on 3 performance turbo kit 5.0 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 311 Old 01-06-2009, 10:19 AM Thread Starter
since the other thread is way off subject, can we get some reviews personal experience with this kit, is it good or bad, whats the pros and cons of it.. is it worth the buy or go with a well named kit?
superfeak is offline
post #2 of 311 Old 01-06-2009, 12:18 PM
jonyboy107's Avatar
Trader Feedback: (15)
theres one recently started on tm as well.. http://www.theturboforums.com/smf/in...;boardseen#new
DAILY DRIVEN: 92 GT
306,9,5:1,AFR 185s,RPMII,xe264hr,ProMagnum rockers,turbonetics 66S,bg kit,METH,Flowmaster catback,Accufab race 75mm,pro tube,60lb injectors,255lph walbro BAP,ac delete,no smog,full MSD ignition,mark fan,3G alt,TKO600,spec stage 3,alum flywheel,3.55s
jonyboy107 is offline
post #3 of 311 Old 01-08-2009, 02:10 PM
there are specific people that post to just get things off topic and accomplished what they tried.
On 3 Performance.com
5.0 Fox, SN 5.0, 4.6 2v, 3v, 4v Turbo Systems, NEW Forward Facing 2v & 4v, 5.8 Swapped Foxbody, S197 4.0L V-6 Kits Now In-Stock
90 Coupe 4v Single Turbo, 99 Cobra 9.4psi(526/550), 02 GT 10psi(440/496), 2011 5.0 GT Twin Turbo
Shop Line - Monday Through Friday 10am-4pm Eastern 614-439-0057
On 3 Performance is offline
post #4 of 311 Old 01-08-2009, 10:15 PM
Project Reef Blue's Avatar
X2.
Stock Block 306", TFS 170, Systemax, F303, Novi 1220, Tweecer, Faceplated TKO 500, Mr. Freeze, 3100lbs
N/A: 332rwhp 332rwtq 11.44 @ 117mph; 6psi: 10.765 @ 128.31mph
Project Reef Blue is offline
post #5 of 311 Old 01-09-2009, 02:45 PM
ramsey was doing a complete write up on the install of his car on there as well and its under control. He didnt start installing yet but he said sometime this month when he gets time so should start getting other photos from what he said
post #6 of 311 Old 01-10-2009, 08:30 PM
mine went on fine. i have to get 1 a/c line custom built.
i did not even do the oilfilter relocation. i run the small motorcraft filter.
larryb is offline
post #7 of 311 Old 01-10-2009, 08:43 PM
do you mind sharing what filter part number you used?
post #8 of 311 Old 01-10-2009, 09:15 PM
i am going over to the shop tonight and i will get it for u.
larryb is offline
post #9 of 311 Old 01-10-2009, 10:00 PM
blackbob's Avatar
Thanks man, That'll help us shave cost on our own build.
blackbob is offline
post #10 of 311 Old 01-10-2009, 10:51 PM
I'm pretty sure its an FL400s filter
89 Black Hatch, 306, stock heads upgraded springs, XE274HR, Trackheat w/ 70mm T/B. shorties catted Hpipe, Flows, 4.10s manual V/b AOD w/ 3800 stall. 100 Shot. Best Time 1.60 7.55 @ 90 11.89 @ 113
Battousai is offline
post #11 of 311 Old 01-11-2009, 12:48 AM
motorcraft FL910
larryb is offline
post #12 of 311 Old 01-11-2009, 09:49 PM
Josh93's Avatar
Im wanting to run this kit also but im new to the turbo scene. I have a UPR k member and dont know if it'll fit or not. Or if i'll have to buy a blow through MAF since i already have a draw through.
Anyone know?
1988 SSP Coupe-04 Cobra Swap
Josh93 is offline
post #13 of 311 Old 01-11-2009, 10:20 PM
it will fit with that k-member
larryb is offline
post #14 of 311 Old 01-11-2009, 10:31 PM
Josh93's Avatar
Thanks, are you running one of their kits? If so, how was the quality?
Josh93 is offline
post #15 of 311 Old 01-11-2009, 10:41 PM
yes i have there kit.. the kit is nice. i just got it going in the last week.
i bought mine with 76mm turbo.
my 306 dynoed 612 to the wheels.
larryb is offline
post #16 of 311 Old 01-11-2009, 11:50 PM
Josh93's Avatar
Dang, thats some good numbers.
Will I need to upgrade anything on it? Any reason why you went with the bigger turbo? How does it sound?
Im just lookin for a well performing turbo that sounds mean.
Im new to turbos so I dont know that much
I know a pretty good bit for my age but I have alot to learn.
My Novi 1000 is pretty straight forward and gets the job done but I
just want something different
Josh93 is offline
post #17 of 311 Old 01-12-2009, 12:16 AM
i went with bigger turbo to make more power..
it sounds ok. i have a 3in magnaflow Y'ed into 2.5 in tailpipes.
larryb is offline
post #18 of 311 Old 01-12-2009, 03:28 PM
Josh93's Avatar
Oh, did you use a blow through or draw through MAF? or is yours speed density?
Josh93 is offline
post #19 of 311 Old 01-12-2009, 03:45 PM
i have a fast efi..speed density
larryb is offline
post #20 of 311 Old 01-12-2009, 04:07 PM
Josh93's Avatar
ahh. is it possible to run a draw through with that kit?
sorry for the random questions man.
Josh93 is offline
post #21 of 311 Old 01-12-2009, 05:21 PM
red89coupe's Avatar
Trader Feedback: (31)
Im NOT trying to get off topic like the other thread did but I have to say... STAY AWAY from SS 304 !!!!!!
I have SS 304 ebay headers and I faild to believe all the hype.... now Im pulling them off evey other month to have them welded up where they crack !!
Kit looks great, fit great, and held up for 1.5 years before the cracking started.
Now its time to buy something different cuz Im tired of pulling them off to be welded lol
NEVER do business with Sam Rivera AKA Sam Wilson of Rivera Race Chassis. Paid 2800 to put car together. NO work was done, never gave back my turbo kit. Now I see old adds of my parts being sold on craigslist while car was at his shop.
red89coupe is offline
post #22 of 311 Old 01-12-2009, 09:06 PM
There is nothing wrong with using 302 stainless so long as it is done right. 304 stainless is what Turbo Technology has used for well over a decade and you can find 10+ year old very used kits out there with zero cracking issues. Turbo Engineering, were George who owns Turbo Technology came from, also used 304 stainless and you can find those kits still to this day and no cracking issues. There are other companies as well but those two are great examples of how it can be used and it can work out just great simply because their kits have been in use for so many years.
--Admiral Aaron Rouse
post #23 of 311 Old 01-12-2009, 10:07 PM
Josh93's Avatar
Oh yea, did you have to cut or modify anything to make it fit?
Josh93 is offline
post #24 of 311 Old 01-12-2009, 10:18 PM
i had to trim my lx nose a lil.
larryb is offline
post #25 of 311 Old 01-12-2009, 10:20 PM
Crud, typo above, meant 304 not 302
post #26 of 311 Old 01-12-2009, 11:40 PM
Josh93's Avatar
Ok thanks alot man
Josh93 is offline
post #27 of 311 Old 01-13-2009, 12:40 AM
WHITEMACH's Avatar
Trader Feedback: (23)
fls-400 motorcraft!!
2012 GT AUTO
bbr tune ,bbr x-pipe,jlt cold air
11.81@118.11
WHITEMACH is offline
post #28 of 311 Old 01-13-2009, 12:56 AM
Anyone know?
It would fit for sure, it fits with the stock k-member so the tubular setup will only have more clearance
post #29 of 311 Old 01-13-2009, 12:57 AM
Im going to go check out both of these and see what I think, thanks guys
post #30 of 311 Old 01-13-2009, 06:46 AM
millhouse's Avatar
Correct me if I'm wrong, but I do believe Turbo Technology used 304 stainless in their manifolds...not their headers. There is a huge difference in regards to fatigue. 304 is not meant for extreme high temps with constant heat cycles....which is why you see it used in countertops at restaurants and in kitchen sinks. It's possible to design a 304 header that can withstand the heat, but it's going to take some kick ass welding (tig, back purging with an inert gas) along with engineering. Supporting a turbo with the expansion factor seen in basic 304 is tough...which is quite often why you seem to see so many cracked tubular headers.
millhouse is offline
post #31 of 311 Old 01-13-2009, 11:09 AM
They use it in their headers, look at any TTI single race kit since that is the most common kit they have sold for Fox bodies and it uses a header not a manifold. Turbotime PSI uses 304 some as well although I think they tend to lean towards using 321 if at all possible($ being the factor).
post #32 of 311 Old 01-13-2009, 11:23 AM
millhouse's Avatar
I believe they are tubular log manifolds with a massive diameter, single tube supporting the mass of the turbo.
As for turbotime psi, their designs are completely different….as they are basically hanging down low rather than up high. The turbo’s themselves do not appear to be wholly supported by the lone header, but rather the entire hot side. They also appear to have an intermediate connector between the header, turbo and cross-over. It appears to be a well thought out kit, that’s for sure.
There is one caveat however….as it does not appear to be offered in 304 stainless anymore… “Available in mild steel, or military grade 321 stainless, .065 wall, annealed, backgassed”.
post #33 of 311 Old 01-13-2009, 11:27 AM
You believe wrong, the TTI race kit does not use a log manifold. Here is a picture if you need visual proof:
http://www.turbotechnologyinc.com/si.../50_single.jpg
I talk to the owner of Turbotime quite often and you can get them in 304. The overall design he is using is similar to the Turbo Engineering kits I mentioned earlier and those were 304 as well.
post #34 of 311 Old 01-13-2009, 11:51 AM
and back to the thread topic...
post #35 of 311 Old 01-13-2009, 11:56 AM
red89coupe's Avatar
very very true. !! I will have to change it to ...
stay away from EBAY SS 304 headers !! LOL
IF its done RIGHT they will NOT crack however inorder to do something RIGHT it allways costs more. On3 has allready admited to sending them out (but wont say where) to be made/welded to get the best possible price. Im NOT bashing on3 its just what I have found in the threads related to his kits that I have read. I doubt who ever he sends them to does as good of a job as george/tti ect.... after all they are the lowest bidder on the job lol
Im NOT expert by far thats for sure but the "quality" looks exactly like the treadstone/vecco headers which I have cracking all to hell right now as we speek lol lol
