How to test your OSS (Output Shaft Sensor) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 02-15-2017, 05:54 PM Thread Starter
99-04 Mustangs have a reluctor-style OSS (Output Shaft Sensor) that tells the PCM the vehicle speed. Here is how to test your OSS:
Remove the OSS from your transmission. Connect the two pins of the OSS to an AC voltmeter. Find a piece of iron or steel (not stainless). Rapidly shake the OSS over the metal as fast and as close as you can and you should see about 1/3 to 1/2 of a volt on the AC voltmeter:
Mark Olson
96 Kenne Bell Cobra: See
for mods.
markolson is offline
post #2 of 5 Old 02-15-2017, 07:38 PM
indy2000's Avatar
frequency and amplitude need to be verified
need a scope and rotating shaft........
indy2000 is offline
post #3 of 5 Old 02-15-2017, 08:34 PM Thread Starter
I stand corrected.
You guys all need a scope and a rotating shaft with teeth or holes to properly test an OSS. And you need the amplitude specs for the sensors too.
Mark Olson
for mods.
post #4 of 5 Old 02-15-2017, 08:40 PM
indy2000's Avatar
Naw, ya don't
important sensor info is really just useless......
indy2000 is offline
post #5 of 5 Old 03-05-2017, 10:00 AM
shurur's Avatar
Thanks Mark..another great post.
1999 Mustang Cobra DD
shurur is offline
