Go Back   Corral.net : Ford Mustang Forums > General Non-Tech Forums > Lounge
Thread Tools Display Modes
Old 09-30-2009, 07:20 PM   #36
xmtrxmt
xmtrxmt's Avatar
WOW!! Hate to see that.
__________________
351W with an electrical GREMLIN!!!!
xmtrxmt is offline   Reply With Quote
Old 09-30-2009, 08:06 PM   #37
mstngman28@yahoo.com
mstngman28@yahoo.com's Avatar
Looks like it just needs some fresh oil...may want to put some heavier weight oil in there or the engine might have a "tick"
__________________
1987 2-tone GT 5.0 5 speed
GT40 Intake, Underdrive pulleys, Steeda Tri-Ax short shifter, Summit fenderwell CAI, ceramic coated shorty headers, X-Pipe, flowmasters & 3:55's
mstngman28@yahoo.com is offline   Reply With Quote
Old 09-30-2009, 09:56 PM   #38
Daywalker
DROID
Daywalker's Avatar
Elwood: Oh no.
Jake: What the #### was that?
Elwood: The motor. We've thrown a rod.
Jake: Is that serious?
Elwood: Yup.
__________________
Be advised. I'm mean, nasty and tired. I eat concertina wire and piss napalm and I can put a round in a flea's ass at 200 meters. So why don't you go hump somebody else's leg, mutt face, before I push yours in.
Daywalker is offline   Reply With Quote
Old 09-30-2009, 10:07 PM   #39
03mustangGT07
03mustangGT07's Avatar
You have some shaving's in you oil pan.lol. That suck's bu at least you can build a better one now.
__________________
2003 gt. K&N intake, Bassani off road x-pipe,flowmaster catback,steeda under drive pully's,steeda tri-ax short throw shifter, 3.73's ,Trickflow plenum, bbk 70mm t/b, SCT3 tuner, 18 by 9 black saleens.
03mustangGT07 is offline   Reply With Quote
Old 10-01-2009, 10:50 AM   #40
NUTTSGT
Unregistered User
NUTTSGT's Avatar
That sucks but I love engine carnage.
__________________
Eric
TOO MUCH IS...JUST ENOUGH
Originally Posted by Dave88LX View Post
That was a horrible mistake and I am sorry I did not listen to all of you. I made a big mistake.
NUTTSGT is offline   Reply With Quote
Old 10-01-2009, 03:53 PM   #41
90NotchLX
90NotchLX's Avatar
I'm going to miss this motor
http://videos.streetfire.net/video/1...501_147758.htm
http://videos.streetfire.net/video/N...con_138363.htm
__________________
Streetcar 90 Notch Stock 69 351W C6 trans 8.8 with 3.73, Strange 31spline axles and spool
Racecar 68 Falcon FE487ci PowerGlide trans. 9' with 4.56 with 33spline axles and spool FE is blown up. BBF 503ci coming soon
90NotchLX is offline   Reply With Quote
Old 10-01-2009, 07:31 PM   #42
apollo12
apollo12's Avatar
sorry to see that happen to you!
__________________
1992 notch 306 afr heads n-41 cam 373s upper/lowers edelbrock intake 70 mm t/b tremec 3550 all bolt-ons
1992 lx hatch 306 eagle crank,rods forged pistons p/p rpm heads 2.02/1.60s full suspension tremec tko aeromotive fuel system custom cam 31 spline axles all bolt ons
apollo12 is offline   Reply With Quote
Old 10-01-2009, 07:42 PM   #43
NUTTSGT
Unregistered User
NUTTSGT's Avatar
bigger better faster
__________________
Eric
Old 10-02-2009, 02:56 PM   #44
scoupe89
scoupe89's Avatar
Asesome vids! Bad ass car also!
What times were you running w/combo?
Carnage sucks, but if it lasted the whole season it was a good build.
FE=BBC + arm + leg+$
Most formed pieces with ASTM stamping meet none or few ASTM standards.
China is lowering the standards for just about everything worldwide.
730hp motor,cast crank and your surprised it broke.Shame on you.
I've seen lots of 9-10 sec cars with cast crank and two bolt main crank/block combos last several seasons.
scoupe89 is offline   Reply With Quote
Old 10-02-2009, 03:09 PM   #45
CPHK96
CPHK96's Avatar
I noticed in the OP's pic and the link to his friends carnage, that the bellhousing is cracked in both instances.
Why is that?
__________________
Chris
91 LX
Stock 5.0
CPHK96 is offline   Reply With Quote
Old 10-02-2009, 03:29 PM   #46
scoupe89
scoupe89's Avatar
I noticed both cracked bellhousing also.
When the crank breaks, it would transmit that shock to the BH.
I seriously doubt the root cause is bellhousing crack propagation.
Most likely bearing failure, detonation or imbalance/vibration that led to catastrophic failure.
The OP's car pulls the wheels off the ground, which is impressive, but is torture on the frame, suspension, motor mounts,etc.
I seen a few landings where the driver nailed the oilpan, doing damage, even though nothing appeared damaged. I'm a physical metallurgist and do some consulting on failure analysis. I'm always curious to find out the details. I've seen some stranger stuff.
Old 10-02-2009, 04:35 PM   #47
90NotchLX
90NotchLX's Avatar
The motor has never been hurt and all bearings look prefect. When the crank broke that is what broke the bellhousing there is no question there. Seen it plenty of times with a stock trans case. It's just a cast crank it can only take so much abuse then needs to be replaced or it's breaks.
__________________
Old 10-02-2009, 07:58 PM   #48
jtsfastgreen92gt
jtsfastgreen92gt's Avatar
it definitly scatted
__________________
87gt-mild stuff-sold,92gt-D/D
85 NOTCH-victor JR'S h/i,sleeper,turbo in da works
R.I.P.PAINTER TOM MORRIS '51-'09
R.I.P.MATT KOONTZ
jtsfastgreen92gt is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
