Go Back   Corral Forums > Power Adder Forums > Turbochargers
Notices
Thread Tools Display Modes
Old 05-10-2006, 12:16 AM   #106
millhouse
millhouse's Avatar
Well...here are a couple more pics.
I finally recieved my bov...as mentioned before a tial knockoff.
And...here are a couple of crude pics of my gauges. Again, mentioned before to be autometer cobalt h20 temperature, boost and my innovative x-16 afr.
millhouse is online now   Reply With Quote
Old 05-10-2006, 12:33 AM   #107
Stang Man
Gauges look great, I've got the Cobalt series as well but I'll need a WB O2 sensor as well, gonna have to find somewhere to mount it.
How did you get your dash gauges blue? I'm guessing there is a green film on the inside of the gauges and you just replaced it with some blue?
Arron
__________________
1989 GT- Prowler Orange Pearl
Engine:
331, AFR 185, FTI cam, 90mm LMAF/30 lb, TFS-R intake, BBK LT's, X-pipe, Spintech mufflers
Suspension:MM: TA, PHB, Rear LCA's, C/C Plates, H&R Race Springs, Bilstein HD's, SFC's, Moser 28 splines, 3.73's, Cobra brakes,10th Anniv. Cobra wheels
Stang Man is offline   Reply With Quote
Old 05-10-2006, 08:13 AM   #108
millhouse
millhouse's Avatar
Arron
Blue led's. You can see my brief comparison here...
http://www.corral.net/forums/showthread.php?t=789853
__________________
1989 5.0 notch - TFS heads, Perfomer Intake, 1.7 rr's, f303 cam, Megasquirt ecu, twin .60/.48 turbos@8psi, Tremec 3550, 42lb inj, 255 pump, 24x12x3 intercooler, 3.27's, AJE Tubular k-member/A-arms, UPR LCA's
Best 1/4: 11.35 @ 125.84mph (1.77 60') 489rwhp/527rwtq
Old 05-10-2006, 06:27 PM   #109
Erich
Erich's Avatar
Looks cool with the blue.
Erich
__________________
97 Laser Red GT-248A Wingless model, Built Lincoln Mark VIII motor-Procharger D1SC, 3 core IC, 60# inj
1989 Sonic Blue Notchback-DIY Twin Turbo, 42# inj, GT40P heads
Erich is offline   Reply With Quote
Old 05-10-2006, 07:18 PM   #110
87mustang347
hey good job with the install, glad to hear you;ve worked out a lot of the bugs and are now enjoying the car. sry im a bit late to post but i got a few questions too as this has always seemed like a project id like to get into with my next stang.
how many miles does the explyer motor have
how much did you pay for it
and how did you know what size tubing to use from the turbos to the i/c and so on?
jorge
87mustang347 is offline   Reply With Quote
Old 05-10-2006, 09:44 PM   #111
millhouse
millhouse's Avatar
jorge
Lets see...the exploder motor has ~ 60k on it. I bought it for ~ $550...and I turned around and sold the upper intake for $200. Hell...after my recent headswap I sold the gt40p's for $250.
As far as sizes go...I researched the hell out of the whole combo. Turbomustangs.com has a huge database you can search through (key word being search). I try not to ask to many questions over there though as there tend to be many a-holes who bitch about it.
Old 05-10-2006, 11:49 PM   #112
87mustang347
yah i kinda figured that about them. i just went over there and it seens like they get irratated when people ask question because of the huge amounts of write ups they have. what made go with twins instead of just a single turbo?
Old 05-11-2006, 08:17 AM   #113
millhouse
millhouse's Avatar
Well, the turbo's seem to be somewhat plentyfull...fairly cheap and seem easy to rebuild. The hot side is much easier to fabricate...although the cold side is a bit more difficult. In the end it really doesnt matter...as both twins and singles can put out wicked levels of h/p.
Old 05-24-2006, 09:06 PM   #114
linkmustang1235
what are the waste gates set at
linkmustang1235 is offline   Reply With Quote
Old 05-24-2006, 10:43 PM   #115
millhouse
millhouse's Avatar
They are non-adjustable, so they are set to whatever the stock setting is. With the gt40p heads that translated into 8lbs of boost without a boost controller. With the trick flow heads I suspect the boost will go down to between 4 & 6 lbs (due to the better head flow numbers).
Old 05-24-2006, 10:48 PM   #116
linkmustang1235
cause my exteranl wastgate have 8 psi spring and i have to so that mean 16 pounds of boost
Old 05-25-2006, 07:57 AM   #117
Erich
Erich's Avatar
It will be cool to see the difference with the trick flows. You are already making "mad power". Also, since I have GT40Ps now I can evaluate the upgrade.......
Two 8# wastegates does not equal 16# of boost. Think of it simple: the wastegate is just a pressure operated diaphram. The ENTIRE system feels the boost since however many turbos there are, there is only one engine/intake. So as your turbos spool up the sytsem gets pressurized. EACH waste gate will feel about the same pressure off the compressor outlet line. So when the pressure reaches 8#, they will both push open and release to regulate the system pressure at 8.
If you plumb them to the intake instead, there is pressure drop so they can be fooled into opening at a higher compressor outlet pressure. But the wastegate settings are still not additive.
Erich
__________________
Old 05-25-2006, 08:14 AM   #118
millhouse
millhouse's Avatar
Erich
I hear ya…our combo's have been quite similar it seems since day one.
For now I'm tuning the damn megasquirt with the wastegates disconnected. Until I get a good base tune and figure out what the hell I'm doing….boost will not be an option.
Old 05-26-2006, 01:03 AM   #119
86strokerlx
86strokerlx's Avatar
Hey, Millhouse, I thought I would bring this to your attention. I recognized the first picture your posted.... couldn't figure out why for a couple minutes then I realized I saw it on eBay today. Here's the link: http://cgi.ebay.com/ebaymotors/Musta...spagenameZWDVW
Looks like the same one to me. You selling or did someone rip off your picture? Just curious. Killer project, man. I'm diggin' it, bigtime. Mike
__________________
"The enemy of my enemy is my friend."
86strokerlx is offline   Reply With Quote
Old 05-26-2006, 08:28 AM   #120
millhouse
millhouse's Avatar
Bwahhaahaaha
Yeah...it looks like someone ripped off my pic. It's all good though.
Old 06-22-2006, 05:46 AM   #121
TL351LX
TL351LX's Avatar
subscribing!
__________________
95 Crystal White Cobra/Black Leather - Bolt On's
81 T-Top Coupe - Waiting to be worked on
TL351LX is offline   Reply With Quote
Old 03-21-2008, 06:06 PM   #122
millhouse
millhouse's Avatar
Just an update. I'm re-posting the pics as my old hosting site went down. I'm adding some dyno results and vid's at the bottom of this post. Soo....well start with the hotside....
Drivers side...
Passenger side...
__________________
Old 03-21-2008, 06:07 PM   #123
millhouse
millhouse's Avatar
On to the cold side...
This is how the two turbo's come together before the intercooler
And on to the intercooler...
And the turbo drain (sence been updated with welded bungs & push-loc hose & fittings...
You can see my old oil feed setup in this image. I've sence tapped the main logg and switched to push-loc fittings for a cleaner look.
And here is the latest pic I have of the setup...again, it's now a bit cleaner and has an updated oil feed and drain setup.
Here is the dyno results...
And the link to a few of my latest vids...
http://videos.streetfire.net/video/3...ea0150d4a0.htm
http://videos.streetfire.net/video/T...Ver_141332.htm
__________________
Old 03-21-2008, 07:03 PM   #124
93gtman
93gtman's Avatar
very nice job
__________________
NY
92 Red Notch 5spd Powered by MS1 V3 running HI-RES Code.
93gtman is offline   Reply With Quote
Old 03-23-2008, 05:30 PM   #125
stockhatch
Nice setup and numbers. What does your exhaust consist of post downpipes? It almost sounds like is just piped out the back sans mufflers...Cool vids, it looks like things get interesting pretty fast once boost hits.
stockhatch is offline   Reply With Quote
Old 03-23-2008, 09:02 PM   #126
millhouse
millhouse's Avatar
Thanks!
As far as the exhuast goes...you got it! It's straight out the back...with no mufflers or cats.
Old 03-25-2008, 01:54 PM   #127
eighty8gtfiveo
Trader Feedback: (120)
awesome dyno vid.. the muppets are great.
__________________
1988 coupe- new project
1991 emerald coupe- stroked, caged & sprayed
1987 lx vert- caged and a single turbo
eighty8gtfiveo is offline   Reply With Quote
Old 03-25-2008, 02:29 PM   #128
stockhatch
Millhouse, what vesion of MS do you run, and does it control the AIC valve? Do you have any idle issues from cold to hot? Watching your AF guage under cruise and WOT, it looks like you have that tune nailed down pretty well.
Old 03-25-2008, 03:01 PM   #129
millhouse
millhouse's Avatar
I'm running the high_res version of MSNS-E…and I am now controlling the IAC valve. During the spring/summer/fall it starts very quickly and idles well….although I don't have the IAC settings nailed down yet so I end up having my idle set a bit high (900-950rpm range). I still have some tweaking to do with my AFR's…although they are pretty darn close to what I want them to be (thanks for noticing).
Old 03-25-2008, 04:10 PM   #130
93gtman
93gtman's Avatar
i am running MSNS-E where did you get the High res version? and is it better for idle and iac control. i wished you lived by me to help me fine tune mine for idle and cold start that is the hardest part. it idle ok when warm but wants to stall when cold. if you get a chance if you can send me your file so i can take a look at some of your after start and warm up wizard settings i think that is where my problem is.
__________________
NY
Old 03-25-2008, 06:00 PM   #131
millhouse
millhouse's Avatar
You can get it here... http://www.msextra.com/viewtopic.php?t=25336
If your idle pulse widths are anywhere around 3.0ms or below...it will absolutely help with better idle quality (IAC control remains the same). You will want to scale your VE table (adjust req_fuel and recalculate table) so that your high load/rpm area is a higher number (above 200 is good). This will give you a smoother table and allow you to make finer adjustments.
Unfortunately I don't have my .msq ready right now to send you. I will say that my cold starts are not the best (under 40*), but everything above that seems pretty good. I just haven't had a chance to fine tune it this year.
Old 03-25-2008, 08:38 PM   #132
93gtman
93gtman's Avatar
The settings you just mentioned can they be adjusted in the non-high res code? any if so i will check that out when i get the car started and running after the turbo install right now im mocking up everything. i will be posting my build soon on here. if you get your msq i dont care if it is perfect i just want to compare it to mine so let me know when you can send it..it will help me out alot.
thanks again man
Paul
__________________
NY
Old 03-25-2008, 08:47 PM   #133
millhouse
millhouse's Avatar
thanks again man
Paul
It will help with smoothing out the VE table...and making finer adjustments, but it will not give you the finer resolution needed at lower pulsewidths.
The next time I get on my other computer I'll see if I can't find the .msq for you. Keep in mind, it will be for reference only...as there will be quite a few differences between your and my setup.
Old 03-25-2008, 09:17 PM   #134
93gtman
93gtman's Avatar
If you can that will be great... Thank you very much millhouse for you help
Paul
__________________
NY
Old 03-26-2008, 10:05 AM   #135
Speedy911
Looks good!
Got me going crazy waiting on my kit.
Damn BG is behind -_-
Speedy911 is online now   Reply With Quote
Old 03-28-2008, 10:30 AM   #136
Sic5OhhSC
NM I just read ha
Nice, didnt know it was this old.
__________________
You own a fox mustang, the three things you should have in the glovebox is a igniton switch,TFI module, and some rubbers...-windsordeath
Sic5OhhSC is offline   Reply With Quote
Old 04-04-2008, 06:02 PM   #137
millhouse
millhouse's Avatar
More pics!
Old 04-04-2008, 06:49 PM   #138
93gtman
93gtman's Avatar
millhouse what PVC setup did you go with?
__________________
NY
Old 04-04-2008, 06:58 PM   #139
millhouse
millhouse's Avatar
I actually swapped over to a turbocoupe pcv valve along with 2 baffled valve cover breathers. I only switched in attempt to cure the dipstick tube blowing out....but I believe the actual cause was valve stem seals (which I changed out at the same time).
Old 04-04-2008, 09:21 PM   #140
got9lbs
millhouse- couple of quick ???? First I assume you had to swap out the stock p/s for a different year? Also no chance that you could run a/c if you wanted to ?
got9lbs is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
