Anyone found anything to quieten a noisy throw out bearing? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 11-06-2005, 12:40 PM Thread Starter
VIPERBLUELX's Avatar
My Spec stage I clutch in my Mystic only has 5,000 miles on it and it's really freakin noisy unless I apply a little pressure to the clutch pedal then it's silent. I tried spraying some lithium grease on it but it didn't phase it. Anything else anyone's tried aside from pulling the dang tranny and replacing the TOB?
98 SVT Cobra 610rwhp/632rwtq Hellion T76
VIPERBLUELX is offline
post #2 of 9 Old 11-06-2005, 01:00 PM
slosvt's Avatar
Take the TOB out and replace it with a Ford piece....Two local guys have had their clutches fail in the past 2 weeks due to the SPEC TOB's...
slosvt is offline
post #3 of 9 Old 11-06-2005, 01:09 PM Thread Starter
this one came with a metal TOB instead of the normal plastic so I thought it would be a good one
post #4 of 9 Old 11-06-2005, 02:26 PM
my tob started making noise and a little bit of wd-40 quieted it up.
99
99svt32v is offline
post #5 of 9 Old 11-06-2005, 03:39 PM
Big Top GT's Avatar
Trader Feedback: (37)
If it's the one that came with the SPEC clutch I'd ditch it and put the Ford piece in. I did when I first bought my Stage III and have never had a problem.
Good luck,
Alan
98 Cobra Coupe ~ Back to square one: no motor.
2006 Lotus Exige - 1.8 litres of Supercharged fury!!! SOLD!
Originally Posted by ATOMONKEY
If you don't want to take my word for it, maybe you'll believe the internet.
Big Top GT is offline
post #6 of 9 Old 11-07-2005, 09:49 AM
Guido in Da Cobra's Avatar
there was a guy a while back who rigged up a spring to pull back on something near the pressure plate. I just picked up one of the clutch pedal adjusting things from steeda and hooked it up so that there is very slight pressure on the pedal. Probably not the most ideal thing for the TOB but I've been driving with it for almost 2 years now and havent had a problem. Plus I used up the slop in the beginning inch or so of clutch pedal travel so the feel is much better.
1998 Black Cobra Convertible- FR500 Stuff, T56, MM Suspension. -Garage Queen-
1998 Blue GT- Loud Pipes, MM Suspension. -Daily Beater-
Guido in Da Cobra is offline
post #7 of 9 Old 11-07-2005, 09:08 PM
SnakeBit's Avatar
http://www.ldcchicago.com/index.php
Fred
03 Cobra Coupe DSG
You dont need the bullet when you got the ballot. ~George Clinton
SnakeBit is offline
post #8 of 9 Old 11-07-2005, 09:13 PM
Originally Posted by SnakeBit
I have one of thoses, but have not installed it yet.
1997 Crystal White Cobra
97WHITE COBRA is offline
post #9 of 9 Old 11-08-2005, 01:15 AM
COBRASVT's Avatar
Aftermarket TOBs squeak / squeal because they have ****ty bearings inside...that's why they don't last.
The squealing is usually caused because the TOB is slightly touching on the feelers of the clutch causing the TOB to spin and squeal.
The spring like the ldcchicago piece (which didn't work for my 98) push the TOB off of the feelers. That way, the TOB is not spinning or moving at all so it doesn't make noise.
This should make the TOB last longer as well since there's no unnecessary spinning.
What I did with mine was to place two springs from under the stock seats hooked one to another and attach to the clutch cable and then to the opposite end to pull the TOB back.
It adds very little effort since the springs are very light, but is enough to pull the TOB off the feelers. I simply hooked them against the metal that's under there. The springs grab and hold w/out falling off believe it or not. I need to take some pics when I'm under there next. I've had them off a couple of times and put them back on and they hold fine just catching on the metal.
You can actually hear a little chirp when you first press the clutch in which lets you know that the TOB just made contact and hasn't been rubbing.
I also use the Steeda clutch pedal adjuster to get the slop out of the pedal. I have the UPR firewall adjuster and triple hook quadrant, so it's set in the middle of the hook to get the pedal close to the floor.
Hope this makes sense....
EJ
edit: Found this pic:
It's similar to this, but I used two springs because they came from under my stock seats and I just hooked it to the metal of the tranny, not a seperate add-on piece.
98 Yellow Cobra Vert #1079 / 3480
Built Shortblock • JLT CAI • Koni strts, shocks, quads • FRPP welded sub frames • BBK C/C • BBK Upr & L C arms • 3.73's • Dr Gas o/r X • Borla XR-1's • MGW shifter • Aluminum shaft • FR500 steering wheel • Cobra Sidewinder seats • S351 spoiler • FMS CF knob • Saleen Front/Rear Bumpers • Black Saleens • 95 R Fuel Safe cell • Audi bi-xenon HIDs • Export tail lights. NOW I NEED A CHARGE!
COBRASVT is offline
