Go Back   Corral Forums > Power Adder Forums > Turbochargers
Notices
Thread Tools Display Modes
Old 08-06-2009, 09:22 AM   #1
91coupeLX
91coupeLX's Avatar
muffler question
I'll be running a pony down hot side, MPT-70, and intercooler with ebay cold side on my coupe in the next few weeks, as well as 42 lb injectors, and a Pro-M blow through MAF. Right now I have BBK 1-5/8" long tube headers, MAC pro chamber, and spintech pro streets with flowtubes welded on. I've heard that chambered mufflers severely limit performance on a turbo car. I was planning on buying the pony down Y-pipe and hooking my existing spintech mufflers to it. Would this be a bad idea and would it limit performance? Thanks for the help.
Chris
__________________
'91 Wild Strawberry Metallic notchback: too much to list with a snail coming soon
91coupeLX is offline   Reply With Quote
Old 08-06-2009, 09:25 AM   #2
93gtman
93gtman's Avatar
get rid of the chamber mufflers.. i went with HOOK MaxFlows from summit. They sound as quite a stock and they are a straight through muffler. even on the highway no drone at all very very quite untill you open it up this way it is a totall sleeper
__________________
NY
92 Red Notch 5spd Powered by MS1 V3 running HI-RES Code.
93gtman is offline   Reply With Quote
Old 08-06-2009, 09:41 AM   #3
91coupeLX
91coupeLX's Avatar
Thanks for the tip, but I'm not necessarily concerned with the car being a sleeper. It's wild strawberry metallic with 17" chrome rims on it, 3" exhaust tips, tinted windows, and the interior from a 2004 cobra. Right now it's loud as all hell and I like it that way. I'm concerned about performance issues associated with a chambered muffler design on a turbo set up.
__________________
Old 08-06-2009, 10:33 AM   #4
93gtman
93gtman's Avatar
if you dont care about the sound then you can go with race bullets? but you will def lose power with chambered mufflers some here have picked 20hp or better when they switched to a straight through design
__________________
NY
Old 08-06-2009, 10:37 AM   #5
badloser
racing on a 275
badloser's Avatar
Trader Feedback: (49)
if noise is not a factor then a open dp is the way to go..
__________________
Boss block 4V turbo build up
www.youtube.com/watch?v=OuOY3B5RJ2U
creperformance 08/09 NMCA street radial world champ
badloser is offline   Reply With Quote
Old 08-06-2009, 02:07 PM   #6
91coupeLX
91coupeLX's Avatar
hmm, i was thinking about bullets... do you guys have any sound clips of turbo cars with different mufflers?
__________________
Old 08-06-2009, 06:48 PM   #7
millhouse
millhouse's Avatar
Here is mine...no cat's or muff's. http://videos.streetfire.net/video/3...ea0150d4a0.htm
I will say I picked up quite a bit of SOTP horsepower and a definite decrease of turbo spool when I removed the flow's.
millhouse is offline   Reply With Quote
Old 08-06-2009, 10:51 PM   #8
91coupeLX
91coupeLX's Avatar
I've seen that vid quite a few times, and it makes me drool every time. You need a new clip with the 470w now
So you're running two open downpipes straight to tails?
__________________
Old 08-07-2009, 10:53 AM   #9
millhouse
millhouse's Avatar
Thanks!
Hopefully I'll finish up within the next few weeks. With a new baby, I've got better things to focus my attention on.
Yep, the downpipes run straight down to the h-pipe (already had it) and straight out the tail pipes.
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
