Thread Tools | Display Modes |
#1 |
Look how my suspension is working
so I got the car working what I "thought" was perfect. went up to Tasca Ford day at my local track and the car ran AWESOME.
60's 1.37 1.37 1.37 1.37 1.36 ET's 10.02 9.99 9.98 10.02 (pulley swapped) 9.99 couldnt have asked for a better day. but check out the video. I still seem to have a rear end "bounce" on the launch. its one good solid bounce and I bet there is .01-.02 left in the 60' if I could eliminate that. here is a vid of my 5 passes this past weekend with (3) 9.9 passes. http://videos.streetfire.net/video/J...uns_714078.htm
__________________
Silver '03 Cobra Coupe Auto OEM Longblock UNTOUCHED 9.94@135 w/a 1.36 - Eaton only, NO nitrous! Last edited by BADASS03SVT; 10-19-2009 at 04:08 PM. |
| Sponsored Links | |
Advertisement |
#3 |
One word...WICKED!!! lol.
__________________
1985 capri, stock 88 shortblock 302, twisted wedge, TFS stage 1 cam, LTs, 3.73, ET streets, summit stage 3 intake, demon 650, G-force T-5, centerforce D/F, MSD dizzy, 6AL,12.11@110 |
#4 |
Any other videos...
I saw the car run it ran hard!!! I was gonna come over and say hi, but I was running around a bit.
__________________
89 LX: Stock cam, E7s, Cobra intake, 3.73s and bolt ons... BESTS 12.56 et 107.4 mph: slicks, 12.53 et 108.2 mph: 17" ET Streets, 12.87 et 111.5 mph: 17" DRs, 12.95 et 109.2 mph: 18" radials |
#6 | |
upr uppers and lowers anti roll bar strange shocks stock gt springs FRONT tubular K/arms 14" 175# coil overs tokico drag struts
__________________
Silver '03 Cobra Coupe Auto OEM Longblock UNTOUCHED 9.94@135 w/a 1.36 - Eaton only, NO nitrous! |
#7 | |
__________________
'07,'08 & '09 NMRA FACTORY STOCK CHAMP // '07 NMRA ROOKIE OF THE YEAR Quickest & Fastest Pass in F/S History 10.899 @ 122.59mph ( unported GT40's ) 10.96 @ 122.11 w/ E7's unported ( BFG's ): 10.665 @ 124.24 w/GT40's unported ( 26x10 m/t ) JPC Racing / RGR Engines |
#9 |
Im running 12psi hot in them now. I tried 12.5 last week and I lost a tic on the 60' by .02. moved them back to 12 and got it back. Ive just always run 12. maybe the car is working so good (transferring) that the extra pound will be ok?
__________________
#10 |
edited.
__________________
#11 |
Do you have adjustable shocks on the rear?
I would also like to know what camera and software you used to make your slo mo vid. I want to take some video of mine also.
__________________
2003 SVT Cobra Vert 450 RWHP 1986 GT 686 RWHP |
#13 | |
its just a Sony handycam and adobe premier pro
__________________
#14 |
Don't most cars work well with about 5 clicks on the rear?I haven't used Strange rears,but I've got a couple of friends that run them there in cars that 60ft. well.Full loose is usually a front setting(I'm using 2 clicks in front).Have you played around with the shock settings?
__________________
'91 Hatch-12:1 408,fogger,C4 5.60's@124 1.23 60ft. Last edited by bykr; 10-20-2009 at 11:52 PM. |
#15 | |
Im at 3 up front and 1 out back...lol...backwards to most I know!
__________________
#16 | |
__________________
#17 | |
Exactly. The suspension is working. The bounce is all in the tire. If you don't want to go up in tire pressure you could try reducing the amount of anti-squat you have dialed in with your control arm angles. The initial hit is planting the tire pretty hard.
__________________
97 GTS Bolton PI engine 266 rwhp 11.94 @ 111.66 NMRA F/S #1 (2005 and 2006) Crew Chief Last edited by HIPSI; 10-21-2009 at 12:11 PM. |
#18 | |
so what arms? angles? I cant really move my lowers as the 28s just fit in the fenders. someone told me to "raise" the back of the car a tad to make the lowers even with the ground though? right now the body side is a little lower than the axle side.
__________________
#19 | |
__________________
97 GTS Bolton PI engine 266 rwhp 11.94 @ 111.66 NMRA F/S #1 (2005 and 2006) Crew Chief |
#20 | |
I was thinking of just adding in a spring isolater set to raise it up 1/8" or so. dont think I want to get into drilling holes and swapping around mounting points.
__________________
#22 |
You guys keep it coming, I'm reading every word of this and I really appreciate all this info. I'm going to do my rear suspension this winter, and I will take all of this into consideration. Thanks.
__________________
#23 | |
no huh?just to even the lower control arms up?
__________________
#24 | |
I don't think I would change anything. You are cutting a low 60' and being VERY consistent. Good job. I wouldn't tinker with it, just enjoy it.
__________________
2001 Mustang Bullitt #01992 Quote:
#25 |
I cant stand the fact I can see something wrong though and knowing the car could go faster irks me! haha
__________________
#26 | |
It looks to me the car has no suspension control in the rear....and is actually bouncing after launch........try upping the rear shocks to 5 clicks and report back.....after trying that, if it works for you, try upping the air pressure 1/2 lb at a time.
__________________
Pump gas 501 BB Ford...... 28 x 10.5's - stock suspension |
#28 | |
Well you have some bounce in your rear suspension so you could probably use a little more rebound. If you are running the tokicos that increase compression and rebound with every click, you can't go up with rebound without stiffening the compression. With that said, I'd be inclined to just leave it alone, but I know what you mean. Its hard not to improve something if you think it can be fixed. You already said you lost time by going stiffer, aside from another set of shocks (which you could spend lots of time chasing your tail with) I'd leave it be and enjoy the ride. Especially since you are already in the 9's.
__________________
#29 | |
I know the car is working great but all this year Ive been striving for every last .01 in this car. if I can get it into the 1.36s or even the 1.35s Itll be a solid 9.90-9.95 car. I have to do dash bars this winter and Ill remove the heater core and a couple other things so I dont see the car actually changing too much for next year. more I can do now is less I have to next year and start some events
__________________
#30 |
Play with the shock and strut settings. If you are inclined to leave the rears alone, put a few more clicks in the front. This will control the rise and fall of the front end of the car so it is not so drastic. FWIW I run QA1's in the front and rear of my car and it likes 7 turns in the front and 4 clicks in the rears. I used to run them full loose and the thing would yank the front tires, bounce in the rear, unload the rear tires when the front came down and bounce again on gear shifts. I know we have drastically different cars but just try it.
__________________
89LX, 11.45@118.11, Stock Bottom End 302, N/A, Mileski Racing/Espeut Performance. 06 Atco O/C Winner , 09 Atco O/C R/U. |
#31 |
What do you have your pinion angle set at? Trying to get a bad hop out of my 96 cobra. What do you guys think of mega bite jr lowers? That's what I have.
__________________
1996 Laser Red Cobra #64 Detroit Locker, Moser 31 spline axles, 4.56, Hooker Longtubes with 'X', ASP pullies, UPR Powerpipe CAI, SSR Ported Intake, Ripper shifter, UPR double adj. uppers, solid housing bushings, Mega Bite Jr. lowers, MM full length subframe connectors, UPR chrome moly k/member, a/arms, coilovers and Strange adj. front shocks. Tuned by Jerry. 26 x 8 1/2 x 15 ET Drags 8.11 @ 84.64 1/8 mile 12.91 @ 107.05 - before headers, SSR intake, suspension and tune. |
#32 | |
I probably should have added I have the 2-step / converter flashing HARD. 2 step is 3500 and the converter flashes to 4800-4900. so Im flashing 1300-1400rpms.
__________________
#34 | |
whats your take on the launch?
__________________
#35 |
Trader Feedback: (37)
Strange. Afco and varishock all make them.
Tim
__________________
86 3185lb FTI 408 10.24 132 unported TW. Hot Rod Drag Week NA-SB R/U 2007 Officaly Retired from Racing. When arguing with a idiot after a few min it is hard to tell who the idiot is. www.flowtechinduction.com www.boozebrothersracing.com |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
