License Light Replacement - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 05-24-2012, 05:05 PM Thread Starter
Tony@Latemodel's Avatar
1979-04 Mustang License Light Replacement
Whether you are trying to replace that burnt out license lens bulb, or just trying to show off the custom license plate, our L.E.D. license plate bulb will get the job done. Stock license plate bulbs typically melt down the bulb sockets because of the heat they produce so we will show you how to fix the bulb socket as well as replace those old bulbs.
Check out this detailed blog of the install on JMac's 03 Cobra.
Tony@Latemodel is offline
post #2 of 3 Old 05-29-2012, 12:49 PM
Mustang Matt's Avatar
Hey Tony,
Can you work on getting us some sort of replacement rubber for the black beauty corners? Mine split and cracked just after my 1 year warranty was up.
2005 CTS-V : 2009 CTS4
Mustang Matt is offline
post #3 of 3 Old 05-29-2012, 12:52 PM Thread Starter
Originally Posted by Mustang Matt View Post
Hey Tony,
unfortunately thats not a part we can get. although they do carry a 1 year warranty if they are defective within a reasonable time past that we will try and work with you on a replacement.
