Dull Pop Sound Comeing from area of Passenger Side Header - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 04-12-2006, 10:37 AM Thread Starter
I just completed the entire install of my 9 PSI Powerdyne BD11. For starters the car has been off the road for 5 months with the battery disconected. I started the car up and it idled a little rough for a few min then things started to get smooth out when everything started to warm up. I did a few quick 1/4 thorttle revs to about 2500-3000 RPM in neautral and after the Rpm starts to come down I hear this dull but noticeable POP come from the area of the passenger side header. The car maintains idle after being reved and it dosn't stall out. My fuel pressure is currently set to about 36 PSI accoring to my Autometer Electric F/P gage and Timeing is at roughly 14-15*. Could this pop be from a lean condition or is something wrong internally. The engine is practially brand new, it has about 2000 miles on it since being installed last summer.
1993 Mustang GT
306 9.0:1 Compression, Cryo treated crank/rods block,cam,valves. GT40 Y303 Heads.Comp Cams 270H-R14 .533"/.544" lift 215*/220* duration 114* LSA. Ported Cobra Upper/Lower Intake, 70mm T-Body, 73mm C&L MAF, 24lb/hr injectors, 155 lph pump, Kenne Bell BAP, Powerdyne BD11 9PSI, Anderson PMS, Innovate LM1 Wideband 02, Jacobs 5.0 Ignition, MSD BTM, FRPP 1 5/8" Dia Shorty Headers, BBK X-Pipe 2.5" w/cats, Flowmaster Catback, Tremec TKO-600, Alum driveshaft 3:55 gears, FRPP/HPM Controll arms, KYB Shocks/Struts.
1993-306-GT is offline
post #2 of 5 Old 04-12-2006, 11:55 AM Thread Starter
TTTTTT
1993 Mustang GT
post #3 of 5 Old 04-12-2006, 11:00 PM
avbcon12's Avatar
Trader Feedback: (26)
u sure the rockers are adjusted properly? exhaust leak?
adam
90 GT black, V2 SI-Trim, Blow-Thru A/A Intercooler
stage 3 "Y" heads/ Bennett Racing intake, TFS#1, long tubes, 3"Pro-Dumps/H-pipe, TKO500, 3.55's, Home made TA and PHB, cobra brakes, 22 gallon Fuel Safe Cell, PMS tuned etc.. built for twisties
avbcon12 is offline
post #4 of 5 Old 04-13-2006, 12:30 AM
filthy1's Avatar
Could be your heater core under the dash. Mine did the same thing just ONE big loud pop. Look for antifreeze on the floorboard and near the back of the passenger header coming out of the firewall. just my .02
1995 GT Vert - Ported Trick flow heads, ported track heat intake, cam, longtubes, etc. It's slow.
2002 GT Coupe - Sold
XBOX 360 - SCUZEME32
filthy1 is offline
post #5 of 5 Old 04-13-2006, 08:00 AM
Sounds very much like a lean-pop condition. Pretty common with blown set-ups. Have you considered up-sizing your injectors? I would definately recommend doing so!
SC50 is offline
