Go Back   Corral Forums > Power Adder Forums > Turbochargers
Notices
Thread Tools Display Modes
Old 08-04-2006, 11:45 PM   #1
5.0mustang5speed
5.0mustang5speed's Avatar
will twin t3 go 10;s
the t-bird turbos..i guess they are t3 or t4??? with a built 347 motor, with they be enough to run 10.50;s or faster
__________________
Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem" -- Ronald Reagan
5.0mustang5speed is offline   Reply With Quote
Old 08-05-2006, 09:09 AM   #2
Erich
Erich's Avatar
Yes. You want the bigger t-bird turbos-.60/.63 ones from the manual trans cars before 87. With your 347, you may want T3/T4 hybrids. In any event, a 302 with the 60/63 should be capable of running 10s. You will need to do something about your 11:1 compression, I would imagine. Also, if you are running a stock block, you are going to surpass the "safe" limit.
Erich
__________________
97 Laser Red GT-248A Wingless model, Built Lincoln Mark VIII motor-Procharger D1SC, 3 core IC, 60# inj
1989 Sonic Blue Notchback-DIY Twin Turbo, 42# inj, GT40P heads
Erich is offline   Reply With Quote
Old 08-05-2006, 09:23 AM   #3
Zmokedawg
Hope you have hand/eye coordination of God with 4.56 gears and tko600! With turbo's and low tens that tach needle is going to leave trails on your cluster. Have Fun!
Zmokedawg is offline   Reply With Quote
Old 08-05-2006, 10:08 AM   #4
5.0mustang5speed
on my comprsiin..i have stated before that its actally lower...i had made the cobustion chamber a tad bigger than the 58cc it was..and 11-1 is with a block that is zero decked..my pistons are in the hole (what ever a 5.4 rod 3.40 stroke is) i would say i have 10-1, i had seen where using a carb and a intercooler 10-1 is fine up to 12psi..safe limit..lol..bla bla bla..i cant hear you..lol...what is a t3/t4 hydrid ? and if i go turbo i will use a 3.27-3.73 gears..not the 4.56;s
__________________
Old 08-05-2006, 10:13 AM   #5
5.0mustang5speed
ok..i did some research..i now know what a t3/t4 hybrid turbo is..now are they made like that on certian cars, or is this a custom made deal..do i need to buy 2 t3 and 2 t4 turbos? and cross them...i am also thinking about a single turbo...what about the t70 or t76?
__________________
Old 08-05-2006, 04:19 PM   #6
mfpmax
Hybrids are crosses between T3s and T4s.
http://www.atpturbo.com/Merchant2/me...egory_Code=TBN
mfpmax is offline   Reply With Quote
Old 08-06-2006, 12:23 PM   #7
Erich
Erich's Avatar
For your set up, if you want to get turbos off a car, maybe like a pair of grand national turbos would do the trick.
Erich
__________________
Old 08-06-2006, 12:51 PM   #8
5.0mustang5speed
Erich
cool..what size are those normaly?
__________________
Old 08-06-2006, 01:01 PM   #9
MOOVS
I hope to go 10's with my T3's on drag radials.
I believe I have the power it will just depend on traction in my opinion.
I don't think launching will be the issue as I have no boost until I load the motor so with a stick car it will depend on the wheelspin on the shift into 2nd and 3rd.
JMO
Good luck!
__________________
89'LX 306,T.W.heads,perf.intake,36's,
stock cam/1.7's,70mmT.B.,T-56,3.27's,
Twin 60/63 T3's intercooled,14psi,
Evolution WG's, Meth inj.
579.2rwhp
658.6rwtq
11.0@129 kicked off track
MOOVS is offline   Reply With Quote
Old 08-06-2006, 07:46 PM   #10
xr8240
xr8240's Avatar
A pair of SC61's will.. For the slight extra cost imo new turbos are far less worry, can be less expensive than overhauling used turbo's...
Hope block is not std or http://videos.streetfire.net/hottest...0a0177e6d0.htm
Will happen......
__________________
1991 XR8 Australian Falcon TFS induction
85 Lb injectors,2 x Bosch 044 fuel pumps.
Custom cam ,E11v2 Haltech ecu...4x's 2 coil wasted spark ignition.Twin SC 61-2s with Dart block and 330/4340 Crank, Oliver rods,7.9/ comp c C.P pistons.. 482 rwkw/ 646 rwhp..A.P 4 pot brakes...TKO Tremec
xr8240 is offline   Reply With Quote
Old 08-06-2006, 10:35 PM   #11
5.0mustang5speed
that was nasty ..mine is not a roller block..but its still not a very good year(1984)
__________________
Old 08-22-2006, 07:32 PM   #12
got boost?
You won't be going tens then, at least not for too long.
__________________
"Britney spears doesn't sing. She makes vocal noises into a microphone. There is a top-notch engineer who then feeds that signal through an alchemist's collection of signal processing tools and renders something that millions of fans with no taste will buy."
got boost? is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
