My 93 Cobra heads seem to be lifting a bit under boost @ high RPM ( says the dyno tuner), so this is a good excuse to do heads, gaskets and ARP bolts or studs. Since this seems to be a very common and successful combo and I have no experience with fox heads, I'm looking for what part #'s I should add to my S-Trim'd Cobra.
Looking for part #'s on:
bolts or studs that work on these heads
Gaskets for boost that work with these heads
anything else to avoid future fitament issues.
Thank you. I gotta start saving for them and find a shop to do it as I don't have the time to do the install myself. Plus I got a bad back from surgery last year
I think he just put the B303 he has in it ... I know they aren't optimal boost cams but I think ctozzi wanted a little lope. Hardened push rods are good advice.
I'd run felpro pt9333 headgaskets over the cometics unless the block has been resurfaced..
Related Threads
Ford Mustang Forums
9.8M posts
200.6K members
Since 2001
