DPFE sensor replacement, anyone done this? - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > Modular Tech Forums > SVT & DOHC
Old 10-13-2009, 09:32 PM   #1
DarkMesa8's Avatar
I'm trying to buy a replacement DPFE sensor, but both autozone and advance auto parts are stocking something completely different than what's on my 01 Cobra.
Had anyone replaced this? I know they went from aluminum to plastic, but the one on my car is already plastic, and the plug is completely different than the one I was given. I could make the vacuum lines work, but I don't know what to do about the plugs.
__________________
1991 Grey Mustang LX Hatch
1995 Jeep Grand Cherokee Limited V8 4x4
1994 Suzuki GSX750F Katana
Honk if Parts Fall Off
JasonWeg@comcast.net
http://home.comcast.net/~jasonweg/index.htm
DarkMesa8 is offline
Old 10-13-2009, 10:09 PM   #2
Try egr valve pressure sensor. I am at work. Typed in dpfe for a 01 cobra and found the part. Its plastic and looks like the original piece.
__________________
2002 GT 4V swapped 468hp/511tq
2008 G8 GT Stock
2001 Pontiac Grand Am GT...Baby Hauler
CamFox is online now
Old 10-13-2009, 10:10 PM   #3
ModularSpeed's Avatar
Hmmm....
Surely someone can hook you up with one?
If it were me, I would just delete the EGR and be done with it.
__________________
STOCK4V
n/a 345rwhp
ModularSpeed is offline
Old 10-13-2009, 10:19 PM   #4
TARZAN's Avatar
Can you get a pic of the one on the vehicle? I can tell you what part # you need.
But yeah, I'd just delete the EGR...
-Will
__________________
The internet is just a fad
TARZAN is offline
Old 10-14-2009, 09:41 AM   #5
DarkMesa8's Avatar
In the yellow circle, notice that there's a single rubber boot for both vacuum lines.
Two prong, squarish plug.
This is straight off of the Advance Auto Parts website. That's what was in the box. Same for autozone.
__________________
Old 10-14-2009, 10:51 AM   #6
blackbob's Avatar
I used one off a 96 GT and works on the 99' Cobra with no problems. The part you have pictured goes on the back of the intake and has two 7mm I think it is holding it on. That's the DPFE like autozone has pictured and what you have pictured off your car is the EGR vacuum regulator I want to say. They are giving you the right part you're just asking for the wrong thing or not sure what you're looking for.
__________________
05' GTO - M6 Impulse Blue/Blue
sosmotorsports.com
blackbob is offline
Old 10-14-2009, 10:58 AM   #7
DarkMesa8's Avatar
A used DPFE, or did you have the parts store search for a 96 gt and you got one that fits?
I'm trying to get a new sensor.
__________________
Old 10-14-2009, 11:00 AM   #8
yeah thats not the dpfe. the 2nd part you pictured from the website is the DPFE. thats what the one looks like at autozone.
__________________
2008 G8 GT Stock
Old 10-14-2009, 11:23 AM   #9
DarkMesa8's Avatar
Where is the DPFE than?
This sensor has a vacuum line running from the upper intake into it, and than from it straight to the top of the EGR valve.
I can't imagine what else it could be.
__________________
Old 10-14-2009, 11:59 AM   #10
TARZAN's Avatar
It is an EGR Vaccuum Solenoid, it'll be part number EVS58 at your local AutoZone.
-Will
__________________
TARZAN is offline
Old 10-14-2009, 12:16 PM   #11
DarkMesa8's Avatar
Oh, woops!
Than where is the DPFE?
__________________
Old 10-14-2009, 01:27 PM   #12
TARZAN's Avatar
What is your issue? Why do you think you need to replace a DPFE?
-Will
__________________
TARZAN is offline
Old 10-14-2009, 01:32 PM   #13
DarkMesa8's Avatar
Stalling when coming to a stop. Cleaned the IAC and throttle body and MAF. Several over on SVTPerformance said that when they got to theirs out, water from condensation dripped out of the sensor.
So where is it?
__________________
Old 10-14-2009, 01:43 PM   #14
BraMas's Avatar
Follow the 2 smaller vacuum lines that are connected to the EGR piping to the back side of your intake and you should see it
__________________
96 GT w/ 4V Swap,IRS Swap,4.30's,Pro Chamber and Magnaflows ,H&R Race,
BraMas is online now
Old 10-14-2009, 01:56 PM   #15
DarkMesa8's Avatar
LoL, as soon as I opened the hood I saw it. I think I spent 5 minutes searching the firewall for it earlier.
SOB!
Thanks!
Edit: And its even in one of my pictures.
__________________
Old 10-14-2009, 06:11 PM   #16
TARZAN's Avatar
SOB!
Thanks!
Sorry, I knew where it was...I was just trying to address your reason for replacing, and the part type/number of the solenoid.
Being on the firewall a lot of people actually mistake it for the MAP.
-Will
__________________
TARZAN is offline
Old 10-14-2009, 09:32 PM   #17
wow, never heard of one going bad.
weird.
Let us know what happens!
__________________
STOCK4V
n/a 345rwhp
Old 10-14-2009, 09:48 PM   #18
TARZAN's Avatar
weird.
Stock DPFE's are actually pretty notorious for going bad.
-Will
__________________
TARZAN is offline
Old 10-15-2009, 11:18 AM   #19
blackbob's Avatar
I'm glad I have a metal one then..woo !
__________________
sosmotorsports.com
blackbob is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
