Go Back   Corral.net : Ford Mustang Forums > General Tech Forums > General Mustang Tech
Thread Tools Display Modes
Old 03-06-2010, 03:04 PM   #1
Duspan
Shifter handle length?
Does anybody have the lengths of the handles for the triax and pro 5.0? Also, out of the two, which one has the shortest shifts? Thanks guys
Duspan is offline   Reply With Quote
Old 03-06-2010, 03:10 PM   #2
Time only
Time only's Avatar
www.clickclickracing.com
The source for all our AOD questions.
Time only is offline   Reply With Quote
Old 03-06-2010, 03:18 PM   #3
Duspan
For a T5.
Old 03-06-2010, 03:38 PM   #4
ALMOST STOCK
ALMOST STOCK's Avatar
Hopefully this helps?
[IMG].photobucket.com/albums/v489/almoststock/triax_design.jpg[/IMG]
__________________
MY CAR
ALMOST STOCK is offline   Reply With Quote
Old 03-07-2010, 09:01 AM   #5
qtrracer
Trader Feedback: (15)
I replaced the factory Pro 5.0 handle with a Tri-ax handle because (i) the 5.0 was too short requiring more effort than I preferred, and (ii) the Tri-ax provided me with a better seating position. The Tri-ax is noticiably longer with a more rearward/D/S configuration.
qtrracer is offline   Reply With Quote
Old 03-07-2010, 12:11 PM   #6
Duspan
Thanks guys, that is the kind of answer I was looking for.
Old 03-07-2010, 03:56 PM   #7
1trkpny95
1trkpny95's Avatar
Trader Feedback: (40)
Yes the Pro 5.0 handle is definitely shorter than the tri-ax. Pro 5.0 FTW anyday
__________________
'95 GT: FordStrokers.com 347...375/384 to the tires and wanting more
1trkpny95 is offline   Reply With Quote
Old 03-07-2010, 07:22 PM   #8
FR500_Notch
FR500_Notch's Avatar
I have this same setup. Excellent combination and the difference in shift throw is negligible.
__________________
92 Coupe 4 cyl conversion - Silver/Dark Shadow Grey
302: AFR 185s/FTI/Eddy RPM, 75mm MAF /TB, T5-Z PRO-5.0, 3.73s
13" Bullitt / 11.25" Mark VII, SN95 booster & 99 V6 MC
296rwhp/316tq - 12.78 @ 105 - NX 100 wet - 409rwhp/468tq - No E.T. yet
FR500_Notch is offline   Reply With Quote
Old 03-07-2010, 10:48 PM   #9
glennster
glennster's Avatar
I have a 5.0 handle on my tri-ax,being 6'4" its perfect.
__________________
2008 Bullitt Highland Green #5564
1989 5.0 LX regatta blue hatch 5 speed
GT40 heads/cam/intake/long tubes/274 rwhp/310 rwtq
13.09@106.1 on a 1.99 60'
glennster is offline   Reply With Quote
Old 03-07-2010, 11:57 PM   #10
BadboyGT
BadboyGT's Avatar
I have a tri-ax shifter. At the track i run my tri-ax handle and on the street i run my comfort pro handle.
__________________
04 GT 5 Speed Mods: Custom Tune, CMS Stage 1 Cams, CAI, 70MM TB, Upper Plenum, Intake Spacer, 24lbs. Injectors, 180 Stat., Under Drive Pulley, Off Road X-Pipe, Cat Back, 4:10 Gears, Electric Water Pump And More. 291 RWHP And 314 RWTQ
BadboyGT is offline   Reply With Quote
Old 03-08-2010, 11:49 PM   #11
FOXRODDER
FOXRODDER's Avatar
Trader Feedback: (22)
I've found that I didnt care for the short handles of any sort and use factory handle with solid bushings or a custom stick. Ran the comfort pro steeda for awhile but no longer using it.
__________________
Sonic 87 GT, 2000 GT
FOXRODDER is offline   Reply With Quote
Old 03-09-2010, 02:02 AM   #12
Kerpal
I'm starting to feel like my Tri Ax handle could be a little shorter. I love how it shifts, it just seems like the handle still has a lot of for-and-aft travel for a short shifter.
I guess I've really gotten used to it, because I can't even remember how much longer the throws on the stock shifter were now...
__________________
'90 GT - daily driver
WTB... '03 Cobra or AGR SN95 steering rack, Centerforce clutch
Kerpal is offline   Reply With Quote
Old 03-09-2010, 10:12 AM   #13
MFE
Super Moderator
MFE's Avatar
I've never thought the throws were too long on my Tri-ax/comfort pro combo. In fact, I can shift every forward gear with just my wrist, with my forearm resting on the armrest. How much shorter do they need to be? IMHO it's way more important to be able to reach every gear solidly without leaning forward at all than it is to shave the last 1/4 inch of travel. Harnessed in tight, seat all the way back and then some (modified the rails), I can comfortably reach the shifter at all times. I could not say the same with the Hurst I used to have.
http://www.streetfire.net/video/92-5...-on_117325.htm
MFE is offline   Reply With Quote
Old 03-09-2010, 10:24 AM   #14
Duspan
I ended up going with the Steeda shifter. It seemed that through my research that was the one for me. It was a hard choice between this and the Pro 5.0 due to the nostalgia properties of the Pro.
Old 03-09-2010, 03:54 PM   #15
Kerpal
I'm not knocking the Tri-Ax, just observing how much I've gotten used to it over the past year. It's a great shifter. I love mods like this that make the car much more fun and enjoyable to drive at any speed. I had my alignment checked the other day and after taking it around the block the tech even commented on how much better than stock it shifts.
You sure drive the hell out of your car MFE. I would love to get my car on a road course some day, I can only imagine how much seat time I would need to be able to drive like that though!
__________________
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
