Cobra Eaton on 5.0 - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > Power Adder Forums > Superchargers
Gallery Corral Parts Store Videos Advertising Info Blogs Outside the Fence Corral Home
Old 09-10-2010, 09:28 PM   #1
joeystang's Avatar
Cobra Eaton on 5.0
So I thought it was about time to start my own thread on this and stop posting onto other peoples threads. So I started this project about 6 months ago with the Thunderbird M90 supercharger and then decided to upgrade to the M112. So here is a few picks and a video on it, there is more on my Photobucket "joeyfocus" if your interested in looking around as well as many pics of my other projects. Also I am making several more of these for sale at various different prices depending on what you are interested in. I also do custom CAD designs. If your interested just ask me.
Video link: http://www.youtube.com/watch?v=GLbKRCupkh8
__________________
91 LX 5.0 HO, Custom intake adaptor by JDB Modifications to top mount or side-mount Eaton m112 or m122 supercharger.
Owner of JDB Modifications
www.jdbmods.com
Jbraswell1987@hotmail.com
joeystang is offline
Old 09-10-2010, 09:38 PM   #2
indy2000's Avatar
design a laminova air to water intercooler for fox kenne bell screws.......you'll make some serious money.
__________________
indy2000 is offline
Old 09-11-2010, 05:43 PM   #3
funny you mention those cores as i was going to use them on my a2w setup for my kb. but after shawn(92rohcp) reworked mike's a2a setup i went this route too. those cores are pretty nice though.
__________________
1990 LINCOLN MARK VII SE
OLD COMBO- STOCK 302 WITH 1500 KB ON TOP.
IN THE WORKS- D.S.S. 331, AFR 185'S(FULLY WORKED OVER), EXTRUDE HONE GT40 LOWER, 2200 KB, 75MM TB AND SPACER, 4IN AFM POWER PIPE, 80 MM MAF, FRPP 1 5/8 UNEQUAL LENGTH HEADERS, MAGNAFLOW X PIPE, MAGNAFLOW MUFFLERS, CUSTOM 2 1/2 EXHAUST ALL THE BACK FROM X PIPE TO TAILS, MSD ELCTRONICS, AND AEROMOTIVE SYSTEM.
http://www.cardomain.com/ride/2063731
mark007 is offline
Old 09-11-2010, 07:56 PM   #4
joeystang's Avatar
Its weird that ya'll are talking about the laminova coolers, I just learned of these things a few weeks ago and have been trying to get my hands on some of them to see if I could work on integrating them into my setup and maybe the KB too.
__________________
www.jdbmods.com
Old 09-11-2010, 08:48 PM   #5
steel1's Avatar
Trader Feedback: (29)
Nice fab work, how does that s/c compare to a paxton/vortech set-up. I would imagine it doesn't need high rpm to make boost. How much boost are you making? What will you do for a hood/scoop set-up, hieght seems to be an issue.
steel1 is offline
Old 09-11-2010, 09:15 PM   #6
joeystang's Avatar
I'm not sure how if compares to the Paxton/Vortechs because I have never worked with them. But it makes about 14PSI on a 2" pulley and the stock crank pulley. Hight isn't too big of an issue, it fits under a 2.5" cowler hood with just a slight bit of modification. (see picture below)
__________________
www.jdbmods.com
Old 09-15-2010, 09:17 PM   #7
joeystang's Avatar
Here is just a few higher quality pictures of the supercharger on my stang.
__________________
www.jdbmods.com
Old 09-15-2010, 09:47 PM   #8
StarrMan's Avatar
Have you ran the A/C on that setup yet? Doesn't look like there's much belt wrap on the compressor pulley...lol
StarrMan is offline
Old 09-15-2010, 11:51 PM   #9
joeystang's Avatar
Yeah, it works fine cruising and at idle, just slips a little when you get on it.
__________________
www.jdbmods.com
Old 10-04-2010, 07:54 PM   #10
joeystang's Avatar
So I put a few more of these together if anybody is interested in buying.
__________________
www.jdbmods.com
Old 10-04-2010, 10:46 PM   #11
Trader Feedback: (144)
Robertsdale eh? Bring it to Pcola, to XXX and put that sucker on the dyno!
__________________
00 Expedition, 5.4, 4R100, 3.73's
NEXT?
95 GT, B50 331-S Trim-D&D T56 SOLD
02 Z06, 402-TFS 225's-257/264 Cam-FAST 102-552 RWHP SOLD
Speeds8erM-1 is offline
Old 10-04-2010, 11:05 PM   #12
joeystang's Avatar
I will gladly when I get it back together, I cracked the block.
__________________
www.jdbmods.com
Old 10-04-2010, 11:17 PM   #13
Wingman302's Avatar
what shaft did you use on the snout? i see its longer.
Wingman302 is offline
Old 10-04-2010, 11:39 PM   #14
joeystang's Avatar
I made about a 5" long shaft that presses onto the stock shaft where the pulley would normally go.
__________________
www.jdbmods.com
Old 10-10-2010, 10:59 PM   #15
joeystang's Avatar
So I'm starting to break down my motor finally, and here is a pic of one of the head gaskets, this is the passenger side. It was the worst but the driver's side was blown too, 7 of 8 cyl were compromised.
__________________
www.jdbmods.com
Old 10-14-2010, 04:03 PM   #16
1992Hatch's Avatar
Thats pretty sick!! exactly how i thought something like that should be made!!
__________________
2007 Ford Escape XLT - DD
1992 Mustang LX - Weekend toy
4cyl to 5.0 - auto to 5 speed - 4 lug to 5 lug with 18" FR500's - BBK shorty headers, BBK catted X pipe, MAC flowpaths with Flowmaster 3" tailpipes
1992Hatch is offline
Old 10-14-2010, 06:40 PM   #17
joeystang's Avatar
Thanks for the look,
__________________
www.jdbmods.com
Old 10-14-2010, 08:41 PM   #18
boostdcoupe's Avatar
Trader Feedback: (15)
now THATS the way to blow a head gasket! bravo! time for some machine work and MLS gaskets???
__________________
everything is changing...
93 Coupe 347, twisted wedge, NX282, SMXII, 73 jet in the wet kit...
82 GT Stock w/ Isky Hyd Roller, RPM, Dbl Pmper...
95 F-150 powerstroke, yes... its a halfton smoker!
boostdcoupe is offline
Old 10-14-2010, 08:54 PM   #19
joeystang's Avatar
Lol thanks, I have been debating about what gaskets to go back with.
__________________
www.jdbmods.com
Old 10-15-2010, 12:26 AM   #20
indy2000's Avatar
that's good advice, to break a piston.
__________________
indy2000 is offline
Old 10-15-2010, 05:46 AM   #21
eliminate the weak links, right?
__________________
Old 10-15-2010, 10:56 PM   #22
joeystang's Avatar
Yeah already found out the head gaskets and block can't handle it.
__________________
www.jdbmods.com
Old 10-17-2010, 05:22 PM   #23
Stangaddiction's Avatar
Does your adapter work with any lower intake?
__________________
1988 LX Hatchback
331 Stroker - TKO 600
Too much to list......
Stangaddiction is offline
Old 10-17-2010, 05:48 PM   #24
joeystang's Avatar
I can make one to fit any lower intake.
__________________
www.jdbmods.com
Old 10-17-2010, 06:11 PM   #25
Other than the adapter plate what else is needs to be modified to make the set up work? How much boost were you getting with the m90... I'd only be looking to boost my motor 5-7lbs with some meth probably... lastly how much are you getting for a custom bracket? Thanks!
__________________
1988 LX Hatchback
Old 10-17-2010, 06:48 PM   #26
joeystang's Avatar
Nothing to be modified, just some different routing of the vacuum line to be ok for boost. The m90 was maxing out between 6-8PSI. I sell the M112 in several ways. Follow this thread to find out more:
Custom Eaton M112 Supercharger Kit for 5.0
I only sell the M90 kit without the supercharger, its $550 for the adapter.
__________________
www.jdbmods.com
Old 12-08-2010, 08:57 AM   #27
raysmust's Avatar
Trader Feedback: (30)
Do you have any good pictures of the belt routing? I am trying to see if I can make this work on my car. I am not running power steering or A/C on mine.
This might not be the right place but you mention in your for sale thread that you could sell a kit with the front bearing support and idler. Could you PM me a price with those pieces added in? I think I will need an idler or maybe two to do this without A/C and power steering.
Thanks, Ray
raysmust is offline
Old 12-08-2010, 08:45 PM   #28
redlightningssf's Avatar
Your set up looks very similar to the one I made for my Lightning, having more width an height I was able to put a Cobra/Lightning style IC in the adaptor.Custom water 2 Air IC adaptor
__________________
93 Lightning 427W
redlightningssf is offline
Old 12-08-2010, 08:55 PM   #29
ReplayMan's Avatar
Nice work
__________________
1991 Triple Black LX Vert.
Build Blog: http://replayman.wordpress.com
Latest upgrade: IRS Install
ReplayMan is offline
Old 12-08-2010, 09:11 PM   #30
joeystang's Avatar
I have seen this thread several times, it looks good. I working on a custom intercooler to fit inside my adapter.
__________________
www.jdbmods.com
Old 12-23-2010, 04:30 PM   #31
brando87gt's Avatar
nice!! my kind of build!! any chance this would fit under a 3.5" cobra r hood? is the snout extension for fox or sn95 5.0?
__________________
1995 Opal Frost GT - 5 speed swapped, stock bottom end, gt40 heads, tfs1 cam, tfs street intake, bbk cai, bbk 70mm tb, equal length shorties, o/r h-pipe, dumped 40 series delta flows, 3.73 gears, mgw shifter
brando87gt is online now
Old 12-23-2010, 04:58 PM   #32
joeystang's Avatar
It should fit, the extenjtion has adjustment to fit both models
__________________
www.jdbmods.com
Old 12-26-2010, 12:25 AM   #33
brando87gt's Avatar
My main concern about fitment is with the extended snout. Will that hood mod have to be made with any hood? I was planning on buying the 3.5" cobra r hood from ho fibertrends after the first of the year.
__________________
Old 12-26-2010, 12:41 AM   #34
joeystang's Avatar
I wouldn't think so, that hood mod was on a 2" cowl hood and it only stuck out by a 1/4" so I would think a 3"+ hood would be ok.
__________________
www.jdbmods.com
Old 12-30-2010, 02:49 AM   #35
DSBLK93GT's Avatar
Trader Feedback: (46)
No 2nd guessing those head gaskets LOL. I like the 8548 PT2 gaskets.
__________________
2011 Shelby GT500
Race Red/white w/SVTPP & Electronics package, bone stock for now!
'93 LX
reef blue, 5spd, Vortech Si-Trim, 6037s, TFS 1, 1.7 rockers, Cobra intake, 65mm TB, 60lbers, BA2400 maf, 3.73's, & more *SOLD*
DSBLK93GT is online now
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
