Go Back   Corral Forums > Modular Tech Forums > SVT & DOHC
Notices
Thread Tools Display Modes
Old 02-12-2004, 01:27 AM   #1
white02stang
FR550 valvetrain on Mach1???
I know the machs have different heads than the 01 cobras so does anyone know if this kit would even fit on a mach 1. Also how much HP are you getting from this mod from a just bolt on car with no power adders? What are the diferences in the cam sizes too.
__________________
90 lx hatchback-sold
95 gt supercharged-sold
02 gt bolt-ons 13.2-sold
03 mach1 100shot-sold ;97 cobra-mods coming soon
white02stang is offline   Reply With Quote
Support corral.net, please click our advertisers!
Old 02-12-2004, 07:05 AM   #2
SLVR01COBRA
I believe the mach 1 has the same heads as the NEW cobra and marauder. I think they are 99 cobra intake cams and navigator exhaust cams. I think the FR500 kit should fit any tumble port head.
__________________
2001 Mustang Cobra RIP 6/13/04 2:30am EST
Dallas Speed cal for mustang Tremec $90 shipped.
www.amfracing.com
SLVR01COBRA is offline   Reply With Quote
Old 02-12-2004, 08:23 AM   #3
blacksnake305
blacksnake305's Avatar
Yes. it will fit! I can get you the FR500 valvetrain kit for $1250 out the door: administrator@eastsidemotorsports.net
Chris
__________________
H/C/KB 01 Cobra
blacksnake305 is offline   Reply With Quote
Old 02-12-2004, 11:28 AM   #4
hobbstc
Will the FR500 kit fit my B heads on my 97?
hobbstc is offline   Reply With Quote
Old 02-12-2004, 11:33 AM   #5
Modular Performance
Modular Performance's Avatar
The FR valvetrain will fit ALL '93 - current 4.6/5.4 DOHC heads.
__________________
Mike or John
Modular Performance
248 374-9109
Modular Performance is offline   Reply With Quote
Old 02-12-2004, 10:42 PM   #6
jtack
Whats included in the fr500 kit and how much hp increase on an otherwise stock 4v?
__________________
03 Mach 1 5sp DSG
JLT CAI
PHP Intake Spacer
Pro 5.0 Shifter
Borla Stinger Cat Back
4.30's
Modified Ford Trac Loc
283 RWP Stock
301 Torque Stock
jtack is offline   Reply With Quote
Old 02-13-2004, 10:29 AM   #7
99SVTAddict
E-mail Chris at administrator@eastsidemotorsports.net . He added this to his own motor and has worked with others that have done so as well. He just doesn't frequent this board everyday, so e-mail will be much faster for you.
99SVTAddict is offline   Reply With Quote
Old 02-13-2004, 12:29 PM   #8
KIKN ASP
Consider posting his reply, since quite a few of us would like to know the answer to your question. I'm sure he doesn't want to get several emails asking the same questions. Thanks.
__________________
KIKN ASP
2001 Black Cobra Coupe
#372 of 3867
MODS:
Drivetrain: 4.10 gears, Steeda tri-Ax, MGW shift handle
Power: 87mm Pro-M MAF, Bassani X-Pipe, MAC Cat-Back, JBA 1 5/8 shorty headers, Steeda Pullies, JLT CAI, Custom Tuned SCT
Suspension: PHP Brace & IRS bushings, MM IRS subframe bushings, MM full length SFC, MM coil-overs, Bilstein shocks & struts, MM CC Plates
Misc: 17X9 SSR Polished Aluminum Wheels, 285 Kuhmo MXs, FR500 Steering wheel
Dyno #s: (SAE corrected) 309 rwhp/ 304 rwtq
KIKN ASP is offline   Reply With Quote
Old 02-13-2004, 05:03 PM   #9
jtack
I sent an email and I will post his reply as soon as I get it.
__________________
03 Mach 1 5sp DSG
JLT CAI
PHP Intake Spacer
Pro 5.0 Shifter
4.30's
283 RWP Stock
301 Torque Stock
Old 02-13-2004, 06:05 PM   #10
KIKN ASP
Thanks.
__________________
KIKN ASP
#372 of 3867
MODS:
Old 02-14-2004, 09:41 AM   #11
Boss 330
Moderator
Boss 330's Avatar
The FR500 kit has...Cams, springs, valves, cam followers,valve stem seals,and four new sprocket bolts. All high quality parts. It's worth about 18-20 hp on a mild engine and I have seen it make 800+ at 20 pounds of boost.
Boss 330 is offline   Reply With Quote
Old 02-14-2004, 10:46 AM   #12
Angus
Angus's Avatar
Re: FR550 valvetrain on Mach1???
I'm not too sure why you would want to do this swap on a Mach 1 4V???
Hp/Tq improvements probably wouldn't be as high on the later '03+ improved heads as on the earlier '96 - '01 heads...
__________________
Best N/A ET on the factory long-block: 11.16 @ 120.24 mph
Angus is offline   Reply With Quote
Old 02-14-2004, 09:37 PM   #13
jtack
Heres the reply I got from chris:
The FR500 Valvetrain Kit comes with the following items:
FR500 cams .472 lift @.050 duration around 209x/219i
High flow stainless steel valves (as good or better than any on the market)
High rev/higher strength rockers
High lift/high strength springs w/ titanium retainers
As far as power is concerned, Its hard to know. FRPP doesn't give any power figures for the kit by itself, and when i put the kit on my motor, i did alot of other things as well. But if I was forced to guess, i'd say about 15rwhp & 25rwtq (on a bone stock application). The FR500 valvetrain kits' main focus is to provide a strong flat TQ curve while increasing HP as well. You will NOT see peaky gains with these cams. Rather, you'll see a TQ/HP gain across the curve. Lots of people tend to focus on "peak" numbers, but anyone who's 'informed' understands that its the "Area Under the Curve" that counts. If you interested in the kit, let me know. I can have it to your door in 3 days...
I wonder what an upper/lower ported and polished, spacer, and fr500 kit would gain?
__________________
03 Mach 1 5sp DSG
JLT CAI
PHP Intake Spacer
Pro 5.0 Shifter
4.30's
283 RWP Stock
301 Torque Stock
Old 02-14-2004, 09:52 PM   #14
MP John
MP John's Avatar
High rev/higher strength rockers No - Just some old 4.0L
High lift/high strength springs w/ titanium retainers Same old stock retainers
__________________
MP John
Modular Performance
FelPro head gasket sale
Quality parts at affordable prices.
248 446-8767
MP John is offline   Reply With Quote
Old 02-14-2004, 11:50 PM   #15
Boss 330
Moderator
Boss 330's Avatar
FR500 cams.... Checked with a solid adjuster in place..Int.214@.050 .468 lift Exh.204@.050 .469 lift
Springs....avg. 70# seat and avg. 200# open
Old 02-16-2004, 09:39 AM   #16
blacksnake305
good info boss. The info i provided was based on a chart i used at Hensler Racing. And that is because FRPP does not advertise the cam specs as we would like. Accordinng to Hensler's conversion chart, 12mm lift = .472@050. As for the dur, i knew i was close, but not right on the money...
__________________
H/C/KB 01 Cobra
Old 02-16-2004, 09:41 AM   #17
blacksnake305
Not according to my sources. thanks for your opinion though...
And i've seen the rockers, I dont know where they sourced them from but i do know that they ARE much beefier than my stockers (the whole body of the rocker that is)...
__________________
H/C/KB 01 Cobra
Old 02-16-2004, 10:16 AM   #18
KIKN ASP
How involved is the install of the kit? In other words, how many hours of labor (estimate) to install?
__________________
KIKN ASP
#372 of 3867
MODS:
Old 02-16-2004, 06:25 PM   #19
MP John
MP John's Avatar
Let me set you straight - again.
The rockers used in the FR500 kit were originally used in the 4.0L SOHC engine. Ford changed the 4.0L SOHC rockers for cost cutting reasons a couple of years ago. These FR rockers are not special design/high performance pieces. Just old stock 4.0L SOHC.
That's a fact not an opinion!
__________________
MP John
Modular Performance
248 446-8767
Old 02-16-2004, 06:31 PM   #20
MP John
MP John's Avatar
You need to pull the engine, remove the heads etc etc etc. Installing the kit requires a valve job.
If the heads are off the block or soon going to be, it's the best bang for the buck out there.
__________________
MP John
Modular Performance
248 446-8767
Old 02-16-2004, 08:35 PM   #21
johndt351
johndt351's Avatar
do you have to get new lash adjusters also, or can you reuse your old ones?
Are the angles different on the new valves?
__________________
2006 IHRA Divisional Qualifier Mod Eliminator
'04 Black SVT Focus
'23 T-bucket Altered-Ford Bodied, Chevy motivated
johndt351 is offline   Reply With Quote
Old 02-16-2004, 08:56 PM   #22
Boss 330
Moderator
Boss 330's Avatar
No..
No..
Old 02-16-2004, 09:36 PM   #23
johndt351
johndt351's Avatar
thanks
__________________
'04 Black SVT Focus
Old 04-26-2007, 07:57 PM   #24
TommyD
TommyD's Avatar
So is it worth trying to find some of these roller finger followers?
TommyD is offline   Reply With Quote
Old 04-29-2007, 01:42 PM   #25
swtmustangman
swtmustangman's Avatar
I've searched for days and cannot find a sound clip of the fr500 valvetrain. I really would like to hear how they sound. I know they won't lobe very much, but I still want to hear a difference. The amount of parts included in this kit is awesome. You can't piece this kit together any cheaper! Can't wait to order mine....anyone know where I can get a sound clip of a near stock 4v with fr500 valvetrain?
swtmustangman is offline   Reply With Quote
Old 04-29-2007, 02:36 PM   #26
Bob Cosby
Corral Charter Member
Bob Cosby's Avatar
http://videos.streetfire.net/search/...6afe885eee.htm (don't be fooled by the dog in the beginning....LOL)
http://media.putfile.com/FR500-Cam-kit
__________________
Bob Cosby, USN (Retired)
99 Cobra
2005 Harley FXDWG Dyna Wide Glide
Bob Cosby is offline   Reply With Quote
Old 04-29-2007, 04:24 PM   #27
swtmustangman
wow it does sound a lot like stock...you have to really listen to hear any lobe. Still cool in my book. How is the performance with this kit (seat of pants wise)?
Old 04-29-2007, 06:30 PM   #28
Rev Happy
Rev Happy's Avatar
Is this valvetrain good to 7500+rpm?
Rev Happy is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
