Go Back   Corral.net : Ford Mustang Forums > Windsor Tech Forums > 94/95 Tech
Thread Tools Display Modes
Old 02-26-2008, 11:38 PM   #1
wldtang
wldtang's Avatar
Trader Feedback: (118)
My 94 cobra to 03 cobra conversion
I don't know of another conversion such as this. Many similar but not exactly like this.
My 94 cobra has went through many changes over the past couple of years. I have finally settled on one setup. At least for now.
This is a major conversion.
04 cobra Motor
T56 trans
complete wiring harness
dash assy - reusing my black pad
brake system - reusing my calipers and spindles
pedals
steering column - reusing my steering wheel
fuel system
a/c system
coolant system
Mods will be:
Stiegemeier stage 5+ Ported eaton
Accufab plenum ported to match Stiegemeier stage 5+ port
2.76 upper / 2lb lower pulley
60 lb inj
SCT 2800 maf
longtubes
x pipe
Mac Flowpath catback
JLT CAI
4 piece idlers
egr delete
SCT Xcal II tuner
Spec stage 3+ clutch
Fidanza Flywheel
Fore top hat
GT pumps
dual FPDM's
First I started stripping the car down. Everything needed to come out.
I installed a PA Racing tubular K. Next I will be installing 03 A arms, sway bar, steering rack. I will re-use my spindles and brakes.
I then stripped the interior.
Pulled the dash and converted it. I wanted to keep most of the 94 look. Mostly because of the color. True black. Not charcoal like the 03-04's.
I swapped my dash pad and heating ducts over to the 03 metal frame and installed all of the 03 wiring.. Installed the 03 cluster.
03 pad after removed from the shell
03 dash shell with pad removed
94 dash before it is stripped
94 stripped shell and harness. Pad was relocated to new 03 dash frame
94 dash converted to 03 internals converted
I had to change the pass side air bag connector.
From Brown
to Black
The 94 has the defroster on the instrument bezel whereas the 03 has it on the stereo bezel. I am having to cut and splice the harness and run to my stock defroster switch.
__________________
1994 Cobra Ex-Terminator-(white w/ black cloth) 1 of 268
5.0 Mustang and Super Fords (October 2009 issue)
http://www.mustang50magazine.com/featuredvehicles/m5lp_0910_1994_cobra_mustang/index.html
#4929 of 5009 - born 7-28-94 - Built by DDP Racing
wldtang is offline   Reply With Quote
Old 02-27-2008, 12:11 AM   #2
1wicked94
1wicked94's Avatar
You got yourself a project there. You should take pics as you go and postem, I'm sure most of us would wanna see that one.
__________________
Rio red Mustang GT. Trickflow street intake, 24lb injectors, ported and polished windsor jr Iron heads, Mac long tube headers, stage 1 trickflow cam 1.6 scorpion roller rockers, 75mm mass air meter, 70mm throttlebody, aluminum driveshaft 3.73 gears, MSD ignition, A9L conversion.
1wicked94 is offline   Reply With Quote
Old 02-27-2008, 01:00 AM   #3
forbanger
There is a guy on another forum who has one like this. His was red full swap interior and all.
Pretty cool!
__________________
- 89 Turbo coupe
-2003 10th Cobra -Gone
-1995 Mustang GT Vert-stock- Gone
forbanger is offline   Reply With Quote
Old 02-27-2008, 01:26 AM   #4
SilverSmith82
SilverSmith82's Avatar
Your pics aren't working. Did you find a wrecked 03 somewhere? This swap is crazy, something I would LOVE to do one day if I could find a busted up terminator somewhere.
Or did you buy it all piecemeal?
At any rate good luck and get those pics working!! Use photobucket.
__________________
-95 Cobra SVT #3914 of 4005. Rebuilt 302, Performer RPMs, Comp XE270HR-112, Tmoss ported Cobra intake, full supporting cast of bolt ons. 301whp/325wtq tuned by Radical Racing.
-00 Contour SVT #1245 of 2150. Daily driver, basic bolt ons, big brake kit.
SilverSmith82 is offline   Reply With Quote
Old 02-27-2008, 03:05 PM   #5
Future303
Future303's Avatar
Wow man, I'm not undermining the work put into this thing, but if it were me, I'd have swapped the 94 Bodypieces to the 04 Cobra and called it a day.
__________________
Mustang Preference: (Favorite to least Favorite):
94-98's . 05+ Stangs . A tie for 03-04 Mach 1's and 4 eyed Foxes . Pre-80's Mustangs. 2 Eyed Foxes and New Edge.
Future303 is offline   Reply With Quote
Old 02-27-2008, 04:21 PM   #6
SilverSmith82
But then you'd have to buy a perfectly good 03/04 Cobra to do this to which defeats the purpose. He probably got a wreck for a good price.
__________________
Old 02-27-2008, 05:59 PM   #7
P63
P63's Avatar
You did all that work and left the Mach460 in there???
Whiskey Tango Foxtrot
__________________
Victor Marshall
Copyright 2010.
May be quoted on the Corral. Not to be otherwise copied or reprinted without permission.
P63 is offline   Reply With Quote
Old 02-27-2008, 06:04 PM   #8
SilverSmith82
Yeah I could see the Mach 1000 if it had one...maybe...
I replaced my Mach system long ago with good pioneer stuff and it sounds 100x better.
__________________
Old 02-27-2008, 08:15 PM   #9
wldtang
wldtang's Avatar
I also replaced my complete body harness. Man the 03 body harness was a pain. I had to take the car completly apart. What a pain in the ass.
main body 03 harness
From this
To this
I have to figure out how to wire in my 94 Mach 460 rear amps, fog light switch (94 mounted in console, 03 mounted on stereo besel), and the seat belt switch.
I finished installing the EEC and the EEC harness from the pass side wheel well.
Next, I swapped my heater box assy. These three bolts need to be removed first.
I had to move some of the parts from my 94 box to my 03 box. Mostly the fan assy and some duct work that was missing. Notice the difference in a/c lines.
94 heater core lines
03 heater core lines
03 box installed. i will need to trim the hole opening.
__________________
Old 02-27-2008, 08:15 PM   #10
wldtang
wldtang's Avatar
03 heater box installed along with eec and eec harness.
I need the bracket to mount this three connectors behind the drivers side kick panel. Notice I installed the 03 gas pedal and dead pedal.
Air bag module installed. I need to trim the holes so the remaining bolt will fit
The 03 main body harness takes a different rear mach 460 amp harness than the 94 cobra does.
Column conversion
These are the two columns
94 column
94 key tumbler
03 column
PATS
94 vs. 03 column
swapped the 94 air bag, clock spring, steering wheel, and black air bag connector to the 03 column
94 Carcass
__________________
Old 02-27-2008, 08:17 PM   #11
wldtang
wldtang's Avatar
Updated: 12-28-07
Removed the abs module and front brake lines.
Removed remaining harness in engine bay
Test fitted the hydroboost. I need to drill one alignment hole.
Removed 94 horn and installed 03 horn
12-30-07
Trimmed the brake hole opening for the hydro boost and drilled the alignment hole. It now fits.
Installed the 03 pedal assy.
Hope to move the lower rad. mounts this week.
1-6-08
Finished bolting up the PA Racing K member and installed the 03 cobra front sway bar. I will complete the front suspension once I install the steeda X2 balljoints on the 03 A arms.
Installed the dash assy and pedal assy. Wire connectors all mated up.
Broke my *&#@ windshield trying to tight the top three dash bolts. Ratch slipped and hit the windshield and crack. Guess I get to buy another one.
Need to get my suspension completed so I can move the car for engine bay paint. Once that is complete, assy should move faster.
Got my stage 5 steggy ported eaton back today.
Stage 5 port
front drive rebuild
2.76 pulley install
accufab plenum port to my eaton
What a beaute.
Fore top Hat - just need some GT pumps now.
__________________
Old 02-27-2008, 08:17 PM   #12
wldtang
wldtang's Avatar
Finished my front suspension.
Bolted up the K member
Installed Steeda X2 balljoints in the 03 cobra control arms
Install 03 struts. Retained my 94 cobra spindles,, brake caliper, abs sensors, and soft brake lines.
Also switched the 03 cobra front sway bar.
I am using the 03 cobra front rotors. Just need to get them shaved to clean up.
I also need to order a MM service 6 kit so I can put a boot over the strut rod.
1/19/2008
Ordered a Fore hat about a month ago from Lethal.
Ordered a new sending unit and dual GT pumps from Tousley Ford.
Today I decided to assy the hat.
All went very well. The only problem I had was when taking the stock filter off of the new GT pump, I broke the small tab that helps hold on the sock.
The fore supplied sock seems to fit very tight on the pump so I should be ok.
Update 1-31-08
Got my longtubes. Nice.
__________________
Old 02-27-2008, 08:18 PM   #13
wldtang
wldtang's Avatar
Update: 2-2-08
Finished installing the mach 460 rear deck harness and ran a 10 ga. wire from the trunk to engine bay. This will feed the GT pumps in the fore hat.
Installed the rear side panels, speaker deck cover and rear seat. Also installed the mounting bracket for the 3 plugs behind the drivers kick panel.
Next up, engine bay paint.
Stay tuned for more to come.
__________________
Old 02-27-2008, 08:20 PM   #14
wldtang
wldtang's Avatar
bought one that was partial parted out. Got about 1/2 of the parts from it. Then bought the other 1/2 from another guy who had parted out a car.
Pics now working. I couldn't get them all in the original post. It will only allow me to post 20 pics at one time.
Old 02-27-2008, 08:22 PM   #15
wldtang
wldtang's Avatar
If i did that, I might as well have bought a 04. I like the looks of my 94 and wanted to have a wolf in sheeps clothing.
Old 02-27-2008, 08:24 PM   #16
wldtang
wldtang's Avatar
The mach 460 worked fine. Besides I didn't have the mach 1000 system. I don't plan on listening the mach much anyhow. Just the eaton whine.
Old 02-27-2008, 08:28 PM   #17
FLstang95
FLstang95's Avatar
wow, dude i envy you!!!!! I love the 03 cobras. If i wasn't building my own SN95 project, and had a crap load of extra cash, and a parted out 03 cobra, id be doing this!!!! I cant wait to see more progress pictures, and a the final masterpiece!!! Keep up the good work man!
__________________
Ex-Stang owner.
FLstang95 is offline   Reply With Quote
Old 02-27-2008, 08:32 PM   #18
wldtang
wldtang's Avatar
what your project consist of?
__________________
Old 02-27-2008, 08:52 PM   #19
willnerd
Great post! Very interesting. I wish, wish, I wish.
__________________
82 coupe, 308, TW heads, RPM, Fcam, Novi 1K, tremec TKO, Strange 33 spooled, best motor pass 12.00 @113 Sold
95 gt ,Tw heads, stage 1 cam, Vortech 10lbs., 3200 Edge Tc, PMS and the list goes on
willnerd is offline   Reply With Quote
Old 02-27-2008, 09:01 PM   #20
FLstang95
FLstang95's Avatar
heres a link to my project...
it hasnt been updated in forever... but i just stripped the whole car, and im building it up the way "I" like it for street use, but mostly a pretty badass weekend warrior!!!
Nothing as intense as yours... i know once this mine is done, im gonna want to start another project. thanks for the inspiration on my next one!!
http://www.corral.net/forums/showthread.php?t=911843
__________________
Ex-Stang owner.
Old 02-27-2008, 09:02 PM   #21
SilverSmith82
Did you get a wreck or do it piecemeal? I'd consider doing something like this in 4 or 5 years when there are some high mileage wrecks to be had where I could yank/rebuild the motor and do all the stuff you're doing. I've always wanted a terminator but I LOVE how my 95 looks...
__________________
Old 02-27-2008, 09:06 PM   #22
wldtang
wldtang's Avatar
Got 1/2 of it from a wrecked 03 i bought. I then drove to atlanta and bought the rest from a guy parting out another 03.
I have had to buy a few parts here and there.
Been modding along the way
Old 02-27-2008, 09:08 PM   #23
wldtang
wldtang's Avatar
I remember that post. Very nice.
Old 02-27-2008, 09:45 PM   #24
FLstang95
FLstang95's Avatar
thanks man. Keep up updated... Ill be subscribing!
__________________
Ex-Stang owner.
Old 02-27-2008, 11:41 PM   #25
1wicked94
1wicked94's Avatar
I love it, great theme of the undercover sleeper. Keep the pics commin, great job man.
__________________
Old 02-28-2008, 08:22 AM   #26
Greg@GLD
Administrator
Greg@GLD's Avatar
We would like to commend you for your project and your post.
This is tech in the truest sense of the word. Extremely interesting post.
+1,000 from Corral Staff.
Greg@GLD is offline   Reply With Quote
Old 02-28-2008, 08:50 AM   #27
Cobra Jet NJ
Corral Charter Member
Cobra Jet NJ's Avatar
Trader Feedback: (36)
Thumbs up
wldtang -
I have to commend you on the "upgrades", the tedious aspect of the conversion, the attention to detail with your explanations of what is being done and the overall documentation with pictures!!!
I will have to say this is one of THE MOST excellent SN95 (94/95) tech related threads in this very forum!
Best of luck with the project and once you get to the finish line - do post up some more pics & vids!
__________________
- Phil
1994 Cobra coupe #0013, 2004 Ford Explorer, 2007 Mercury Milan
Drive like water flows, follow the path of least resistance.
Cobra Jet NJ is offline   Reply With Quote
Old 02-28-2008, 12:37 PM   #28
1trkpny95
1trkpny95's Avatar
Trader Feedback: (40)
Great work man! This thing is going to be a MONSTER. I definitely can't wait to see the finished project. She's gonna be one bad ass mother f'er.
__________________
'95 GT: FordStrokers.com 347...375/384 to the tires and wanting more
1trkpny95 is offline   Reply With Quote
Old 02-28-2008, 08:16 PM   #29
wldtang
wldtang's Avatar
Coming from the staff means alot. I was posting this over on SVTP and got banned for telling someone to STFU. They even deleted this same thread over there after I got banned. It had much more information in it.
I am going to try to keep the details going in this thread. My goal is to have it completed by May and drive it to corral day in June. Once I get the engine bay painted, it will move quickly. That is my current hang up.
__________________
Old 02-28-2008, 08:22 PM   #30
wldtang
wldtang's Avatar
Originally Posted by Cobra Jet NJ View Post
wldtang -
Thank you very much.
I have not seen a 94-95 done this way before.
Old 02-28-2008, 09:07 PM   #31
FLstang95
FLstang95's Avatar
wow MAY! thats a quick deadline... i gave myself 2 years to do my little project, and it ends this august! haha... my hats off to you man!!! I may actually want to go up there for corral day, JUST to see YOUR car in person! keep up the great work
__________________
Ex-Stang owner.
Old 02-28-2008, 09:15 PM   #32
wldtang
wldtang's Avatar
I wish it was done now. I would be driving to the NMRA in two weeks.
I hope to see you at Corral Day.
I want to see what it will do with the 60 shot I just got for it.
__________________
Old 02-28-2008, 10:23 PM   #33
lchauvin88
lchauvin88's Avatar
HOLY SWEET CONVERSION BATMAN!
Man this car is gona be wicked-awesome. I would like to congratulate you for taking on this size of a project. I wish you best of luck with everything, and can't wait to see the finished car!
Question: Anything you wanna sell from the 94'? Like the cobra heads, intake? ECU? ???? Cheap? LOL. Let me know.
lchauvin88 is offline   Reply With Quote
Old 02-29-2008, 12:36 AM   #34
89cobranotch
89cobranotch's Avatar
svtp can be a joke sometimes! i remember seein this thread over there i was wondering where it went!
sick project, keep us updated.
__________________
94 SVT Cobra- 408/T56
89 Notchback (sold)
89cobranotch is offline   Reply With Quote
Old 02-29-2008, 07:00 PM   #35
wldtang
wldtang's Avatar
The heads, ecu, intake have been sold. I do have somethings still left. Just depends on what you need.
I have a For sale thread with parts I have.
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
