Go Back   Corral Forums > Windsor Tech Forums > 94/95 Tech
Notices
Gallery Corral Parts Store Videos Advertising Info Blogs Corral Home
Thread Tools Display Modes
Old 10-28-2002, 11:40 AM   #1
P63
P63's Avatar
Thumbs up Got the C&L mass air working!
Thanks for the input from the other thread.
Saturday I finally had time to take another run at installing everything. I disassembled the stock intake north of the tb. It took about ten minutes. I also disconnected the battery.
I took the air sensor out. Expending two dabs of alcohol and two q-tips, I cleaned the black soot off the upwind side of the air sensor. (Being a rookie, I didn't want to remove the black stuff, then log on to the corral and have people say "you did WHAT? That black stuff NEEDS to be there!" A note to do so in C&L's instructions would have been great.)
I put everything back together, 20 minutes. The only difference from my previous attempt is that this time I put the air sensor on TOP of the Mass Air unit.
Reconnected the battery.
Checked everything.
Started up the biotch. It purred like a kitten. When revved, it roared like a lion. I drove it gently around the block to make sure it wouldn't die when it warmed up.
Growing in confidence, I went out to an empty strip of road with a 50mph speed limit, waited for a light to turn green, and hammered it. My SOTPM tells me I now have 275 rwhp, up from 175rwhp. (Hold the bs flag for now, more at the end.)
This morning I just touched the starter switch and the car fired to life- as opposed to the normal one second of cranking.
And usually the car starts starving for air around 4k. Now it pulls HARD up to redline. (You supercharged guys would probably laugh at what I call hard acceleration, but relative to what it was is day vs night.)
So did a C&L intake kit alone increase my rwhp by 100? We all know that's not possible. I think the big culprit here was the caked-on soot on my air sensor. Removing the crud, my computer now knows how much air is being ingested, and I presume that's a good thing.
And let me just relate the incredible satisfaction of installing a $300 kit which, along with cleaning the sensor, transformed the car from wheezing above 4k to healthy-to-redline.
At this point I am a satisfied C&L user. If I get the time I will give them a call and offer to write up a REAL installation instruction sheet.
Thanks to everyone who contributed to my previous thread.
__________________
Victor Marshall
Copyright 2009.
May be quoted on the Corral. Not to be otherwise copied or reprinted without permission.
P63 is offline   Reply With Quote
Support corral.net, please click our advertisers!
Old 10-28-2002, 12:29 PM   #2
MKoebra95
Glad it works! The MAF upgrade was my favorite mod and it yielded awesome results for such little time. 15+hp and ft-lbs is a welcomed improvement to any car. You probably gained more, but like you said some of it came from cleaning the MAF wires.
__________________
Matt.
95 Cobra Convertible #298 of 1003.
261.7rwhp and 299.5rw ft-lbs
dyno sheet
Bunch of NA mods just aren't cutting it, so JYTT here I come...
MKoebra95 is offline   Reply With Quote
Old 10-28-2002, 04:32 PM   #3
rel3rd
rel3rd's Avatar
Trader Feedback: (33)
Thumbs up
Victor, Glad to hear you got it straightened out.
Hopefully, they'll take you up on your offer to write some directions that have everything in them..lol.
BTW, did you also add the "sleeve" on the throttle body??
You know, the one that nobody got...
__________________
2000 Camaro SS
Baby Cam + Converter = mid 11's
1991 Mustang LX
Father & Son Project
rel3rd is offline   Reply With Quote
Old 10-28-2002, 05:22 PM   #4
P63
P63's Avatar
Yes, I put the extra sleeve on. It fit tightly over the tb, and the sleeve on the inlet pipe fit tightly on top of that. Then the whole mess got tightened down with a clamp. I doubt it ever was an issue.
__________________
Victor Marshall
Copyright 2009.
Old 10-28-2002, 05:38 PM   #5
95GTS
US Navy Active Duty
95GTS's Avatar
Re: Got the C&L mass air working!
For two years, I had problems with my car. Even after a dyno-tune, my car died at idle, died in sharp left hand turns, etc. Everyone, including the dyno-tuner said it was the 73mm C&L. Those meters just don't work well with our cars is all I heard. Just when I was about to get rid of it, someone recommended that I clean the air sensor. That little bottle of electrical cleaner solved all my problems.
I know our set-ups are different but my 76mm works flawless. No idle or drivability problems. I now make sure to keep the air sensor clean and have yet to have anymore problems. Glad to hear it worked out for you.
__________________
The average Navy pilot, despite the sometimes swaggering exterior, is very much capable of such feelings as love, affection, intimacy and caring. These feelings just don't involve anyone else.
95GTS is offline   Reply With Quote
Old 10-29-2002, 12:21 AM   #6
MKoebra95
Re: Re: Got the C&L mass air working!
Did you have it dynoed at Abacus before March of this year? When I did my 3 MAF dyno thrash, Chuck mentioned a C&L guy that couldn't get anything to work tuning wise. Just curious if that was you.
BTW, I'm in Coronado now. Sorry I never got a chance to get together with you. How's the car running?
__________________
Matt.
dyno sheet
Old 10-29-2002, 06:11 AM   #7
95GTS
US Navy Active Duty
95GTS's Avatar
Re: Re: Re: Got the C&L mass air working!
I'm just jealous that you're in San Diego. I miss that place.
Nope, wasn't me. It's possible that my car could probably be a bit more fine tuned with a Pro-m 77, but my car runs great as is. I'm thinking why fix it if it anin't broke.
Old 10-29-2002, 03:41 PM   #8
MKoebra95
Re: Re: Re: Re: Got the C&L mass air working!
Probably the best advice anyone could give. Then again, it all depends on what the definition of "is" is errrr I mean "broke's" definition. I just bought a $115 FRPP 65mm throttle body that isn't polished like the current one I own. This one matches my dull upper. I'm keeping the polished 65 incase I ever polish the rest of the engine. You've seen my car, it is by no means a show car though so making it bling bling isn't likely
Anyway, sorry to hijack your post P63. If you hear of any Mustang get togethers, let me know! Also, where do we have to go to race? I've heard a lot about cracking down on street racing (not that I do that) and the usual answer is that the city needs to build a racetrack. How far away is the nearest one?
TIA.
__________________
Matt.
dyno sheet
Old 10-29-2002, 05:26 PM   #9
P63
P63's Avatar
The drag strip is in Carlsebad. A couple Sandy Eggans go there, I think Laura and Ron do. Maybe Jason will be there.
I believe there is 1/8 mile drag racing and perhaps autocrossing that happen occassionally at Qualcomm Stadium.
Sorry I don't have contact info for Total Performance. 411 should give you their number, they are in Santee. They have a lot of nice hardware out there. Both times I was there they had two or three 351 Vobras in back. Greg is the owner and he does consciencious work. Bob at the front desk is Greg's step dad.
__________________
Victor Marshall
Copyright 2009.
Old 10-30-2002, 01:00 AM   #10
GusPQ
GusPQ's Avatar
The drag racing Qualcomm is going on every Friday till the end of the year.
GusPQ is offline   Reply With Quote
Old 10-30-2002, 10:19 AM   #11
Sinful
Sinful's Avatar
yeah
Sinful is offline   Reply With Quote
Old 12-06-2002, 01:51 AM   #12
KenI
KenI's Avatar
Hows the car running Victor? Still OK? Are you still at TS?
We should get a group of San Diegans together. 95GTS can fly out for old time sake.
Another aviator, 2 in one thread...what do you fly? (MKoebra95)
__________________
'95 Cobra w/Vortech
Dyno:
RWHP 515.4
RWTQ 454.8
2004 ZO6
KenI is offline   Reply With Quote
Old 12-06-2002, 02:28 AM   #13
Sinful
Sinful's Avatar
im in
Old 12-06-2002, 11:33 AM   #14
MKoebra95
I fly Navy MH-60S's, at least I will when I'm done with training. I came from H-3's.
I have a set of 3.55 gears that I need installed. Does anyone have a suggestion of where to take it or where NOT to take it out in SD?
95GTS (Chris) suggested Swanson Performance. I'm going to go with that unless you guys know of some place better.
__________________
Matt.
dyno sheet
Old 12-06-2002, 11:40 AM   #15
95GTS
US Navy Active Duty
95GTS's Avatar
Matt, go to Danny, you won't be disappointed. He does excellent work though it is about a two hour drive.
By the way, what is the MH-60, as apposed to the other variants? You're not going to do plane gaurd are you? That has to be the worst assignment, IMO ?
Old 12-06-2002, 12:01 PM   #16
KenI
KenI's Avatar
Dannys cool. http://www.swansonperformance.com Hes not very close though. He did my dyno tune for me. For someplace colser you might try Total Performance in Santee ((619) 562-9894). George out there has a very nice 95 Cobra vert also. http://www.swansonperformance.com/healey.html
__________________
'95 Cobra w/Vortech
Dyno:
RWHP 515.4
RWTQ 454.8
2004 ZO6
Old 12-07-2002, 07:55 PM   #17
MKoebra95
No plane guard for me, not anytime soon. The newest 60 is replacing the 46 for vertrep. It has an all glass cockpit with 4 computer screens. WAAAAYY more modern than the steam gauges on the H-3. What's that phrase? Like Darth Vader's bathroom???
__________________
Matt.
dyno sheet
Old 12-09-2002, 02:58 PM   #18
P63
P63's Avatar
Ken, I'm still TS. The cobra is not a slobra any more.
__________________
Victor Marshall
Copyright 2009.
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© 2010 Corral.net
