#1 |
03/04 svt rotating assembly in teksid block
I have a complete mint 04 cobra rotating assembly that has 20,000 miles on it. I want to put it in a teksid block that only had 30,000 miles on it. would I be able to put the assembly right in? has anyone heard that the teksid blocks had a slight tapper to the bore and even if using std pistons should be bored straight?
| Sponsored Links | |
Advertisement |
#2 |
Get the block honed, new rings, and new bearings, the mains are different for the aluminum block.
__________________
Andrew Barrale -Qickest 4.6 F1 car in the country! best 1/8 mile 5.18@138 best 1/4 mile 8.08@171 4v F1R NMRA D/R trim. Thank you, Procharger, American Racing Headers, UPR(1.25 60 ft), TCI, TA Performance, Fox Lake, Oliver, Ford Racing and Injection Connection. |
#3 |
thanks
I figured that 98 cobra main bearings would work. I'm mostly concerned about the bore being off. I think I read somewhere that its .002 smaller towards the bottom for some reason. I should be set if I get the block hot tanked and honed. |
#4 |
Trader Feedback: (33)
Measure the piston diameter and the bore diameter. Determine the piston to wall clearance and go from there.
__________________
2005 F250 Super Duty Harley Davidson True Blue 1997 SVT Cobra Pacific Green 1995 5.0 GT Dark Forest Green If you aren't living on the edge, you're takin' up too much space! |
#5 |
authorized corral.net advertisers
Trader Feedback: (56)
There is no taper present in the teksid block but when measured without a torque plate they can show .005 to .001 taper from top to bottom, this is more apparent in aluminum blocks but you will measure it in all blocks that have been properly machined.
Good luck with your project, let us know how we can help! MMR 1-877-MOD-POWR
__________________
www.modularmotorsportsracing.com 1-877-MOD-POWR Precision Engineered Modular Engines and Components, WORLDS FASTEST NON-TUBE CHASSIS MODULAR 6.99@205.4, WORLDS FASTEST MODULAR PERIOD 6.08 @ 241.7, WORLDS FASTEST 5.0 COYOTE 7.02 @ 202,5 speed Record holder-8.99@154 ![]() RANKED TOP TEN MUSTANGS OF 2011 by MM&FF Magazine |
#8 | |
#9 | |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
