'96 Cobra: Brake lights not working? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 12-01-2007, 02:54 PM Thread Starter
I need some help guys. The brake lights are not working on mine/my dads '96 Cobra. The taillights DO work when the parking and/or headlights are on though. He just bought a new brake light switch that I just installed a few minutes ago, but that did not fix it. We dont have the owners manual for the car so I dont know if there is a relay or fuse to check. I have also checked the harness in the trunk and it looks fine (as I said, the taillights do work, just not the brake lights). Any ideas??? Its kinda dangerous to drive it without the brake lights working!
EDIT: The turn signals, headlights and foglights do work as well. Just not the brake lights!
1996 Laser Red Cobra- JLT, BBK O/R H, B Springs, KYB's and Saleen replicas (SOLD Aug '09)
2006 White Mazda 6s (daily driver)
Dave89GT is offline
post #2 of 12 Old 12-01-2007, 03:07 PM
Always check the fuses first.
birdman941 is offline
post #3 of 12 Old 12-01-2007, 03:16 PM Thread Starter
Just did. None of them are blown.
Dave89GT is offline
post #4 of 12 Old 12-01-2007, 04:01 PM
Get a test 12V test light.
There are 2 wires going to the brake light switch.
Green with a red stripe if I am not mistaken.
One should have constant voltage going into the switch,
and the other only when the switch contacts are closed. (brake applied)
If you have no voltage there,
check for volatage "upstream" a few inches in the harness before it gets to the connector.
The wire may have broken inside.
if so, repair the connection there.
post #5 of 12 Old 12-01-2007, 05:43 PM
Does the third brake light work? It is kind of strange all the brake lights would quit working at the same time. Did you make any changes to the car that involved anything electric recently?
BrightBlueCobra is offline
post #6 of 12 Old 12-01-2007, 05:59 PM
Sometimes once cars accumulate some age and mileage,
the connectors on the ends of the wires going to the brakelight switch
lose connection with the wires.
If the fuse is good as he states, it's the only explanation for the symptoms.
post #7 of 12 Old 12-01-2007, 07:18 PM Thread Starter
No, the 3rd one doesnt work either. Im gonna have to find me a test light.
Dave89GT is offline
post #8 of 12 Old 12-01-2007, 11:55 PM
Big Top GT's Avatar
Trader Feedback: (37)
If all three lights went out you're going to have to go through the pain of tracing out the wires in that circuit.
It's going to be a HUGE pita.
Hopefully, it's something as arbitrary as a loose connection somewhere.
Good luck and keep us posted.
Alan
98 Cobra Coupe ~ Back to square one: no motor.
2006 Lotus Exige - 1.8 litres of Supercharged fury!!! SOLD!
Originally Posted by ATOMONKEY
If you don't want to take my word for it, maybe you'll believe the internet.
Big Top GT is offline
post #9 of 12 Old 12-02-2007, 06:00 PM
If they are all out, it's probably right up at the brake light switch.
He didn't mention any issues when braking with the turn signals on,
so if the voltage never gets to the interruptor wire
going into the turn signal switch, it's likely before the brake light switch,
right at the connector itself.
post #10 of 12 Old 12-03-2007, 09:07 AM Thread Starter
Man I hope youre right! If its not in that little section, that will be a major PITA
Dave89GT is offline
post #11 of 12 Old 04-01-2013, 04:22 PM
Trader Feedback: (32)
I know this is super old. but, by chance did you figure out what was wrong? mine quit working over the weekend
bone stock Bright Atlantic Blue 98gt
ruffledfeathers is offline
post #12 of 12 Old 04-02-2013, 08:51 PM
If the 3rd brake light is out along with the regular brake lights it's more then likely the multi-function switch (turn signal lever assembly). Do your turn signals work (not that it matters really, for some reason when this thing goes bad the brake lights stop working)? You can remove the multi-function switch, open it up and clean up all the corrosion that's on the contact pads and put some more dielectric grease in it, should fix it. Be careful though, lots of little springs in it. A new Motorcraft one costs about 70 bucks if you don't want to fix it yourself.
Helomech74 is online now
