 42's ran out at around 450 rwhp. My combo is a stock bottom end, stock cam, out of the box twisted wedge heads and a performer rpm II intake and I make 534 rwhp on 13 lbs with a 70mm turbo.
__________________
1995 Mustang GTS. Stock bottom end with boost. 534 rwhp, 513 rwtq. 10.72@129.31 on 17" drag radials. "Just turn the boost up.....it's only air." |
#13 |
OK maybe i will make that HP...i dont know...i know my Heads have some major porting and polishing..i run the stock cam 1.6 roller rockers, Street heat intake..70mm TB...and i think there shooting for 10 psi..But i have an AOD so im thinking thats going to rob some HP....
__________________
#14 |
There is a guy who has the exact same setup you have, but supercharged....making 556 rwhp. What advantage he'll have over you is......his tuner is considered one of the best.
If your tuner is good expect close to those #'s minus loss through the AOD.
__________________
#15 |
Also....look @ tireburner sig.
He's making 534 Setup is almost identical
__________________
#16 |
Cool...i should be able to get into the 11's then...My tunner his car is almost like me too...he has a cam VS my stock cam...he's in the 10's his car is a stick and lighter then mine tho...VS vert and an AOD...lol...Well not bad if i can get that HP....and ET's
__________________
#17 |
Nothing they sell is their own or came from their R&D dept.
__________________
#18 |
Thats what i was thinking so what brand is it?>..lol
__________________
#19 |
Dunno what brand it is
By the way....if your suspension is design for it....you can run 10's Suspension is the key
__________________
#20 | |
__________________
#21 |
Not to wish bad luck on you guys but I see split blocks in your future. I have an aeromotive 340lph....Have about 2000miles on it.....Hasn't missed a beat. Tireburner does that rpm performer intake fit under the stock hood?
__________________
95gt stock short block, Ported xploder GT40p heads and intake, F cam, ARP head studs, 70mmTB, On3 Turbo Kit 15psi on occasion and head gaskets holding, Moates tuned by me, AODE done up. Drag radials, 327 rear. 10's @130 foot breaking.... |
#22 |
What HP do you make?..isnt your block stock too?....i hope the fule pump is a decent one...lol..
__________________
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
