Go Back   Corral.net : Ford Mustang Forums > Power Adder Forums > Superchargers
Gallery Corral Parts Store Videos Advertising Info Blogs Outside the Fence Corral Home
Thread Tools Display Modes
Old 11-02-2005, 10:37 PM   #1
fastfed
Water Injection?? Which company??
getting my car back running again. Before I put her in garage not driving state, I was planning on getting a water injection kit for my 331 S-trim setup..
Homemade or should I get an all in one kit? if so where?
Or home made any instructions??
Thanks all.
fastfed is offline   Reply With Quote
Support corral.net, please click our advertisers!
Old 11-02-2005, 10:47 PM   #2
Kobra4Kris
Kobra4Kris's Avatar
I think many will recommend the Snow kits. I have not used it but they have gotten great reviews. I like to do diy whenver possible but I think you'll find most of the kits out there are very well priced making diy pretty unecessary unless you just want to do it for fun. Couple diy links below.
http://members.cox.net/stevemonroe/AlcoholInjMod.html
http://users.frii.com/maphill/wi.html
I have an ERL Aquamist System on my VW and I can tell you it is awesome. The pump they use is specifically built for water injection, real nice setup...But the ERL systems are pretty expensive. I will most likely go with a Snow kit on the Cobra b/c of the reviews and they seem to have great customer support.
HTH
__________________
Factory Five MKIII Cobra #3892RD
Check out: MyKobra.com
302 w/ Forged Rods/Pistons Stock Iron Heads, Vortech V1-S Trim, Mighty Demon 650 Modded for Blow-thru, Polished Air Gap Intake, New T5, 4 Whl. Discs, Hallibrand Cobra III Wheels 17x9 & 17x10.5.
"She might not look like much, but she's got it where it counts kid" -Han Solo
Kobra4Kris is offline   Reply With Quote
Old 11-02-2005, 11:27 PM   #3
fastfed
HTH
So how do I choose with the snow kit.. Stage 1 or 2??
What's the diff.?
Old 11-02-2005, 11:35 PM   #4
1slowaod
I saw a car last week at the track that had the Anderson Motorsports meth kit on it.He said it worked great and he made over 1100 rwhp using it. I want to say it ran around $150. So it's way cheaper than the snow it.
__________________
93 coupe, 347, 11.5 to 1, AFR 185s, performer rpm intake,TFS stage 3 cam, 1 5/8 longtubes,
1slowaod is offline   Reply With Quote
Old 11-02-2005, 11:47 PM   #5
Michael Plummer
Trader Feedback: (30)
I can help you with picking a kit.
Stage 2 kit
reverse check valve
thats it
See ya
Michael Plummer
__________________
www.mplummerperformance.com
1994 Mustang GT Procharger D1
762rwhp and 691rwtq SAE
Michael Plummer is offline   Reply With Quote
Old 11-03-2005, 12:32 AM   #6
GroverDill
GroverDill's Avatar
What does the reverse check valve do?
GroverDill is offline   Reply With Quote
Old 11-03-2005, 07:58 AM   #7
NotoriousNotch
Formerly known as jbj302
NotoriousNotch's Avatar
Trader Feedback: (39)
Keeps boost from blowing back into the system when its not spraying.
NotoriousNotch is offline   Reply With Quote
Old 11-03-2005, 10:16 AM   #8
HRS PLY
Mr Freeze kit here........... way simple to install and was 188.00 shipped to door. See sig for results
__________________
custom Freezy74 cam......... ask him about cams.
dont claim the power if you can't mile per hour
HRS PLY is offline   Reply With Quote
Old 11-03-2005, 12:17 PM   #9
GroverDill
GroverDill's Avatar
I should likely pick one up.
Old 11-03-2005, 02:17 PM   #10
fastfed
Stage 2 kit
reverse check valve
thats it
See ya
Michael Plummer
So they are charging 100 bucks more just for a valve?
Old 11-03-2005, 04:12 PM   #11
Michael Plummer
Hi there,
For the extra money you get from Snow Performance the following:
1)150psi pump
2)Variable Controller: which will allow you to set when the kit turns-on (55% flow) and full-on. This controller also makes it easier to tune your combo.
3) 2qt reservoir: Larger container than Mr. Freeze.
4) 3 differnet sized nozzles to aid in dialing in your combo.
Hopefully thats enough because I thinks that s about it.
See ya
Michael Plummer
__________________
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
