Go Back   Corral.net : Ford Mustang Forums > Windsor Tech Forums > 5.0/5.8 Engine Tech
Thread Tools Display Modes
Old 08-11-2009, 03:08 PM   #1
Nottoofast50
10 second streetable combos
Curious about what setups you guys have running in the 10s and still streetable. I'm trying to find the cheapest street friendly way to do it(yes I know the 2 probably dont go together).
__________________
92 AOD GT Lentech/HCI
2009 G8 GT LTs/CAI/Tune
Nottoofast50 is offline   Reply With Quote
Old 08-11-2009, 03:45 PM   #2
S-Trimmed302
S-Trimmed302's Avatar
Trader Feedback: (65)
Nope its hard to have GOOD and CHEAP together lol
__________________
Looking for performance Parts?Check out my for sale thread. http://forums.corral.net/forums/showthread.php?t=1138608
Originally posted by Fomoco347
One time i drove my car with 3 rims cuz i couldnt afford the 4th rim,
S-Trimmed302 is offline   Reply With Quote
Old 08-11-2009, 04:23 PM   #3
Wildstreet
Trader Feedback: (28)
Unless we are talking about whores
__________________
Just a #$%^ talker, I know nothing.
Wildstreet is offline   Reply With Quote
Old 08-11-2009, 04:34 PM   #4
rixx93gt
They go together very easily (10's and streetable not the cheap part, forget that now) with a power adder such as nitrous. A 331 n/a combo that can break off 10.90's takes more effort/money and depending on your defenition of streetable may be hard to do. But a stout aftermarket block with a good n/a combo and a cam that can take advantage of a 150-200 shot when your at the track could be very streetable once again depending on your idea of "streetable". My car will run mid elevens n/a and I feel it is very streetable but some might not agree. With a decent shot of spray I could be deep in the 10's. Tens and cheap dont go together very well, anyone can make a 10 second car that will last a couple passes but if you want dependability and 10's now your talking about more money, more time and more testing. Let everyone know your idea of streetable and if you want to stay n/a or go power adder and if so which power adder you prefer. Do you want to stay efi or alright with carb? You gonna race on street tires or dot slicks or full slicks? Etc, etc.
__________________
www.thericksswitch.com
Stick shift 2 step contol "Simplify"
93GT 347
rixx93gt is offline   Reply With Quote
Old 08-11-2009, 05:23 PM   #5
killerkx327
killerkx327's Avatar
Trader Feedback: (23)
heres a cheap and very streetable pump gas low 10 second combo that i use to run.all motor no power adders.
CHP 347 shortblock flattops
AFR 205's 58cc with titanium retianers and Kmotion K950 springs
Super Victor intake
probe 1.7 shaft mount rockers
Pro systems carb 860cfm
Camshaft Innovations solid roller cam
tko 600 box stock
Spec stage 3+ clutch
5.13 gears
28in tires
car wieghed #2880 with driver
i shifted it at 7600-7700 rpm.
that was a stock E7 block.
i adjusted the valves twice a year, drove it about 150 miles every week for 3 years that way before i sold it.
it ran 1.38 60ft. 10.27 @ 133mph every rip. that car could've been a bracket racer.
__________________
There 3 types of work I offer!
if you want it cheap and fast it won't be good.
If you want it cheap and good ,it won't be fast
If you want it good and fast ,it won't be cheap
killerkx327 is offline   Reply With Quote
Old 08-11-2009, 05:28 PM   #6
buddy rawls
370-410 cid 351W stroker, 11:1, AFR 185's, victor jr intake and 750-850 double pumper, 1 3/4 headers to a 3" dual system, a Comp Magnum 280H (hyd flat tappet).
Peak horsepower around 5000-5500 rpm, launches like gangbusters, and pulls from 2500 rpm onward, powerbrakes, low rpm idle, shift around 5500-6000.
One example went 10.50's (3200 lbs), with an auto (no trans brake), and slicks. pulled 60 ft times in mid-upper 1.40's (No trans brake!). switched to a solid flat tappet (the only change) and got 10.30's out of it.
buddy rawls is offline   Reply With Quote
Old 08-11-2009, 06:01 PM   #7
Lee8995
Lee8995's Avatar
306 stock crank/rods, old forged TRW pistons, TFS TW heads, TFS 1 cam, Holley Systemax II, 70mm Tbody, 42# inj, Vortech S-Trim, ASP 8" crank pulley, Vortech 3.33 blower pulley, Power Pipe, MSD 6AL, 1 5/8 Hooker shortys, 3.55 gears and a T5.
Shift at 5800 and it's mid 10s all day long in hot thin air.
__________________
The real reason that we can't have the Ten Commandments posted in a courthouse is this:
You cannot post 'Thou Shalt Not Steal,' 'Thou Shalt Not Commit Adultery,' and 'Thou Shall Not Lie' in a building full of lawyers, judges and politicians...It creates a hostile work environment.
Lee8995 is offline   Reply With Quote
Old 08-11-2009, 06:33 PM   #8
lov2xlr8
n/a 331 9.8comp 415rwhp@7200
ported performer rpm 289cfm@600
ported vic jr intake
speed demon dg 750
.640 .648 248-256 dur 110
13/4 long tube
tko600 by promotion
4.10
3000lbs w driver
10.8@127.8 n/a 225shot 9.57@145
same combo afr185 comp and 11.5comp steel flywheel instead of aluminium
3.73 gear 26x10 10.8@129
not mutch gain n/a but on a 250shot whent 9.43@147 1.39 60ft
lov2xlr8 is offline   Reply With Quote
Old 08-11-2009, 06:42 PM   #9
thesource
thesource's Avatar
Trader Feedback: (126)
408-427W with good heads, intake and camshaft or small cubic inch 302 based setup with a turbo on it.
__________________
[SIGPIC][/SIGPIC]
AUTHORIZED DEALER FOR:
QUICKTIME - TREMEC - PRO 5.0 - SPEC - UPR - ASTRO PERFORMANCE
thesource is offline   Reply With Quote
Old 08-11-2009, 11:35 PM   #10
Nottoofast50
I was thinking of going the same route as you and building a 347 that could run mid 11s then spraying 150 shot on it. That seemed to be the cheapest streetable reliable option to me. I'd prefer efi as I dont really know much about carbs. My setup I was considering was a 347 with AFR 185s, systemax 2 ported, custom cam and all the supporting parts. Hoping that would do mid 11s then spray 150 shot for 10s. I will be running a lentech which is already in the car. I mainly made the post becasue I'm curious what other people are running and looking for any different builds/suggestions that I hadnt thought of. By cheap I didnt mean I want to build a 10 sec car for 2k just would rather spend as little money as possible while keeping it streetable.
__________________
Old 08-12-2009, 12:32 AM   #11
Lee8995
Lee8995's Avatar
A power adder car is going to be the most streetable of all the combos, The cheapest way to go is to do heads and intake with the stock cam. Stock cam S-Trim combos will make between 550-580RWHP which is guaranteed mid to low 10s, The reason I say do a supercharger is because it wont take long filling bottles before the cost of the Nitrous system and expendables exceedes that of a supercharger set up. A stroker is fun as is a 351w based stroker but they aren't cheap, You can buy a new Vortech SC and SCi-Trim for 1800 and then get heads/rockers and intake. The thing is you can't build a cheaper more consistent combo, Yeah a turbo would be nice as would a big cube stroker but the fact is neither are cheap to build or buy. Use your stock short block and save a bunch of money, You can do what I listed above for about 3500 but you would be hard pressed to build equal HP for that money.
__________________
Old 08-12-2009, 12:42 AM   #12
Thewhite88pony
Trader Feedback: (41)
A turbo on basically anything. lol
__________________
Precision 67mm turbo, this and that.
Thewhite88pony is offline   Reply With Quote
Old 08-12-2009, 12:10 PM   #13
10 SecStang
10 SecStang's Avatar
Junkyard shortblock with new rings and bearings, S trim with powerpipe,
out of the box edelbrock performer rpm heads, 1.6 rockers, crower 15512
cam, ported cobra intake and BBK equal length shorties 10.9 @ 130.5 with
1.86 60ft on drag radials. Car weighed 3250 lb with me in it, very streetable
and drove like a stocker.
__________________
87 LX Vortech S Trim 558 RWHP 542RWT 10.9 @130.5 1.86 60 ft on Drag Radials,sold. 1995 Cobra Vert, Trick Flow stage 1 cam, Edelbrock performer intake, S-Trim 8 lbs 12.3 @ 118 2.0 60 ft.3850 lbs. New Combo:347 S-Trim with Patriot 185cc heads,TFS stage 1 cam,TFS track heat intake. 11.92 @ 127.32
10 SecStang is offline   Reply With Quote
Old 08-12-2009, 12:16 PM   #14
MileHighTurbo
MileHighTurbo's Avatar
Freind of mine had a 10:5 to 1 347 afr185's,xhr282r,systemax,5sp,3250 weight would go 10.5's on a 150 shot plate system in colorado!!! all day!!!
would run 12.2's on the motor
__________________
04 Terminator Silver Chrome FR500's
93 COBRA Teal
90 NOTCH 302 w/Turbo 60-1,AOD *SOLD*
MileHighTurbo is offline   Reply With Quote
Old 08-12-2009, 12:26 PM   #15
the bone
the bone's Avatar
i went 10.80's all day taking it on road trips and driving to and from the track
3200lbs without me
s-trim 12lbs
aod 2200 stall
373
8:1 short, tf heads tf intake b41 cam
exhuast, ignition, etc etc etc
__________________
98gt vert sold - PI conversion, low 12's on a 100 shot
93notch sold - 9 second supercharged street-killa
95gt - current project streetcar
http://wayne-martin.mybrute.com
the bone is offline   Reply With Quote
Old 08-12-2009, 12:37 PM   #16
slo88notch
slo88notch's Avatar
i'm another guy that is a nitrous kit away from a streetable 10 sec combo, i'm running a pretty mild 347.
slo88notch is offline   Reply With Quote
Old 08-12-2009, 12:52 PM   #17
flop5.0
get a 306 with some good pistons (no trws) and good bolts throught it, procomp aluminum heads, vic jr intake, good carb, around a .600 lift hyd roller, c4 w/ t-brake and about a 250 shot and it should be in the 10s
__________________
'02 GT:a few mods!
'89 coupe all upr sus., cage, fuel cell, rear firewall, telstars
flop5.0 is offline   Reply With Quote
Old 08-12-2009, 01:10 PM   #18
Lee8995
Lee8995's Avatar
Nothing wrong with old TRWs especially with a power adder, The block is the weak link and Pro Comp heads are junk.
__________________
Old 08-12-2009, 09:55 PM   #19
mike06tr
mike06tr's Avatar
I am hoping to run high 10's with my 357 and thenm maybe spray it into the 9"s...
__________________
want it done right is that to much to ask??!!
mike06tr is offline   Reply With Quote
Old 08-12-2009, 10:45 PM   #20
ACJ
ACJ's Avatar
I hoping to get there also . I'm having a dart 363 built by ford stroker with a jay allen cam and som TW cnc 205's . I doing this with EFI also , Some one PAY PAL me some spare change
ACJ is offline   Reply With Quote
Old 08-12-2009, 11:22 PM   #21
Wildstreet
Ran this tonight, drove a hour there, ran 10.60's on pump gas, 3.55 gears, AOD, hyd roller, and drove home.
http://videos.streetfire.net/video/d...ome_701153.htm
__________________
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
