Thread Tools | Display Modes |
#1 |
F303 cam idle and sound
Hello all
I am going to be getting my old 93 Cobra back here soon and one of the first things i would like to do is switch the cam. It has an E cam in it now and the 1.7 rockers to go with it. Does anyone have any sound clips of an F cam in a stock 5.0 with either the cobra iron or aftermarket heads? How well do these idle compared to the E cam? Also, will this cam pass emissions? Will i have to go with the 1.6 rockers as well for clearance issues? Thanks guys, Nick |
| Sponsored Links | |
Advertisement |
#2 |
Go to www.youtube.com and type in f303 in the search bar and their will be two cars with sound clips.
#4 | |
it did not pull up anything with f303. i tried other ways with it and i got nothing. Do you have a link? |
#6 |
bbk long tubes,mac pro chamber h pipe , 2 chamber flows with turn downs
__________________
347,high ports,vic jr,750,c4,373,180 shot 60' 1.39 BEST 1/8 6.43 BEST 1/4 10.46 1/8 mph 108.5 BEST 1/4 125.6 da was 2000 96* |
#7 |
www.projectstang.com/fcam_flowmasters.wmv
BBK Long Tubes, H-pipe, Dumped Flowmasters (and F303 obviously) |
#11 |
Here's mine
Fresh 308, T-5 WC trans, Edelbrock performer RPM heads and Intake, summit 1.72 roller rockers, FRPP hardened pushrods, ARP head bolts, new king cobra clutch, Hurst shifter, BBK FPR, 75 mm MAF and throttle body, 76mm C&L pipe, 24 lb injectors, f-303 cam, 3.73 gears, hooker headers w/flowmaster 2.5” exhaust, underdrive pulleys http://s34.photobucket.com/albums/d1...pipes003-1.flv http://s34.photobucket.com/albums/d1...=car2005-1.flv
#12 |
The Elitest
Location: Foht Walt'n Beach Floriduh aka The Redneck Riviera
You're buying a cam based on how it sounds??
__________________
1990 LX 306, Neil Erickson ported Edelbrock performers, Jay Allen cam, 92MM Pro-M, 75MM-R TB, holley systemmaxII, 1 3/4 accufab longtubes, 3" exhaust 358RWHP/346RWTQ 7.68 at 89.4 28MPG hwy, 1986 LTD wagon, glorified fairmont with a luggage rack and a big truck motor |
#13 | |
Trader Feedback: (22)
nice set up, sounds good. do you have any more pics of your car? pretty lopey for an f cam, what is the idle set at? |
#15 |
x2
Ive had the f303 in my car and went with a custom cam. I enjoyed the extra 25hp and 40tq improvement (w/ afr heads)...How it would sound never really crossed my mind
__________________
http://www.87gt.com Bad Ass Mustang of the Month! TIRESMOKE! (25MB) Fun at ATCO (10MB) |
#16 |
sound of cam
No, i just want to hear what it would sound like. I don't want a cam that has so much lope it feels like it is going to die while idling.
I like to specs of the F cam and the car has an E cam in it and i wanted to hear the difference between the two. I also have thought of a custom cam as well, just havent put too much thought into it. |
#17 |
The Elitest
You should, to optimize your combo; otherwise Jay Allen will recommend on off the shelf cam for $50. Also keep in mind the letter cams were designed at least 20 years ago.
__________________
#19 |
I have the f-cam in a 306. Dart iron heads (not drilled for emmisions), Cobra intake and long tube headers. All emmisions stuff is disconected and removed. I bolt up a set of 2.5 highflow cats every couple of years for the emmisions test and pass with flying colors every time. It is the Indiana emissions test. I put the fuel pressure at 38psi, Set the timing at 10 degrees, get the car good and hot then go take the test. Past 4 times taken I have always passed.
__________________
FIGHT FOR EVERY TENTH, SOONER OR LATER THEY ADD UP. |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
