Go Back   Corral.net : Ford Mustang Forums > General Tech Forums > Wheels and Tires
Thread Tools Display Modes
Old 05-14-2003, 08:04 PM   #1
Cool Focker
Arrow Foxbody Wheel Picture Thread
Post any and all pics of Fox body Mustangs with any kind of wheels. Please state any applicable info, such as; wheel make, model, size, all tire sizes (front/rear), backspacing, where to buy them, etc, etc.
Thanks everyone,
C. Focker
__________________
its an LX
Cool Focker is offline   Reply With Quote
Old 05-15-2003, 06:34 PM   #2
duddor
duddor's Avatar
http://www.mustangworld.com/ourpics/...38/kevins1.JPG
91 Lx Coupe,17x8 98 cobras w/ 245-45-17 nittos 555's,cobra front brakes,rear drum conversion soon to be disc
__________________
91 LX Coupe 5.0, Built on 5/30/91, 1 of 91
Light Crystal Blue Met./Black Int.
AFR/FTI/Vortech Combo
498/468 Tuned by Murillo
03 F150 SC 5.4 FX4...PNYPULR
81 F100 4.9 700k miles...DD
02 686 Grizzly...Mud toy
06 400 Big Bear...Mud toy
http://forums.rpmplanets.com/sigimages/1061.png
Vote on my stang here
duddor is offline   Reply With Quote
Old 05-21-2003, 03:47 AM   #3
PROCHARGER
__________________
Too many projects not enough time
PROCHARGER is offline   Reply With Quote
Old 05-21-2003, 11:36 PM   #4
BlownGT92
Here is link to my site. I have Roh snyper 17x9 wheels on my gt.
http://mywebpage.netscape.com/chevyh.../carpage1.html
__________________
92 GT-- Procharged 358W, Art Carr AOD, 3800 stall
69 Mustang S-code Coupe -- Mild 351C Cleveland/C4, tcp front coilover conversion, tcp ps rack, work in progress
BlownGT92 is offline   Reply With Quote
Old 05-22-2003, 12:24 PM   #5
ChadsMach1
Member
93 LX notch with stock Bullitt wheels. I love it!
__________________
Chad
ChadsMach1 is offline   Reply With Quote
Old 05-22-2003, 03:00 PM   #6
WhiteLX
WhiteLX's Avatar
MSW Sport
17x8.5
255/40R17
4lug
custom finish
no longer manufactured
__________________
1992 5.0 coupe - P1200 Procharger - 421rwhp/426 ft-lbs
1986 Merkur XR4Ti - 2.3L turbo - 256rwhp/262ft-lbs
WhiteLX is offline   Reply With Quote
Old 05-25-2003, 12:34 PM   #7
anthony washington
anthony washington's Avatar
I HAVE AN WITH 94 GT 17'S ON IT WITH 235-45-17 IN FRONT AND 255-40-17 IN THE REAR . THE OTHER PICS HAS 225 -50-15 FRONT AND24-50-15 REAR WOULD HAVE POST THEM HERE COULDN'T FIGURE OUT HOW TO http://groups.msn.com/picturesofyourcars/photoalbums LOOK UNDER HANKGTS
anthony washington is offline   Reply With Quote
Old 05-30-2003, 10:15 AM   #8
mikeys5.0
89 GT with Chrome 03 Cobras.
I got them from Todd at Discount Direct. They are 17X9 with the 20mm offset. The Tires are Kumo 245/45/17. The only problems I had was that my car is lowered so the wheels would rub the A-arms. I had to install a set of Rack Limiters from Ford.
See my Sig for pics!
__________________
89 Mustang GT:
Brand new built 306 by Tachyon
Ported Dart heads, Port matched Cobra Intake, 1.6 Studded Rockers, FMS "E" Cam Advance 4 degrees, 75mm PRO-M Bullet, 65mm TB, 24lb FMS INJ, 255 FP, Steeda Clutch, Mac Cold Air Induction, Mac Headers, Off Road H-Pipe, Dynomax Exhaust, and 3:55 Gear.
Suspension:
New FMS "C" springs
Complete set of Tokico Shocks & struts
Subframe Connectors
Wheels:
A set of Chrome 4-lug 17X9 03 Cobras
http://www.alwaysrecord.com/Stang5.htm
mikeys5.0 is offline   Reply With Quote
Old 05-30-2003, 10:15 AM   #9
snipe656
Turbo Wizard
snipe656's Avatar
I do not think the wheels on either of my cars are made any longer, but here you go.
My LX with 17x8.5 fronts(255/45s) and 17x9.5 rears(275/40s), chromed ROH ZR6 wheels(center caps off in the picture). I had to trim my front fenders when I went to the Griggs front suspension and had to roll the rear fenders some to clear those tires, a 265 tire would have required no rolling.
http://www.happyhacker.com/images/Pi...tang_Dside.jpg
My Saleen with 17x8 fronts(235/45s) and 17x9 rears(245/45s), Stern wheels. My rear fenders have been rolled a ton and I still get some tire rub on hard bumps, car has a Cobra IRS in it so I think that might be wider than the 8.8 that was originally in there with Mark VII brakes. I probably am going to change these wheels out with something, just not sure what since I am unsure what will fit all around on it.
http://www.happyhacker.com/images/Pi...leen_Dside.jpg
__________________
--Aaron Rouse http://www.happyhacker.com/
2009 335d - Daily driven "rod knocker"
2003 F250 PSD - Backup "rod knocker"
1985 300SD - Money pit "rod knocker"
snipe656 is offline   Reply With Quote
Old 06-01-2003, 05:27 PM   #10
Hissing Cobra
Hissing Cobra's Avatar
Here's my 1979 Cobra with Weld Draglites.
Front:
15x7 with 215-50-15's (4.5" backspacing)
B.F. Goodrich Radial T/A's - 215-60-15
Back:
15x8's with 295-50-15's (4.5" backspacing)
B.F. Goodrich Radial T/A's - 295-50-15
__________________
1979 Mustang Cobra
5.0/5-Speed/4.30's
1989 Mustang LX
5.0/5-Speed/3.73's
Hissing Cobra is offline   Reply With Quote
Old 06-04-2003, 09:49 PM   #11
Oktavius
Moderator
Oktavius's Avatar
From the looks, I do not believe StangerBanger is using any spacers. His setup is similar to mine, with the SN95 axles in the back (.75" longer on each side) and the SN95 spindles up front (he has '94-'95 spindles, I am using the '96+). The wheels are factory '98 GT rims which are 17X8s. I use the same type of rims (just not as nice looking) for my autocross rubbers.
__________________
Tim ||||||| ||||||| |||||||
07 Subie Impreza - DD
92 GT SSP
Sent from my Droid using Tapatalk
Oktavius is offline   Reply With Quote
Old 06-08-2003, 06:28 PM   #12
466coupe
Member
466coupe's Avatar
15x9 w/6" bs bogarts dragon fly stars 28x10.5 et drags 15 x 3.5 fronts
__________________
Goin for broke Oh wait a sec I'm already there! For sale low mileage brunette, doesn't cook or clean. Take over payments!
466coupe is offline   Reply With Quote
Old 06-12-2003, 12:13 PM   #13
snipe656
Turbo Wizard
snipe656's Avatar
The rear brakes make your rear end wider? The link you gave were for anniversery wheels, these the ones you got?
http://www.gefracing.com/Merchant2/m...ry_Code=WHEELS
__________________
Old 07-09-2003, 12:08 AM   #14
Jim5pt0
Jim5pt0's Avatar
__________________
89 LX
359W Turbo
Jim5pt0 is offline   Reply With Quote
Old 07-13-2003, 03:06 PM   #15
newdy22
newdy22's Avatar
4 lug 17" Pony R's with Dunlop SP5000 245/45's on all four corners.
__________________
1988 GT
-13" Cobra Brakes, '95 GT Rear Disc, , Aluminum Drive Shaft, Rear UCA's, Front LCA's w/ SN95 Ball Joints, 3:55's,
-Underdrive Pullies
-Maximum Motorsports: Caster Camber Plates, Rear LCA's
-Kenny Brown: Strut Tower Brace, G-Load Brace, Sub Frame Connectors
-Pro 5.0 Shifter
-K&N Filter
-Eibach Pro-Rate Springs
-Flowmaster 2 Chamber
Car Domain Page
Click here to email me.
newdy22 is offline   Reply With Quote
Old 07-13-2003, 03:30 PM   #16
WhiteLX
WhiteLX's Avatar
Check out this thread for many pictures of factory Ford wheels on Fox body LX Mustangs (mostly notchbacks)
http://www.socalhorsepower.com/forum...=&postid=18416
Eric
__________________
Old 07-19-2003, 02:51 AM   #17
Madmiamian
Madmiamian's Avatar
My foxy lady
Madmiamian is offline   Reply With Quote
Old 07-22-2003, 05:22 AM   #18
ShortThrow5.0
ShortThrow5.0's Avatar
Damn, those 5-Lug 03 Cobra wheels look awesome..
-LJ
__________________
Luke
'93 MUSTANG 5.0 LX
(Mod list to come..)
ShortThrow5.0 is offline   Reply With Quote
Old 07-23-2003, 01:35 AM   #19
CAM D
CAM D's Avatar
03 cobra wheels
Short throw..... Waite til it get out of the body shop in a couple weeks. It's going to be a total transformation into a Cobra Clone. I'll post pics when it gets back.
Cam
CAM D is offline   Reply With Quote
Old 07-24-2003, 12:48 AM   #20
Madmiamian
Madmiamian's Avatar
They are real close. I say dead on the fender.
Old 07-30-2003, 03:25 PM   #21
Hokie D
Hokie D's Avatar
Wow! Those 94-95 GT 17" wheels still look great on a fox. I also like the 1998 GT wheels on a Fox. Too bad they're all 5 lug. Hate spending extra money on something that ain't broke.
My stock 16" ponies are ugly - hate 'em!! Thinking about 4 lug ROH ZS next time I need new tires...
http://home.socal.rr.com/mskwik/93LX50.html
__________________
Reef Blue 1993 LX Notch: Dugan Racing X-Drilled Rotors, Kenny Brown Subframes, Eibach Pro Springs, Steeda Camber Plates, Baumann Shift Kit, 3:73 Motorsport Gears, ADS Computer Chip, Motorsport Underdrive Pulleys, 1.5" Cervini Mach I Ram Air Hood, Flowmaster 2.5" Catback Exhaust, Griffin 31x19" Radiator, PA-Perf 130-amp 3G Upgrade
130-Amp 3G Alternator Upgrade Project <--> Hokie D's Ride
Hokie D is offline   Reply With Quote
Old 07-31-2003, 10:04 PM   #22
duddor
duddor's Avatar
the 03 cobras are 17x9 w/ 275/40zr17 tires
__________________
Old 08-06-2003, 03:15 PM   #23
twokota
Member
__________________
Hey guys, what's going on in this sig?
twokota is offline   Reply With Quote
Old 08-06-2003, 08:28 PM   #24
duddor
duddor's Avatar
__________________
Old 08-15-2003, 10:41 AM   #25
88lx5.8
Here's my car, Moda R6 18", look for 1988 5.8 LX, dark blue coupe:
http://dfwstangs.net/forums/showthre...hreadid=113171
__________________
1988 LX 5.8L S/trim'd, EFI Coupe
1963 Ford Falcon Sprint Hardtop
1956 Ford Thunderbird
88lx5.8 is offline   Reply With Quote
Old 08-18-2003, 05:06 PM   #26
93FIVEOH
93FIVEOH's Avatar
Man, that is one of the nicest coupes I have seen in a while. I love the rim combo on there. Those wheels are definitely different, I have never seen those on a fox-body before. If you don't mind me asking, how much did those wheels run you? If you want, I can post the pic on here for you. Nice car!!!!
__________________
Kevin
93FIVEOH is offline   Reply With Quote
Old 08-19-2003, 09:45 AM   #27
88lx5.8
Originally posted by 93FIVEOH
One more thing, those rims have the same bolt pattern with that Ford brake kit, but just SN-95 spacing?
From what I researched and found online, the Moda wheel line is made by Radius in Italy, as it is cast on the wheel inside and came with both sets of center caps. Here is the Radius site, there is a .pdf you can download with all the models, offsets, and sizes:
http://www.radius-autotech.com/
Or look at tirerack.com for the Moda series.
The bolt pattern is 5 on 114.3 mm (= to 5 on 4.5" if you convert mm to "s), same as M2300k brake and the SN95. Spacing happened to work well on the Fox, but of course the SN95 has tons more room for wheels. I find the perfect set up for Fox w/ m2300 k is 8 wide w/ about 5.75 b/s and 9 wide w/ about 6.75 b/s. (perfect for me means looks wide and filled up but does not rub on turns or bumps - sure you can go wider but it gets to be a hassle in my opinion)
__________________
Old 08-19-2003, 02:01 PM   #28
93FIVEOH
93FIVEOH's Avatar
Thanks for the info. I totally agree 100% with your theory.
__________________
Kevin
Old 08-21-2003, 11:20 PM   #29
duddor
duddor's Avatar
pupdog, thats one of the sweetest verts I've ever seen. Nice job.
__________________
Old 08-22-2003, 12:23 AM   #30
93FIVEOH
93FIVEOH's Avatar
Pupdog....nice!!!!! 1993 Cobra wheels are IMO the best looking wheels on a fox-body. Chrome makes them look even twice as nice.
__________________
Kevin
Old 08-22-2003, 07:26 AM   #31
pupdog5oh
Member
pupdog5oh's Avatar
Thanks alot for the compliments. It took me a while to find those wheels in the condition I was looking for.
__________________
Craig
Click Here For My POS
91 GT Vert
Edelbrock Heads/RPM II Intake/Paxton Novi 9psi
36# Injectors, Pro-M 75mm bullet
Stock cam w/1.72RR's
Kenne Bell BAP, No FMU, Higgins Chip
Mac 1 5/8 shorties, 2 1/2 off road H
Tremec 3550, Eaton 31 spline, Mosers
SSBC rear disk conversion
429HP/408 ft-lbs R.I.P.!!
pupdog5oh is offline   Reply With Quote
Old 08-24-2003, 12:32 PM   #32
Fiveofeen
Formerly known as lxnogt
Fiveofeen's Avatar
16" cobra r's 5 lug. these are temp wheels while the car gets painted. then its sonic blue paint, and 17x8 & 17x10.5 bullets w/ 245' up front 275' or 315 out back.
Edit: Here is what I ended up doing to it. 17x9's all around with 245's and 275's for tires. (Its been done a long time, dont worry it didnt take six years to pull it off!)
__________________
1990 LX Hatchback Sonic Blue
All the rad mods and a few lame ones
Fiveofeen is offline   Reply With Quote
Old 08-24-2003, 12:40 PM   #33
WhiteLX
WhiteLX's Avatar
How are you going to fit 10.5s in the back?
__________________
Old 08-25-2003, 03:49 PM   #34
Lickmstickmman
Lickmstickmman's Avatar
LXNOGT, hope that combo works for you... I have 17x8 bullits on a 93gt with Kumho 255/50-17s and they rub the inside and the quad shock. I made a poor tire size choice for the back, should have went with 245/50-17 like the front! But I wanted to fill the wheel well better, now it's too much...live and learn!
Here is a link to mine and a buddies fox bodies with the new bullets on, mine is the red one.
http://f1.pg.photos.yahoo.com/ph/lic...rl.jpg&.view=t
Lickmstickmman is offline   Reply With Quote
Old 08-25-2003, 09:28 PM   #35
Cool Focker
Both cars look great, but we need some better pics......Bullets on Fox bodies are hot......post more and better pics!!!
C. Focker
__________________
its an LX
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
