Drivetrain vibration on acceleration - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 11-16-2007, 09:57 PM Thread Starter
Since added the turbo to the car I've been having a drivetrain vibration on acceleration. It seem to be worst in 1 & 2 gear. I've already changed the transmission mount and u joints. I noticed the drive shaft sometimes hits the car under the parking break. I still have the stock control arms in the car. Could a damage/worn out control arm bushing cause that problem? I have steeda springs with tokico shocks if that matters. I really think it is coming from the rear end of the car.
Forged Short Block, Stock heads, cam, intake
Single MP T-70 Turbo
turbochargedinnovation.com
sc96cobra is offline
post #2 of 7 Old 11-17-2007, 12:06 AM
Janstang's Avatar
What transmission do you have? Also, have you checked the driveshaft to confirm its not bent?
01 Mustang Cobra
T88 turbo, 5.4L, GT Heads, Powerglide tranny, plus much more..
Janstang is offline
post #3 of 7 Old 11-17-2007, 01:24 AM
sc96cobra: "I noticed the d/shaft sometimes hits the car under the parking brake. I still have the OE control arms in the car. Could worn out control arm bushings cause that problem? I have Steeda springs w/Tokico shocks."
I had the same problem & initially assumed that it was the used aluminum d/shaft that I installed. Purchased NEW aluminum d/shaft ... same problem. Installed upper/lower Steeda rear control arms ... no more vibration & the bottoming issue is gone. I think that MM says that you only have to replace the lower arms, but I took the shotgun approach to fixing the problem cuz I just got tired of chewing up the d/shaft.
'98 GT equipped w/Koni, Eibach, Cobra R rims w/Yokohama tires, Cobra brakes all around & 3.73 gears. Also a Boss330 4.6 Cobra block w/PI heads & stuff from Accufab, ARP, Centerforce, Comp Cams, Fidanza, K&N, Mahle, Manley & Borla exhaust w/Mac Pro Chamber thrown in for grins & giggles.
Geezer is offline
post #4 of 7 Old 11-17-2007, 09:41 AM Thread Starter
T45, How could you check to see if the driveshaft is bent?
yeah I went ahead and ordered aftermarket upper and lower controls arms. Hopeful that will fix the problem. How do you like the aluminum d/s?
post #5 of 7 Old 11-17-2007, 10:51 AM
Janstang's Avatar
Any driveline shop can check it for you. I liked my aluminum driveshaft, never had any issues. Are you getting the vibration through the seat of your pants or more-so through the shifter? Your asking alot from that T45 with the power you are making..
01 Mustang Cobra
Janstang is offline
post #6 of 7 Old 11-17-2007, 12:06 PM Thread Starter
My T45 has been great, but I know it is on borrowed time. The tranny shifts fine. It really feels like the vibration is coming from the rear but is also shakes the parking brake pretty good. If I punch it from a 45+ roll it is fine. Like I said the D/S sometime rubs the bottom of the parking brake.
Janstang, thanks for the help your setup looks awesome. What kind of power did it make?
post #7 of 7 Old 11-17-2007, 06:34 PM
Janstang's Avatar
Thanks..Never dynoed it, I street tune everything. I can say it runs in the 9's and it destroyed the built C4 tranny.
01 Mustang Cobra
Janstang is offline
