Go Back   Corral.net : Ford Mustang Forums > General Tech Forums > Drag Racing
Thread Tools Display Modes
Old 11-05-2006, 02:40 PM   #1
Daniel Mitchell
Watch this launch vid and tell me what my car needs...
I can't seem to get this car to transfer any weight to the rear tires. Here is what my front and rear suspension consists of:
Front:
Tubular k-member and a-arms, coilovers with 160# 14" Hypercoil springs, Strange adjustable struts. Also has a manual rack but has AC and still has the battery up front.
Rear:
Megabite Jr lowers and adjustable uppers. Stock springs that have had a little cut off of them. Torque boxes are welded and it has subframe connectors.
Otherwise, the car is full weight, AOD, etc. I run on M/T 26x10 slicks with around 12-13psi in them. This particular run was with the struts set 2 clicks from full loose but I had already tried some other settings with no luck. Here's the vid:
http://videos.streetfire.net/video/8...700006237f.htm
__________________
'97 GT w/ an '01 engine swap.
Daniel Mitchell is offline   Reply With Quote
Old 11-05-2006, 02:44 PM   #2
Daniel Mitchell
Just from watching it again and pausing at the very start of the launch, it looks like I could use some stiffening at the right rear, possibly an airbag or adjustable shock right there. Maybe a little stiffer setting on the front strut on the pass side as well. But that still won't get the front end up.
BTW, that was a 1.46 60' time.
Old 11-05-2006, 05:52 PM   #3
etatum21
A sway bar will help tremendously. Keeps the rear tires planting at the same time. Also an airbag will help, but is more of a bandade than anything. Try an adjustable swaybar, should help level the car out. (p.s. I am no expert, so get another opinion before spending the cash ) The car needs more preload on the right rear to level out on launch. The only problem with this is that is can affect cornering ability, depends on if the car is a driver or a race car.
etatum21 is offline   Reply With Quote
Old 11-05-2006, 06:07 PM   #4
TonyG
TonyG's Avatar
I had the same problem, and fixed it with 13 way QA1 adjustable rear shocks from summit. I set the passenger/rear stiffer. I also have adjustable front struts, and set the driver/front on a stiffer setting.
__________________
99 2v GT, 35th, 518 rwhp, 470 rwtq
11.035/129.77/1.595 (stock shortblock)
http://www.youtube.com/watch?v=q2ak8fsodjA
TonyG is offline   Reply With Quote
Old 11-05-2006, 06:22 PM   #5
chvyeter
chvyeter's Avatar
we had a 170 lbs spring in the front and dropped to 130 lbs and went from 1.6's to 1.43 60ft times with nothing else changed
__________________
8.0 @ 88 on motor, old 306
7.0 @ 100 on new engine combo
6.4 @ 108 letting out twice on bottle.
11.2 @ 126 in 1/4 on motor
chvyeter is offline   Reply With Quote
Old 11-05-2006, 07:18 PM   #6
SKR8PN
SKR8PN's Avatar
Loose the A/C,put the battery in the left rear corner.
Then go to adjustable rear shocks.
Then, if needed, try an adjustable rear sway bar.
SKR8PN is offline   Reply With Quote
Old 11-05-2006, 08:15 PM   #7
Daniel Mitchell
Yes it has been my daily driver for a while now. It has the stock rear sway bar installed but no front. I'm not concerned at all about cornering. I don't hang curves or anything. And I rarely ever break the speed limit.
Old 11-05-2006, 08:18 PM   #8
Daniel Mitchell
My left rear corner is occupied by my 1 gallon fuel cell for the nitrous fuel system. The right side is the bottle. And I have to load one of my slicks in the middle, so there's no room in the trunk for anything else.
I think I'll try an adjustable shock. It looks like I can get away with just buying one for the passenger's side since that's the side that's squatting so much. I think I may turn on the coilovers some to raise it up. Maybe it's just too damn low?
Old 11-05-2006, 08:20 PM   #9
Daniel Mitchell
Actually I have cut a 1.38 60' before with a 200# spring and stock k-member. Now I have switched to 160# and lost weight off of the front so it should work better than before. It makes more power than it did before as well though.
Old 11-05-2006, 08:41 PM   #10
gray86hatch
gray86hatch's Avatar
Trader Feedback: (36)
It looks like the rear of the car needs to be much lower. get the bar angles correct. I would guess the instant center is way off.
Set the front struts full loose.
Get a sway bar for the rear. Most likley a 130 to 140 front spring. no need to remove the weight off the front if you don't want to.
you need to get a long spring with lots of stored energy to toss the front of the car up.
Tim
__________________
86 3185lb FTI 408 10.24 132 unported TW. Hot Rod Drag Week NA-SB R/U 2007 Officaly Retired from Racing.
When arguing with a idiot after a few min it is hard to tell who the idiot is.
www.flowtechinduction.com www.boozebrothersracing.com
gray86hatch is offline   Reply With Quote
Old 11-06-2006, 12:01 AM   #11
Daniel Mitchell
It must just be the way it looks in the vid or something because the rear is pretty low, as is the front. This isn't a great angle, but here is a pic of it from another angle.
Old 11-06-2006, 06:44 AM   #12
gray86hatch
What location do you have the lower control arm in.
you want the lower control arm parallel to the ground. this will get the IC and AS close. with 26" tires you have to get the car down in the weeds
Tim
__________________
Old 11-06-2006, 09:48 AM   #13
KEVIN$
KEVIN$'s Avatar
Get an antiroll bar..
ks
__________________
Kevin Slaby
Read: Launching a Drag Car
Read: Measuring Pinion Angle
Read: Setting Zero Suspension Preload
Diary of a 5.0 Mustang
79 Pace Car
302, 200hp N2O, Tremec, 9" w/ 4.11's
11.10 @ 122mph
60': 1.47 Stock Factory Control arms.
87 GN
12.05 @ 111, 1.60 60', 15psi launch
Goal: To grow up and be Spiderman
KEVIN$ is offline   Reply With Quote
Old 11-06-2006, 10:18 AM   #14
93hatch
ks
+1. I also thought some 140 springs might help.
What kind of 60' would you like to see? That 1.38 sounds good. Consistant 1.3x?
__________________
Edelbrock 6037's (ported), RPM intake, TFS 1 and all the other bolt ons.
New combos numbers:
315 HP @ 5500
339 TQ @ 4100
7.94 @ 89.70 (1.79 60')
93hatch is offline   Reply With Quote
Old 11-06-2006, 12:15 PM   #15
Daniel Mitchell
No, it wasn't consistent 1.3s back then and a 1.46 was my best yesterday and accordong to everyone else the track was hooking great.
Old 11-06-2006, 09:07 PM   #16
Adrenalin
Adrenalin's Avatar
Front:
Rear:
Simple,
The problem is that you have entirely too much horsepower/torque. Just send me oh about 150-200 of that and you should be good to go!
__________________
Fquick.com/Adrenalin - The project is on hold for a bit, but it's not going anywhere.
Adrenalin is offline   Reply With Quote
Old 11-06-2006, 09:29 PM   #17
Mo-D
Mo-D's Avatar
Hey Daniel, how have you been. Have you seen that FFW is going to have a 10.60 index class next year with a .500 pro tree? Adjust those shift points down a little and come have some fun
Mo-D is offline   Reply With Quote
Old 11-07-2006, 12:20 AM   #18
Daniel Mitchell
What's up Kyle? Amazingly enough, you had just crossed my mind earlier today! Kind of a long story but anyway...that's kinda freaky, lol. I hadn't heard about the new FFW class but I'm pretty sure I still can't stand George, lol.
Old 11-07-2006, 08:51 PM   #19
Mo-D
Mo-D's Avatar
That is weird. LOL Well, just stay away from George and you don't have to like him. Ha ha ha ha ha
Old 11-09-2006, 10:29 PM   #20
99whitecobra
i was up there that day, thats a sick car man
__________________
92 LX - MMR Pro Trans 900, victor 5.0 intake, victor jr heads (12:1 compression), comp 282 cam, moser 33spline axles with spool
99whitecobra is offline   Reply With Quote
Old 11-10-2006, 12:23 AM   #21
Daniel Mitchell
If you were racing that day then you should be on the DVD that they are putting together. Thanks for the compliment!
Old 11-10-2006, 03:58 PM   #22
99whitecobra
i wasnt able to have my turd ready in time to race
__________________
Old 11-12-2006, 09:28 AM   #23
nate-roth
Get an anti-roll bar and use some kind of pin w/ clip on one side so you can disconnect it when not at the track. Probably best mod I ever made for going to the track was the anti-roll bar.
__________________
1990 Notch
302, TFS Top End Kit, PA C4, 3800 Edge Converter, 150hp NX, UPR Pro Series Rear, 4.10's Moser axles
6.84 at 98.72 1/8 Mile Best, trying to get better weekly
nate-roth is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
