Go Back   Corral.net : Ford Mustang Forums > General Tech Forums > Road Racing/Auto X
Thread Tools Display Modes
Old 02-06-2008, 08:03 AM   #1
KAILUAZ
KAILUAZ's Avatar
Arrow Running brake lines inside the car?
Is it legal in most sanctions to run the hard lines inside the car for a short length? I want to run my proportioning valve inside the car where my cowl used to be.
This is for a HPDE/autocross car and I don't want to do anything that wouldn't pass tech at the track.
Thanks.
__________________
P-86 460 Coupe
militarymustang.info
KAILUAZ is offline   Reply With Quote
Old 02-06-2008, 08:49 AM   #2
Jim Brozynski
I have never heard or read anywhere that this would be forbidden under the rules of any racing body. It may be under strick showroom stock class rules, but in any class where they allow mods then I think it would be allowed.
I did this myself on my road race Mustang. I had it come up through the floor on the left side of the driver seat, attached a bracket to the inside of the rocker panel to steady it and mount the preportioning valve, and then had the line go back under the floor to the rear brakes.
__________________
"Drag racing is for those people who don't know how to down shift and brake at the same time. "
'00' SVT Contour
'87' ITA 16V Scriocco
Jim Brozynski is offline   Reply With Quote
Old 02-06-2008, 11:35 AM   #3
KAILUAZ
KAILUAZ's Avatar
Thanks, I plan on running the lines from the master cylinder into the cowl area (to clean up the engine bay) with the proportioning valve on the passenger side. I don't think I will need to change the settings while driving.
__________________
P-86 460 Coupe
Old 02-06-2008, 12:13 PM   #4
Norm Peterson
Norm Peterson's Avatar
As far as auto-X is concerned, you'll want to look at separate issues such as allowances for drilling holes and the purposes for which they may be drilled. Not all categories have the same allowances, so it would help if you have a reasonable idea where the car would otherwise fall.
Technically, I don't see problems as long as the tubing does not attach to structures that can deflect relative to each other, is protected against chafing where it passes through the sheetmetal, and isn't likely to be inadvertently damaged (such as by catching your foot on either the valve or a line or by impact from a toolbox during packing up or transit).
Norm
__________________
Mine: '08 GT, 5MT, black/light graphite, un-Fstock (DD); '95 Mazda 626, 5MT, (auto-X, bad weather DD, spare)
Wife's: '10 Legacy 2.5GT (her new DD, six-speed manual)
'01 20AE Maxima, 5MT (son's DD for now)
'79 Malibu, ex-CP, 5MT, decisions pending . . .
Norm Peterson is offline   Reply With Quote
Old 02-06-2008, 12:17 PM   #5
KAILUAZ
KAILUAZ's Avatar
I'm not building the car to compete, just for fun, so I'm not worried about class rules. I just want to make sure its safe and can pass tech for HPDE events etc.
Good advice though, much appreciated.
__________________
P-86 460 Coupe
Old 02-08-2008, 04:06 AM   #6
Jack Hidley
Jack Hidley's Avatar
Brake fluid is not flammable, so it should be safe from that standpoint.
__________________
Jack Hidley
Jack Hidley is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
