Go Back   Corral.net : Ford Mustang Forums > Power Adder Forums > Turbochargers
Thread Tools Display Modes
Old 09-03-2006, 04:20 AM   #1
Newt-Rod
Newt-Rod's Avatar
twin turbo car
Guys here is some video of some shakedown passes on my twin turbo small block car. Its a 358 yates headed motor. We are shaking it down with just 5lbs of boost logging some air to fuel ratio readings and checking the chassis out. This is a twin 70mm turbos. I built everything about this with air to water intercooler. I am going to start building turbo kits as well. Again its 5lbs of boost with drag radials. This is 1/8th mile stuff to and with 3.27 gears. car needs more gear for the 1/8th
first pass
leave at 3000 and go
6.38 @110
http://videos.streetfire.net/video/3...290182f3ac.htm
second pass leave at 4000 and go
6.10@ 115 with 1.48 60'
http://videos.streetfire.net/video/b...2a0000f368.htm
__________________
http://i3.tinypic.com/wiswnc.jpg
quicktimeturbosystems.com
teamzmotorsports.com
Newt-Rod is offline   Reply With Quote
Old 09-03-2006, 10:28 AM   #2
fastwhite86gt
nice runs. Lets see some vids with the boost cranked up!
fastwhite86gt is offline   Reply With Quote
Old 09-03-2006, 11:49 AM   #3
Newt-Rod
Newt-Rod's Avatar
wont be long
__________________
Old 09-03-2006, 12:08 PM   #4
MOOVS
Might wanna leave the gear until you crank it up????
__________________
89'LX 306,T.W.heads,perf.intake,36's,stock cam/1.7's,70mmT.B.,T-56,3.27's,Twin 60/63 T3's intercooled,14psi,Evolution WG's, Meth inj.
579.2rwhp 658.6rwtq,11.0@131 kicked off track
MOOVS is offline   Reply With Quote
Old 09-04-2006, 11:48 AM   #5
Newt-Rod
Newt-Rod's Avatar
oh definately not changing the gear
__________________
Old 09-05-2006, 02:03 AM   #6
strkdblwncapri
Nice! i have to get me a turbo!
strkdblwncapri is offline   Reply With Quote
Old 09-05-2006, 02:04 AM   #7
Newt-Rod
Newt-Rod's Avatar
Let me know when ready I can build you a kit
__________________
Old 09-05-2006, 03:32 AM   #8
MOTORCITYMADMAN
Are you going to do twins, single or both?
What price range?
What's the advantage of going twins?
MOTORCITYMADMAN is offline   Reply With Quote
Old 09-05-2006, 05:14 AM   #9
Newt-Rod
Newt-Rod's Avatar
I can do either for the fox body. The price depends on which. The difference is the power out put it will make
__________________
Old 09-10-2006, 08:31 PM   #10
Sting 90
Newt that Twin Turbo looks too fun even at that boost level!! Is this car only driven at the track?? I have been debating between a Nitrous car and a Twin Turbo for my 5.0.Is there a big difference in how the Twin's feel as opposed to a Single setup??I would like to keep my 5 speed ,even though automatic's are easier to control with the insane Torque that a Twin Turbo gives.
__________________
1989 5.0 Mustang GT,Stock Engine,5 Speed Tremec 3550 Trans,Mcleod bellhousing,Pro 5.0 Shifter,255 in tank fuel pump,stock Rear End Gears
Sting 90 is offline   Reply With Quote
Old 09-10-2006, 08:41 PM   #11
Sting 90
Although the Twin T-70's would be way, way to much for a very fast street car.I wouldn't need that for a car that's mainly used for daily driving.
__________________
Old 09-10-2006, 09:02 PM   #12
Brokn
A proper single setup is just as good as any twin. Less weight, plumbing, cost, crap to fiddle with, and stuff that could go wrong. Just some advice..
Nice vid Newt.
__________________
Turbo 93 LX
**HP Stage II Twin 60mm Turbo kit 03-04 Cobra FS**
http://www.corral.net/forums/showthread.php?t=824821
Two '04 Mystichromes for sale - pm for details.
Brokn is offline   Reply With Quote
Old 09-10-2006, 09:33 PM   #13
Sting 90
Doesn't Twins make a car feel stronger on the street?? It seems like for the street car most guy's running with Twin Turbo's prefer them over the single's.I know single Turbo's out number Twin Turbo car's by alot!! It just seems like whoever has the TT set up really like them alot??
__________________
Old 09-11-2006, 03:29 AM   #14
Newt-Rod
Newt-Rod's Avatar
The advantage of twins is more power in the end, quicker spool. The cost is quite a bit more though. Weight really isn't that much more of a factor. The car is driven on the street some. If you get ready to do a kit and need someone to build it let me know.
__________________
Old 09-11-2006, 03:41 AM   #15
slocal94
slocal94's Avatar
NEWT ROD PM sent!
__________________
1994 Fobra, Kenne Bell, Maximum Motorsports suspended. SOLD
Kenne Bell Setup for SALE. SOLD
slocal94 is offline   Reply With Quote
Old 09-11-2006, 05:24 AM   #16
Newt-Rod
Newt-Rod's Avatar
replied to pm
__________________
Old 09-11-2006, 05:25 AM   #17
Newt-Rod
Newt-Rod's Avatar
here is a pic of my turbos before the frontend was put on
http://s106.photobucket.com/albums/m...gAnch=imgAnch1
__________________
Old 09-11-2006, 05:53 AM   #18
Newt-Rod
Newt-Rod's Avatar
couple of pics of the car.
__________________
Old 09-11-2006, 09:02 AM   #19
Sting 90
I have never been in a Twin Turbo or a Single Turbo Mustang.The Turbo Regals are impressive with only Single Turbo's.I like 5 speed's but wouldn't it be hard to get it to spool in first Gear with a single Turbo, because of no Torque converter to help with the spool??I would probably like to put in 3:27 Gears since they are the gear of choice for Turbo cars.
__________________
Old 09-11-2006, 11:46 AM   #20
Newt-Rod
Newt-Rod's Avatar
all you have to do to get a turbo car to spool is buy a msd 2 step. Thats whats need on a stick car. A single turbo setup would be more than enough power to split your block
__________________
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
