Go Back   Corral Forums > Power Adder Forums > Superchargers
Notices
Gallery Corral Parts Store Videos Advertising Info Blogs Outside the Fence Corral Home
Thread Tools Display Modes
Old 09-06-2006, 02:13 AM   #1
89ragtopgt
89ragtopgt's Avatar
paxton novi 2000 sound clip- b303cam
here is a video of my novi 2k with a b303 cam on my 89ragtop gt
http://videos.streetfire.net/video/4...33018b2b6f.htm
__________________
306, powerdyne(gone) novi 1000 (sold) now NOVI 2000 too much boost!, 8inch asp crank pulley, tweecer rt, svt heads, kb pistons, b303 cam, trick flow intake,1.7 roller rockers, 60lb inj, sct ba2800, long tubes, x pipe, 70mm tb, CF clutch 355 gears, mm control arms, cold air fw intake A9L.
89ragtopgt is offline   Reply With Quote
Support corral.net, please click our advertisers!
Old 09-06-2006, 05:39 AM   #2
WS6JJP
WS6JJP's Avatar
Trader Feedback: (18)
sounds great!! that B-cam sounded more aggressive than i thought it would
__________________
2004 Screaming Yellow Whippled Cobra
Anti-Theft Device - Nickel Plated .50cal Desert Eagle
WS6JJP is offline   Reply With Quote
Old 09-06-2006, 07:35 AM   #3
mikev08826
mikev08826's Avatar
I can't get sound on that clip. but would like to
mikev08826 is offline   Reply With Quote
Old 09-06-2006, 10:39 AM   #4
Detroitfire23
novi 2000
No sound on video
Detroitfire23 is offline   Reply With Quote
Old 09-06-2006, 12:29 PM   #5
Badazgt
Badazgt's Avatar
same with me.... video works no sound
__________________
94 GT....forged 306, Trickflow Street Intake,
Stage 3 Ported GT-40P's, Lunati 51014 cam w/ 1.7's
S-Trim.. heat soaked.. 509rwhp & 505tq
BADAZGT
Badazgt is offline   Reply With Quote
Old 09-06-2006, 12:33 PM   #6
89ragtopgt
89ragtopgt's Avatar
Guess i will reload the video tonight
__________________
Old 09-06-2006, 01:32 PM   #7
NYC LSC
NYC LSC's Avatar
Man that thing sounds mean!
__________________
1987 LSC - 13.573 @ 102.01, 2.007 60'
Dynoed 285.7 RWHP & 318.8 RWTQ @ Mustang Magic, Deer Park, NY 06.03.06 (*pre-Novi/intake*)
304, Novi GSS, TRW slugs, ARP head & main studs, Thumper E7s, XE270HR-14 cam, YellaTerra 1.72s, SysteMax intake, 65mm TB, 76mm C&L, Kirban AFPR, 24# injectors, FMS wires, MSD 6AL, Crane coil, MAC shorties, 2.5" O-R H, 2.5" Ultra Flows, 4.10 TL, Moser 28 splines, UPR girdle, T-5, Poly trans mount, King Cobra clutch, B&M Ripper, Aluminum DS, Lakewood DS loop, 3G Alt, Dual Flex-A-Lites, No AC/smog, Autometer gauges, TC swaybar, ES poly endlinks, Polyed RU&LCAs, KYB GR2s
1992 LSC
Pretty much stock.
NYC LSC is offline   Reply With Quote
Old 09-06-2006, 02:37 PM   #8
DaveB
Switch to Windows Media Player...Car sounds great though!
DaveB is offline   Reply With Quote
Old 09-06-2006, 04:58 PM   #9
Nasty_Notch
Nasty_Notch's Avatar
Sounds great,I have almost the same motor combo.Novi 2000 should be
here on Friday!!!How much boost are you seeing?
Nasty_Notch is offline   Reply With Quote
Old 09-06-2006, 08:09 PM   #10
89ragtopgt
89ragtopgt's Avatar
Try to switch to windows media player upper left hand of video
__________________
Old 09-06-2006, 09:12 PM   #11
slowstang101
slowstang101's Avatar
my novi sounds louder on video than in real life. For some reason it picks up that higher frequency better on video/audio
__________________
Dart Blocked 438, PT106mm, Callies Magnum Crank, Oliver billet rods, AFR 225's titanium valves, FTI cam
Dynoing in Progress
slowstang101 is online now   Reply With Quote
Old 09-06-2006, 10:17 PM   #12
mikev08826
mikev08826's Avatar
yes please
Old 09-06-2006, 10:34 PM   #13
porsches4lunch
porsches4lunch's Avatar
Sounds mean as F&*K!!!!!!!!!
__________________
www.miketurboinc.com
porsches4lunch is offline   Reply With Quote
Old 09-06-2006, 11:53 PM   #14
89ragtopgt
89ragtopgt's Avatar
still shots here
http://s108.photobucket.com/albums/n22/89ragtopgt/
__________________
Old 09-07-2006, 09:49 AM   #15
Nasty_Notch
Again,how much boost are you seeing?
__________________
302/Novi 2000/T-5/3.73's 492rwp/455rwt-SOLD
Lois: Oh, I haven't been on a college campus in years. Everything seems so different.
Stewie: Really? Perhaps if you laid on your back with your ankles behind your ears that would ring a few bells.
Old 09-07-2006, 10:36 AM   #16
89ragtopgt
89ragtopgt's Avatar
i just put it in last week and have an asp 8 inch overdrive pulley. This feels like a BIG block now. I have not did a W.O.T yet as i am still tuning the motor but i do see about 5-6 lbs just as i stab the throttle at 3500rpm! i have had it to 4800 for a moment and saw 9psi. i do not have forged internals so i am taking this easy for now.
__________________
Old 09-07-2006, 01:28 PM   #17
Badazgt
Badazgt's Avatar
dammit still can't hear it
__________________
BADAZGT
Old 09-07-2006, 05:04 PM   #18
mistamo
Sounds great!! Beautiful car also!!
mistamo is offline   Reply With Quote
Old 09-22-2006, 03:41 PM   #19
V8 Junkie
That sounds mean. I bet it sounds even better under heavy throttle. I saw your photobucket pics. What kind of head unit are you using and are you running a stand alone engine management? I like how you can monitor everything right on your screen.
V8 Junkie is offline   Reply With Quote
Old 09-22-2006, 03:42 PM   #20
V8 Junkie
I saw you have windows xp running on the one pic.
Old 09-22-2006, 09:46 PM   #21
89ragtopgt
89ragtopgt's Avatar
I have a 1ghz laptop under the seat runnning windows xp pro. attached to the laptop is a 8 inch touch screen in the dash .i have a tweecer rt which gives me the virtual dash and i can data log everything and view on hte screen in real time. absolute must for tuning!! it is amazing how much out the maf transfer is even with a matched set of injectors and a maf. mine was 20% too rich. i had to set the injector offset vs battery voltage from .9ms to .5ms that made it almost right on. this is with the ford a9l puter with 42lb injectors. I also have a soundblaster live external usb sound card running to a soundstream amp. all audio mp3 or wav from the puter sounds great.
__________________
Old 09-23-2006, 11:39 AM   #22
Oleflippy
Oleflippy's Avatar
audio
Click the link right above the video that says "Switch to Windows Media ****er"
Car is NICE and sounds awesome.
Oleflippy is offline   Reply With Quote
Old 09-23-2006, 12:56 PM   #23
Badazgt
Badazgt's Avatar
yea i can hear it now..... i had a B-303 in my 94 but could never get it to idle down.... whats urs idling at?
__________________
BADAZGT
Old 09-24-2006, 12:04 AM   #24
mikev08826
mikev08826's Avatar
nice
Old 09-24-2006, 12:50 AM   #25
89ragtopgt
89ragtopgt's Avatar
the magic of a good tune 750-800 rpm
__________________
Old 09-24-2006, 02:03 AM   #26
Blown284
Moderator
Blown284's Avatar
Sounds nice and love that novi!
__________________
SOHC/DOHC Corral Moderator
Founder, Quickstreetcars.com
Part-Owner, Easternfbody.com and Racersden.net
'03 Droptop Cobra
'99 Cobra "10 Second Street car" (SOLD!)
Blown GT (11.2@131) ---> SOLD
AOL: Blown284
Blown284 is offline   Reply With Quote
Old 09-24-2006, 09:10 AM   #27
Musclestang
thats a nice radiator too ......
__________________
1993 , Edelbrock heads - intake - E cam , Powerdyne - 6 lbs , 30's , pro-m 75mm , timing locked at 24 , and I use imports for traction
Musclestang is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
