people with GT40X heads and any kind of supercharger.... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 02-01-2007, 01:53 AM Thread Starter
out of curiousity what kind of number you put down. i am looking at either centri. or KB. open to all suggestions. car is a week end car, will go to the track a couple of times to see what it runs, but never any kind of actual racing. just fun on the street (not street racing either)
95 5.0 swapped from 3.8 Project car 9/11/99 to 09/03/07 SOLD!
99 323is BMW is now my daily driver.
blake95 is offline
post #2 of 10 Old 02-01-2007, 12:03 PM
sukkoi18's Avatar
Trader Feedback: (23)
You can pretty easily get 500 rwhp with those heads and a Centrifugal. I don't know with a Kenne Bell.
~Performance White 2013 GT M6
sukkoi18 is offline
post #3 of 10 Old 02-04-2007, 09:06 AM
8urzo6's Avatar
I have 331 gt-40x heads and a procharger p1sc making 9lbs. I made 461hp and 484tq at the wheels.
8urzo6 is offline
post #4 of 10 Old 02-05-2007, 04:51 PM
rwm0418's Avatar
Trader Feedback: (47)
im finishing up a supercharger install now with those heads an ecam and edelbrock performer intakes yadayada. Car runs quite well now.
rwm0418 is offline
post #5 of 10 Old 02-05-2007, 08:57 PM
rob
rob's Avatar
on my second set. 1st with a vortech 10psi made 460/430 through 5spd.
current setup in 3400lb mustang, car made 375/350 through aod and ran 11.3@122. motor now has a hellion turbo kit in a fairmont.
heads are turds na, but make good power with a vortech.
1982 Ford Fairmont Futura H/C/I, fuel injected and turbocharged 10.67@128
rob is offline
post #6 of 10 Old 02-05-2007, 10:13 PM
NC STANG GUY's Avatar
Trader Feedback: (174)
I have old Y303 GT40 alums on my 89 LX vert. Opened up the exhaust and didnt do much to the intake side. Made 521rwhp/464tq with 10.5 psi from a SC trim Votech(stock bottom end) Ran a 11.38@125mph @3400+lbs with driver before I snapped a stock axle.
85 LTD SSP 383 Windsor/Vortech T trim 10.51@ 131 first time out
90 LX coupe 427ci/Vortech T trim @8 psi. 726rwhp/625 rwtq
93 LX hatch 351/Vortech in.. well... some year..
NC STANG GUY is offline
post #7 of 10 Old 02-06-2007, 08:11 AM
avbcon12's Avatar
Trader Feedback: (26)
have anymore specs on your motor? im using y heads that are heavily ported throughout (still dont know what they flow) and am trying to figure a ballpark area of what i make... ive been trying to make it to the dyno for about a year but things come up and now its lke -12* outside without windchill....
thanks,
adam
90 GT black, V2 SI-Trim, Blow-Thru A/A Intercooler
stage 3 "Y" heads/ Bennett Racing intake, TFS#1, long tubes, 3"Pro-Dumps/H-pipe, TKO500, 3.55's, Home made TA and PHB, cobra brakes, 22 gallon Fuel Safe Cell, PMS tuned etc.. built for twisties
avbcon12 is offline
post #8 of 10 Old 02-06-2007, 10:43 PM
thanks,
adam
It's your old SC trim (with 7" crank and 3.15 pulleys) Stock bottom end with 76K miles,ported GT40Y303's,Lunati 51014 cam (.530/.540 with 1.7 rockers,218/226 @.050,112 lobe),unported Holley Systemax intake,SCT 2400 MAF,70mm Holley TB,60lb injectors,1 5/8 MAC long tubes,2 1/2" X pipe,Pypes violator cat back in 2 1/2",GSS340 Walbro hi pressure intank pump. Going to install a GL392 Walbro inline pump and stick a 2.85 pulley on it when I get it back from being painted. Yeah it's going to crack the stock block but I'd like to see 575rwhp before it does.
post #9 of 10 Old 02-07-2007, 09:09 AM
avbcon12's Avatar
haha, thats right!! ive got the v-2 now, didnt like the attention at idle with the loud whine.
you have a little more aggressive cam than me but we essentially have the same combo, pretty promising if you ask me. Id like to be about 575 when im done with it too. with a safe tune, driven well, and hope, the stock block could last a little while. then comes the dart.
adam
avbcon12 is offline
post #10 of 10 Old 02-07-2007, 07:18 PM
CT93's Avatar
i have x303's on my car. No times or numbers but it pulls pretty hard. I figure these heads and an s trim will most likely make enough power to split a stock block
93 gt- H/C/I,TKO/spec 3, s trim, spool/33 spline axles, pms, aem WB02
CT93 is offline
