Go Back   Corral Forums > General Tech Forums > Road Racing/Auto X
Notices
Thread Tools Display Modes
Old 05-05-2007, 06:24 PM   #1
Blown331fox
Blown331fox's Avatar
Exclamation Wrap around Bilstein Break TOO!
I just had pair of wrap around Bilsteins sent to me for reinforcment work. The owner has two pair, BOTH SETS with cracks in the welds, and BOTH noticably bent. The car is a 03 cobra used for auto x, the owner will chime in soon with the specs on the car, but as far as I know its fairly stock. I was tasked with repairing the cracked welds, trying to straighten out the ears, and reinforcing the ears. A lot of guys seem to think this style is stronger then the weld on ear style, but please dont fall victim to that thought as well. Save your time and money, dont go out and buy wrap around style struts thinking its the final solution to a problem that no one saw coming. I dont have any before shots of the cracked welds, but the owner has high detail pics that he will soon post. Here are some pics.
__________________
Mike
Blown331fox is offline   Reply With Quote
Support corral.net, please click our advertisers!
Old 05-05-2007, 06:27 PM   #2
nate79
Damn. I thought I was the hero for a second...oh well
Those look very nice btw. Rounded edges make a big difference. They should work very well too
*edit*
Just thought of something, the o3/o4 struts provide a thicker surface to weld too...so there is an advantage in using them.
__________________
03 4r70w gt, jmod, H&R, Bilsteins, MM everything else
nate79 is offline   Reply With Quote
Old 05-05-2007, 06:36 PM   #3
2k2GT
2k2GT's Avatar
I'm gonna keep an eye on my MM Sport units...
2k2GT is offline   Reply With Quote
Old 05-05-2007, 06:41 PM   #4
Blown331fox
*edit*
I agree, the inside of his didnt get nearly as hot as mine did when welding.
__________________
Mike
Old 05-05-2007, 09:06 PM   #5
white_2kgt
white_2kgt's Avatar
oh look, someone found out what a chamfer is! However still miss the point of a 'clamping load'.
__________________
American Iron #007
Cobra Powered 2000 GT with MM Bits Currently Building 2kgt #2
white_2kgt is offline   Reply With Quote
Old 05-05-2007, 09:55 PM   #6
Blown331fox
The clamping load still exists, I took some measurments before and after bolts installed. Metal stretches.
And thats not a chamfer, check your dictionary.
Whats your fix?
__________________
Mike
Old 05-06-2007, 12:11 AM   #7
MustangTurboCoupe
MustangTurboCoupe's Avatar
Hmm, I'm no engineer (well not a mechanical engineer) but why not use a heavier plate that covers the ears and extends up higher on the housing, and put a gusset between them....I'd imagine that would distribute the load over a wider area, and resist the twisting of the ears due to the extra material.
Those welds done with a mig?
__________________
The Wagon Queen Family Truckster. You think you hate it now, but wait till you drive it.
89 Country Squire:
96 Explorer Motor, XE264 cam, 24lb injectors, 80mm MAF, '03 Marauder airbox, BBK headers, 2.5" exhaust, underdrive pulley, 3.73's, trak-loc, aluminum driveshaft, big 4 wheel disc brakes, poly bushings, '02 PI steering box, wide ratio AOD, 2400 stall, Lots of suspension work.
You did what with that wagon???
Autocross??? (stock 157K engine & suspension)
NEW Vid 9/9/06 HERE! (short vid)
Full vid here
MustangTurboCoupe is offline   Reply With Quote
Old 05-06-2007, 02:38 AM   #8
Blown331fox
Can you sketch a pic of what your idea is, its kinda foggy.
correct, miller mig, notice the slop.
__________________
Mike
Old 05-06-2007, 09:20 AM   #9
Turbo 5.0 Mike
Turbo 5.0 Mike's Avatar
Do they come in any color besides Big Bird Yellow?
Turbo 5.0 Mike is offline   Reply With Quote
Old 05-06-2007, 09:48 AM   #10
2k2GT
2k2GT's Avatar
I think all Bilstein's are yellow.
Old 05-06-2007, 11:24 AM   #11
WJL
This is another brand of strut, just an example.
Center channel is a big plus I think.
WJL is offline   Reply With Quote
Old 05-06-2007, 11:39 AM   #12
Blown331fox
Adding a center channel would be nice, but diffucult. You cant put it in the inside because the spindle will no longer fit.
Any color you like, but bilsteins are yellow, so i kept that theme.
__________________
Mike
Old 05-06-2007, 11:41 AM   #13
Blown331fox
Turbomike, I got your pm, if you can get me some rainbow paint, Ill spray them.
__________________
Mike
Old 05-06-2007, 11:49 AM   #14
onesillynotch
onesillynotch's Avatar
turbo mike..thier is a face i havent seen in a while..still got the dark GT?..i know blue trash was last seen being sold on a used car lot
__________________
1988 Notch...2.3T
5 lug cobra brakes, full MM CO, MM PH, MM FLSFC
onesillynotch is offline   Reply With Quote
Old 05-06-2007, 12:07 PM   #15
Oktavius
Moderator
Oktavius's Avatar
Going higher up on the strut body wouldnt work for those using coil-overs.
__________________
Tim ||||||| ||||||| |||||||
07 Subie Impreza - DD
92 GT SSP
Oktavius is offline   Reply With Quote
Old 05-06-2007, 12:08 PM   #16
Oktavius
Moderator
Oktavius's Avatar
What about relocating (cut and weld) the tabs to allow room for the channel?
__________________
92 GT SSP
Old 05-06-2007, 12:24 PM   #17
Blown331fox
The channel would have to be the width of the spindle ear. At that point, welding the ear back on would only be good for locating the new holes, as I dont think they would be adding strength.
__________________
Mike
Old 05-06-2007, 02:26 PM   #18
Turbo 5.0 Mike
No, no more Mustangs for me. I am a fancy man now. You can find me at the nearby roadcourses beating up on the local Saleen guys.
Old 05-06-2007, 02:50 PM   #19
MustangTurboCoupe
yup, that's true... Could clearance the coilover a bit depending on how much reinfiorcement is needed to keep the strut intact... I'm glad I don't have to deal with mac struts
Yeah, I noticed on a few of the beads...
Here's a very crude pic....Red obviously is the modification.
__________________
89 Country Squire:
Full vid here
Old 05-06-2007, 04:08 PM   #20
Blown331fox
Here he is at the track..
http://videos.streetfire.net/video/d...5401410ae1.htm
__________________
Mike
Old 05-06-2007, 04:22 PM   #21
88Brawler
88Brawler's Avatar
Smile
Lots of interesting ideas here, but personally I'd wait for Blistein/MM to address it.
Without knowing the exact loading condition that is triggering the failures, throwing reinforcements at it where they aren't needed doesn't gain anything but adds more mass and the potential to screw up the strut body. What measurements were taken pre/post welding to determine if the tube has maintained its design spec for the bore (roundness and diameter)?
And with respect to clamp load, I'd be real cautious about gusseting the hell out of it and then creating a stress concentration at the fastener locations. A part that is uniformly loaded has a higher probability of survival that one that point-loaded...given the same load input. Yes, I know the entire ear of the spindle is trapped, but still I'd watch it.
MustangTurboCoupe: Adding gussets that run the length of the strut body (upward from the spindle mounting ears if you will) doesn't work for us coilover guys. Not to mention it adds very little strength. You might be able to trim the threaded sleeve a bit if you run short enough springs (8" or maybe 10" - would be close). Still, I don't think there's much merit in adding any gusset along that axis.
Don't misunderstand me, I don't have the answers, but boasting because you were the first to do something doesn't mean much if you've toasted a set of struts or created a different failure mode. Time will tell I guess.
By the way, a buddy of mine runs about 12-15 events/ season and has Tokico Illuminas that are approx. 4 or 5 years old and his are not bent. His car is 3350#, puts down 430hp or so to the wheels, and he runs 275s (race tires) all around, 2000R Brembos, and is usually one of the fastest cars at the events he attends.
I'm not knocking Bilsteins, but clearly their spindle mounting ears are questionable under certain circumstances.
Good luck to everyone who's running them.
88Brawler is offline   Reply With Quote
Old 05-06-2007, 05:07 PM   #22
nate79
damn...that mustang pulled away hard from that viper
any info on the mustang? would like to know what type of suspension its got...
__________________
Old 05-06-2007, 07:04 PM   #23
Blown331fox
Thats my car. Stock saleen suspension in the vid. Full MM suspension now.
__________________
Mike
Old 05-06-2007, 08:07 PM   #24
nate79
wow, nice car man
__________________
Old 05-07-2007, 12:15 AM   #25
Turbo 5.0 Mike
It's not that fast, I was looking for a good radio station, that's the only reason the Saleen got by me. I lapped him a few minutes later, but the battery on my camera died.
Old 05-07-2007, 10:16 AM   #26
white_2kgt
white_2kgt's Avatar
http://www.thefreedictionary.com/chamfer
cham·fer (chmfr)
tr.v. cham·fered, cham·fer·ing, cham·fers
1. To cut off the edge or corner of; bevel.
2. To cut a groove in; flute.
Whats your fix?
MM currently has the one set of struts that I have which are bent. I'm waiting for them to send me back a properly engineered, tested and repaired set, not a Granatelli engineered set. I ran those HD's for 3 years w/o (serious) problem, I can wait a few more months, now that I know what to look for, I can check them between runs to see if anythings bending.
Can you post pics of the 03/04 strut that was bent prior to you welding on it?
__________________
American Iron #007
Old 05-07-2007, 11:10 AM   #27
WJL
I do give you a A for effort but I would like to know the following
Questions:
How did you decide:
What thickness of material to use?
What material to use? (cold rolled, hot rolled ect)
What grade of material to use?
Type of welding (tig, mig, stick)?
Where to place the the brackets?
The size of brackets?
Affect on strut body after the install?
Long term results, fatigue, cyclic ability, durability, ect?
Safety, liability?
These are all things that need to be considered when modifying/engineering a design such as this, especilly when you are now doing it for someone else.
Old 05-07-2007, 11:24 AM   #28
BRGT350
BRGT350's Avatar
are these failures on cars with coil-overs, are some failing with conventional springs?
__________________
1984 White Mustang T-Top Auto-x/HPDE
#07 CP SCCA WMR
www.racetech0722.com for my Mustang build and racing info
2011 Ford Fiesta Titanium Edition
For more info, check out my website or www.fiestamovement.com/agent22
BRGT350 is offline   Reply With Quote
Old 05-07-2007, 11:27 AM   #29
white_2kgt
white_2kgt's Avatar
So far I've only heard of them failing on Coilover only cars. MM doesn't seem to think the coilovers have anything to do with it though (well at least as of early last week).
__________________
American Iron #007
Old 05-14-2007, 10:01 AM   #30
Scot_94GT
Scot_94GT's Avatar
Which brand is that?
__________________
Modifications worth noting:
Cobra brakes, BBK headers, H&Rs, Bilstiens
Scot_94GT is offline   Reply With Quote
Old 05-14-2007, 10:10 AM   #31
WJL
Tokico
Old 05-14-2007, 01:55 PM   #32
carrew
carrew's Avatar
If you go to cc.com mm did a test and found the problem. Basically if you 275 or larger tires, bigger than stock pbr calipers, and race compond tires.
carrew is offline   Reply With Quote
Old 05-14-2007, 03:42 PM   #33
white_2kgt
white_2kgt's Avatar
MM didn't 'find' that to be the problem, that was just the common configuration people were running that reported the issue, and for what it's worth, I bent mine using 13" PBR's and stock 01 cobra HP on RA1's.
This thread title should be changed, so far none of them have 'broke' they have just bent. Had mine 'broke' we'd be having a vastly different conversation.
__________________
American Iron #007
Old 05-14-2007, 03:52 PM   #34
carrew
carrew's Avatar
Yes but you were on RA1's were are a race spec tire that provides higher braking force. Which meets their findings, it said nothing about HP.
The interesting part was testing all the kinds band-aid bracing people were talking about and none of them did more 1% additional help. Its cool to see factual findings instead theory.
Old 05-14-2007, 04:20 PM   #35
white_2kgt
white_2kgt's Avatar
I was just throwing that in there for completeness and to show that stock PBR's can cause this as well.
Agreed. Nice to see someone who takes the times to think a problem through then test it before grabbing the welder.
__________________
American Iron #007
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
