What spark plugs should I use?? - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > Power Adder Forums > Superchargers
Gallery Corral Parts Store Videos Advertising Info Blogs Outside the Fence Corral Home
Old 07-21-2012, 04:36 PM   #1
Bonez8791's Avatar
Im needing a little advise as to which spark plugs I should use? Im running holley systemax heads with a vortech V1 S Trim with around 13lbs of boost. Any help is greatly appreciated.
__________________
91GT, 347, Holley Systemax Heads and Intake, 1.6 RR's, Custom Cam, MSD, Vortech V1 S-Trim 12 PSI, Full Aeromotive, PA SuperComp C4 w/ Brake, Edge Racing 9.5" Pro Series Converter, Pro Stars, M/T Drag Radials.
Bonez8791 is offline
Old 07-21-2012, 09:36 PM   #2
Trader Feedback: (44)
Autolite 3923's or 4's. I kinda like the 24's for the street & 23's for the track. I've found that the 23's were too cold of a plug for street driving(Too low RPM's & they fouled out in short order)!!! Some folks have good luck w/the 23's though!!
midnightrider is offline
Old 07-21-2012, 09:54 PM   #3
Bonez8791's Avatar
Ok, Are those plugs I can get at a local Advance Auto or Napa? Or will I have to order them?
__________________
Old 07-22-2012, 02:07 PM   #4
About ANY local parts store.. I just installed 8 of them. Cost from AZ was appx $19...
Old 07-22-2012, 02:13 PM   #5
Bonez8791's Avatar
Ok awesome, Ill try to pick some up today. Are there different variations of this plug? Copper Core, Platinum, Double Platinum? If so which one do I want?
__________________
Old 07-22-2012, 05:03 PM   #6
GMundertaker's Avatar
Trader Feedback: (45)
NGKs
I'm running NGKs and I like them so far. I've been using them for quite some time. Next time I come by I can give you 1 so you'll have the part # if you are interested? no biggie, I wouldn't discourage you from running autolites. I have been buying NGKs at advance.
Matt
__________________
91 GT Vert HCI + SC trim w/Mr.Freeze TSI AOD Non-lockup 3800 stall 3.55s 3600lb race weight Tuned By Mike Post of DynotuneMP.com Best run to date: 7.09 Goal is 6.9s!
GMundertaker is offline
Old 07-22-2012, 07:11 PM   #7
VORTECD's Avatar
Autolite copper core
__________________
'13 GT auto
VORTECD is online now
Old 07-23-2012, 05:33 PM   #8
Bonez8791's Avatar
What are you guys gapping them at?
__________________
Old 07-23-2012, 05:57 PM   #9
VORTECD's Avatar
I wouldn't go over .030.
__________________
'13 GT auto
Old 07-23-2012, 06:21 PM   #10
boostdcoupe's Avatar
Matt
x's 2... bob k suggested them and ive never had a problem since.
__________________
everything is changing...
93 Coupe 347, twisted wedge, NX282, SMXII...
82 GT Stock w/ Isky Hyd Roller, RPM, Dbl Pmper...
95 F-150 powerstroke, yes... its a halfton smoker!
boostdcoupe is online now
Old 07-23-2012, 09:42 PM   #11
NGK #s
The ones I am running in my trick flow heads are Advanced Auto's SKU#20650564 NGK # 6364 On the porcelain they are marked BKR6ES NGK R in blue letters....
Matt
__________________
Old 07-23-2012, 10:02 PM   #12
Matt
this is what bob told me, i got them at advance too...
NGK-R5671A-7... gap em at .025-.027
__________________
Old 07-23-2012, 10:08 PM   #13
Bonez8791's Avatar
Well I ended up picking up some Autolite 3924's today, ive always been a fan of autolites so I went with those. Would you gap them the same way?
__________________
Old 07-23-2012, 10:13 PM   #14
yes... no more than .030
__________________
Old 07-23-2012, 10:14 PM   #15
Bonez8791's Avatar
Ok, thanks for the info.
__________________
Old 07-24-2012, 07:19 AM   #16
millhouse's Avatar
That's why you are supposed to use a recessed tip racing plug. It will allow you to run a hotter plug (with a bigger gap) with a much lower risk of fouling (or spark blowout for that matter). Any time you have a higher compression (or forced induction) engine, the need for recessed tip racing plugs becomes quite apparent. Yes, you can "get away" with your typical projected tip autolite, but that doesn't mean it's going to be best suited for your application.
FYI, autolite sells recessed tip racing plugs as well.
__________________
1997 Rio Red Cobra Vert
Gone but not forgotten, 1989 TT notch...
Best 1/4: 11.35 @ 125.84mph (1.77 60') 489rwhp/527rwtq
millhouse is offline
Old 07-24-2012, 07:53 AM   #17
Bonez8791's Avatar
What is the part number for these plugs?
__________________
Old 07-24-2012, 01:03 PM   #18
millhouse's Avatar
Assuming the threads are the same as the other aftermarket aluminum heads...see below. It's worth noting that you can typically run one step hotter than normal with the recessed tip plugs (if you planned on running 2 colder, you can likely go with 1).
Per... Spark Plug FAQ.
Aftermarket aluminum heads (TFS, Edelbrock, AFR, Canfield, Brodix)
NGK Forced Induction
R5671-A8 Stock Number 4554, 1 heat range Colder (up to about 600rwhp)
R5671–A9 Stock Number 5238, for 18+psi, 2 heat ranges colder 650+ rwhp
R5671–A10 Stock Number 5820, for race cars.
Autolite Forced Induction and N/A
Autolite 3924's Naturally Aspirated Only
Autolite 3923’s 1 Heat Range Colder, good for approx 550rwhp
Autolite 3922’s 2 Heat Ranges Colder, good for approx 650rwhp
Autolie Race Series for aftermarket heads
Autolite AR3935 Naturally Aspirated Only
Autolite AR3934 1 Heat Range Colder
Autolite AR3933 2 Heat Ranges Colder
Old 07-24-2012, 05:00 PM   #19
Authorized Corral.Net Advertiser
Michael Plummer's Avatar
Trader Feedback: (66)
Hi Millhouse,
I thought a recessed plug was for racing application with a lot of boost and in street car applications they tend to foul easier than a projected tip spark plug. If anyone has problems with the flame being blown out get a better ignition system and a really good coil.
__________________
94 Mustang Faleen
ProCharger D1 and Water/Methanol Injected
839rwhp and 771rwtq SAE
www.mplummerperformance.com
Michael Plummer is offline
Old 07-24-2012, 09:14 PM   #20
millhouse's Avatar
Originally Posted by Michael Plummer View Post
Hi Millhouse,
A recessed plug typically is beneficial in any application with extreme cylinder pressures, be it from a high compression n/a engine or forced induction. Because less of the tip is exposed to the chamber, the risk of pre-detonation is significantly reduced. This will allow you to run a hotter spark plug which in turn will allow carbon to more easily burn off. Speaking of carbon, because less plug is exposed, carbon will have a more difficult time accumulating on the porcelain.
Keep in mind, most people are running around with plugs 1-2 ranges colder than necessary when running even mild f/i applications. That's all fine and dandy when running down the 1/4 mile, but stoplight to stoplight those plugs are going to get carbon'd up. No amount of ignition upgrades is going to keep this from occurring, you simply need a hotter plug for the street and a colder one for the strip (or a recessed tip plug).
The final added benefit of course is pulling the spark out of the wind so to speak. While ignition upgrades typically will reduce or eliminate spark blowout, so will a $16 set of sparkplugs. You also get the added benefit of the above mentioned points.
Old 07-24-2012, 09:42 PM   #21
Millhouse,
Thanks for the information but it differs from what I was told by Autolite techs and what was posted by Brandon (see below).
Posted by Brandon Peeler
Technical Support Representative
Aftermarket Division
NGK Spark Plugs (U.S.A.)
The theory is that typically for street driven applications a projected insulator will be beneficial as it positions the spark farther into the combustion chamber promoting better ignitiability as it will be closer to the densest part of the mixture. at low speeds it also helps keep the firing end of the plug hotter preventing fouling. This is helpful in high power cars that run very cold plugs on the street. Also as the intake valve opens and the fuel charge rushes in the plug has a greater area being exposed so as to cool down more.
The only downside is that by putting the plug into a higher turbulence area you may also raise the required voltage needed to fire the plug. In very high boost cars this can lead to misfire (spark blowout), especailly with a weak stock type ignition system or over heating of the ground electrode at high rpms (because the ground path is longer), especailly with a weak stock type ignition system. This can sometimes be helped by switching to a fine wire type iriidum plug which reduces that voltage requirement back down and also lowering the plug gaps.
I have also heard from drag racers on a couple applications that they were able to run a non-projected plug and add in a degreee or two of spark timing and pick up some substantial horsepower increases.
So really I would say if it is a street driven vehicle try to run a projected plug. If it is a all out race car you may benefit from a non projected type plug (or if running nitrous). Of course this rule is not always valid as cylinder head turbulence, quench area, etc can sometimes change this recommendation.
__________________
94 Mustang Faleen
Old 07-25-2012, 12:26 AM   #22
So.....which is it? Some valid points pointing in both directions. 3924's for some time now and they seem to work, however I am not opposed to other options.
EDIT: 3923's for some time, trouble free.....sorry.
__________________
1992 Notch...with some stuff, of Irish descent.
Whitexc is offline
Old 07-25-2012, 07:41 AM   #23
millhouse's Avatar
Michael,
It’s tough to argue with most of his points, as he is spot on (for most applications). I know from first-hand experience (as well as experience of many others) that suggest otherwise for the typical F/I mustang application.
The issue that we have for our applications is that our optimum, day to day heat range and WOT, down the drag strip heat range differ quite a bit. What is the first thing most people are told when selecting a spark plug for their newly F/I setup on their mustang? Pick a plug that is 1-2 steps colder (for mild setups). What is a main contributor to fouling of the spark plug? You got it, too cold of a plug for any given application. Combine that with the fact that quite a few of us run a bit safe (read, overly rich) tunes….or no tunes at all (possibly pig rich), and fouling is a real concern. While a protruded electrode most certainly has a better opportunity to burn off excess carbon, it also will accumulate more carbon. This is especially true on a colder plug that does not get hot enough. The carbon will begin to accumulate and viola…a fouled plug be the result.
This is precisely what was happening to me, as I needed a projected tip plug that was 2-steps colder than normal. A set of normal, projected tip plugs would last a few months (on a good tune mind you) before I would begin to notice excess accumulation of carbon on the ceramic. Switching to a racing plug drastically reduced/eliminated this behavior as I ran a hotter plug and what little carbon accumulated was burned off. I haven’t even mentioned yet that because a recessed tip plug is…well, recessed, that it is far less prone to fouling in the first place.
Of course, the spark break-up is what this post was all about…which is precisely what the recessed tip plug will prevent without having to invest any more $$$ into an upgraded ignition. Obviously, an upgraded ignition is the way to go in the long run, that won’t however negate the need for a recessed tip plug for many of us.
Again, I’m not disagreeing with his points…simply stating that many of our applications differ drastically.
Old 07-25-2012, 05:03 PM   #24
Millhouse,
I respect and can agree with some of your points but we' will have to agree to disagree on whether a recessed spark plug is more prone to fouling. I believe it is when its in a daily driver with no issues going on inside combustion chamber.
I agree that a recessed tip spark plug will help with spark break up but if anyone is running an aftermarket igintion system and they aren't running the best coil for their particular ignition and setup then shame on them if there still experiencing spark break up.
When you see someone closing up their gap because of engine break up its because they have a less powerful ignition. Less powerful ignitions will require a smaller gap whereas more powerful ignitions will allow you to utilize a larger gap.
Myself and customers I work with use spark plug gaps between .030-.035 when they have a capacitive discharge type of ignition like a MSD. Care must be taken as to listen to what your engine is telling you. For example, too much spark plug gap can result in misfires and hard starting issues and too little gap can result in a loss of power.
Bottom line, experiment on your setup and find what works best for you.
__________________
94 Mustang Faleen
Old 07-26-2012, 06:28 AM   #25
millhouse's Avatar
Fair enough.
Millhouse,
I respect and can agree with some of your points but we' will have to agree to disagree on whether a recessed spark plug is more prone to detonation. I believe it is when its in a daily driver with no issues going on inside combustion chamber.
Old 07-27-2012, 04:19 PM   #26
blownholley50's Avatar
NGK-R5671A-7 here-- dig6 gapped at .025, w dig 7 they are gapped .028
__________________
WestTexasMeanStreet-5.53/1.27/126.4@3700'DA 5.58@5275' https://www.facebook.com/groups/WTMS275/
93 LX Hatch 275DR ,YSI, 363, Freezy, XFI, Baseline
Harlow Sammons,Southwest Perf. & Machine,
http://www.youtube.com/user/blownholley50?feature=mhee
blownholley50 is offline
Old 07-27-2012, 04:37 PM   #27
Bonez8791's Avatar
Do you drive yours on the street as well? Mine will be for both street and strip and I'm using a 6AL. With those work for me?
__________________
Old 07-28-2012, 01:27 AM   #28
Mercedez L.'s Avatar
Question
Why Autolite copper core when we have all of these other kinds of plugs in platnum or iridium?
Mercedez L. is offline
Old 07-28-2012, 02:30 AM   #29
blwn89hatch's Avatar
I was told platinums and boost is a big no no when i first put the blower on my back on 09.
blwn89hatch is offline
Old 07-28-2012, 02:34 AM   #30
Question
Is copper a better conductor of electricity?
Old 07-28-2012, 06:53 AM   #31
Im kind of surprised some of you are running the ngk 6's. I ran them for a while but came to the conclusion its bad advice. according to NOS you should run a 7 or colder(8,9,10). I cant see a blown combo liking a warmer plug than nitrous??
I could be wrong but Im pretty sure 3924 converts to ngk 7 and 3923 is ngk 8 and 3922 is ngk 9. iirc ngk 6 converts to 3925 which is stock heat range for na use with cast iron heads?
someone correct me if Im wrong
slow87GT is online now
Old 07-28-2012, 07:00 AM   #32
this has been pretty much my findings
now can someone explain why Id want a hotter plug in a boosted app? It doesnt make any sense to me?
Old 07-28-2012, 11:09 AM   #33
So ultimately what would be the difference from an autolite 3923 and an autolite 3934 race plug if they are both 1 heat range cooler?
Old 07-28-2012, 12:36 PM   #34
Sickfox's Avatar
This is the same plug I run, even gapped the same. Run 22 + psi, MSD-6, Mallory coil, 50%\50% race and street, 100% alky injection. Plugs are changed annually and look mint.
Sickfox is offline
Old 07-28-2012, 01:43 PM   #35
Bonez8791's Avatar
Awesome. I think I'll pick some of these up. The ones I just bought are for N/A so they need to be replaced. Thanks for the info.
__________________
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
