Go Back   Corral.net : Ford Mustang Forums > Modular Tech Forums > SVT & DOHC
Thread Tools Display Modes
Old 09-17-2009, 09:26 PM   #1
na svt
All B heads are not created equal
All B heads castings are not the same. The combustion chambers of the earlier castings, 93-95, do not have the same potential when used in stock form.
Many people buy B heads with the thought they all make the same power making potential. Also, there is always someone trying to pass off Mark 8 heads as Cobra heads. Looking at the combustion chamber is the easiest way to tell the two apart.See the pics below:
I only show two part numbers below but will start a "good" and "bad" list.
na svt is offline   Reply With Quote
Old 09-18-2009, 01:59 AM   #2
me32
me32's Avatar
nice pics, great info. while your add it can you give the cam info of both heads too
__________________
2008 Shelby GT500, 2921 out of 6513 coupes, 132 of 314 Alloy Metallic, Shelby Dash Plaque, FRPP CAI,KR shifter,SVT handling pack,373,TVS, J&M UCA, J&M Adj. Pan Hard Bar, Power House 4" A/D, Custom o/r H, DynoMax 3in CB, Shelby HE/RAD 592RWHP/576TQ
me32 is offline   Reply With Quote
Old 09-18-2009, 06:16 AM   #3
na svt
Mark:
intake 184 deg dur
exhaust 196 deg dur
Cobra:
Intake 204 deg dur
Exhaust 196 dur
Old 11-03-2009, 01:06 PM   #4
metalman302
metalman302's Avatar
Trader Feedback: (104)
The older Mark 8 heads also had crappy springs while the newr ones had beehives.
I have a 97 Mark 8 motor and it has the AD heads.
I also have a 95 Mark 8 motor and it has beehives and has AA heads. I may pull these and be able to take a peek, not sure yet. Maybe someone else can verify.
__________________
1990 GT - TFS TWs, 1.7 RR, GT40 Tubular, Shorties, OR/X, stock cam & 150k short block = 287 rwhp 322 rwtq untuned
94 V6 DD - AODE to T5
metalman302 is online now   Reply With Quote
Old 11-03-2009, 01:58 PM   #5
Erich
Erich's Avatar
Can the older heads be reshaped to resemble the newer ones?
Erich
__________________
97 Laser Red GT-248A Wingless model, Built Lincoln Mark VIII motor-Procharger D1SC, 3 core IC, 60# inj
1989 Sonic Blue Notchback-DIY Twin Turbo, 42# inj, GT40P heads
Erich is offline   Reply With Quote
Old 11-03-2009, 02:56 PM   #6
na svt
Erich
Yup, I'm in the process of doing that to a set right now.
Old 11-03-2009, 03:51 PM   #7
Erich
Erich's Avatar
Here are some shots of my heads before and after I had work done to them. they are 93 Mark VIII heads. Does it look like I had improvements made as far as that shrouding?
Erich
__________________
Old 11-03-2009, 03:59 PM   #8
na svt
nope, they are still shrouded
Old 11-03-2009, 04:14 PM   #9
Erich
Erich's Avatar
This is pretty irritating. I totally did not know there was a difference till recently. I could have easily swapped these for later heads.
Erich
__________________
Old 11-03-2009, 04:27 PM   #10
metalman302
na svt, I think I may have posted this in the other thread...
Is there any truth to mark 8 heads using different diameter valves and valveseals than cobra? THe SHM book said this but there was a few errors in that book.
These are beehive springs correct? These are the AA heads on my 95 motor:
__________________
Old 11-03-2009, 05:45 PM   #11
na svt
Those are Beeehives. Also, the Cobra heads have a "Z" in the part number.
Old 11-03-2009, 06:53 PM   #12
Erich
Erich's Avatar
I got my info that the heads were the same from that hyland book. I knew about the springs and had them changed to beehive.
Erich
__________________
Old 11-03-2009, 06:58 PM   #13
metalman302
I blame Hyland. He even said Mark 8s had 8 bolt cranks.
__________________
Old 11-03-2009, 09:33 PM   #14
assasinator
assasinator's Avatar
i removed the shrouding when i ported mine. if you remember.
__________________
93 teksid 4v forged
96 mustang GT
ported heads,manley,mahley,8.5:1,80mm .56trim turbo,.84 exhaust housing, 4x28x12 fmic,14psi.
assasinator is offline   Reply With Quote
Old 11-03-2009, 09:36 PM   #15
assasinator
its difficult to quantify how much the shrouding hurts, but on 3v heads, the shrouding is the majority of the flow gains in ported 3v heads.
__________________
93 teksid 4v forged
96 mustang GT
Old 11-04-2009, 09:32 AM   #16
Erich
Erich's Avatar
I was wondering how much that shrouding hurts. I thought the transition and bowls were the worst part of those heads.
Erich
__________________
Old 11-04-2009, 10:13 AM   #17
na svt
Erich
The short turns are the worst part but the only way you can fix them is to raise the port floors. Raising them would also increase velocity by reducing the port volume.
Old 11-04-2009, 06:04 PM   #18
ModularSpeed
ModularSpeed's Avatar
Yes, but unshrouding valves on any application helps.
__________________
"Performance Driven, Race Proven"
Kelly Aiken
727-967-3461
ModularSpeed is offline   Reply With Quote
Old 11-04-2009, 08:23 PM   #19
metalman302
Do you mean you are adding material to the port in that spot?
How much hp do you think the shrouding costs on a mild na car? A few hp maybe 3-5?
__________________
Old 11-05-2009, 07:15 PM   #20
ModularSpeed
^Yes. You basically re-shape the runner by adding material to raise the floor, and remove material in other areas when reshaping/porting.
__________________
Kelly Aiken
727-967-3461
Old 11-05-2009, 07:28 PM   #21
metalman302
How much does this typically cost for that? Would it make the low end of a NA B combo comparable to a C head?
__________________
Old 11-06-2009, 10:18 AM   #22
Erich
Erich's Avatar
Can't you just grind down the short side to make the transition smoother?
Erich
__________________
Old 11-06-2009, 10:31 AM   #23
na svt
Can't you just grind down the short side to make the transition smoother? Erich
It's not an issues of it needing to be smoothed. A good short turn radius is not sharp. The B head radius is very sharp and grinding on it will only make it worse. In order to make the short turn radius larger you have to add material to the port floor.
Old 11-07-2009, 07:01 PM   #24
assasinator
imo all you can really do to the primary is add a little flow. there is a shelf and not a turn from the factory. i added better flowing valves, and deshrouded the primary. its going to add some to it. but thats all intuitive. the flow bench guys are the only ones who know exactly how to get more. raising the roof a tiny bit and altering the roof of the bowl to turn the air more perpendicular to the valve should help some also. it should have the effect of compressing the airflow near the valve and helping the short turn indirectly.
too bad the primary sucks so bad. my heads are comin off soon enough. maybe i can flow bench the stupid things this time. maybe.
__________________
93 teksid 4v forged
96 mustang GT
Old 11-07-2009, 07:54 PM   #25
46callaway
My 98 Mark VIII heads are RF-F6ZE...
46callaway is offline   Reply With Quote
Old 11-07-2009, 08:25 PM   #26
metalman302
Same here on my 97 Mark 8
__________________
Old 11-08-2009, 12:55 AM   #27
na svt
Raising the roof will increase the port volume and further reduce velocity and that (velocity) is just as, if not more important than flow.
Old 11-08-2009, 12:13 PM   #28
570cobra96svt
Is it true another difference you cant tell, is the the intake ports/IMRC's?
The cobra has a square port & a round port, and the Mark8 has 2 oval/round ports.
Also the IMRC'S in the cobra are electricaly controlled by the ecu, were as the mark8 is vaccum.???
570cobra96svt is offline   Reply With Quote
Old 11-08-2009, 12:27 PM   #29
assasinator
the primary port is the same as the cobra. one square entry, one round.
__________________
93 teksid 4v forged
96 mustang GT
Old 11-08-2009, 12:28 PM   #30
assasinator
the imrc's for 97-98 mark viii is the same part.
__________________
93 teksid 4v forged
96 mustang GT
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
