Go Back   Corral Forums > Modular Tech Forums > GT & SOHC
Notices
Gallery Corral Parts Store Videos Advertising Info Blogs Corral Home
Thread Tools Display Modes
Old 07-02-2009, 04:31 PM   #1
Modular Depot
Trick Flow Numbers are IN!
Just got done with the first dyno on our first Trickflow car.
The car is owned by Chris Durbin and was already a built 2v. It was ported PI heads, stock intake, Comp 278 cams, C&L plenum and a Mac cold air intake. Numbers were 305 rwhp / 316 rwtq on 93 octane.
We decided to only swap the heads to get a good comparison. Plus he wasn't after alot of power as he run the car in NASA American Iron and it has a power to weight ratio spec. We swapped on the 38cc heads.
I'm happy to say the gains were what we were hoping for if not better! Obviously we picked up about a point of compression with the swap but we are still running pump gas.
New numbers are
353 RWHP 357 RWTQ
That peak gains of 48 rwhp and 33 rwtq!
I'm sure with a better intake and cams ground specifically for this setup there is plenty more on the table. Then add some porting some some tricky stuff to the shortblock and big power NA 2v's are going to become a reality.
__________________
Modular Depot
1.877.234.5551
modulardepot.com
Chassis Work, Custom Fabrication, Installs, Dyno Tuning, Drag Racing, Road Racing.
Modular Depot is offline   Reply With Quote
Support corral.net, please click our advertisers!
Old 07-02-2009, 04:40 PM   #2
2k2GT
2k2GT's Avatar
Wow....now that's entry level boosted performance, without the added weight and extra variables to tune around! I imagine the Trick Flow manifold and compression would get up near the 400's.........N/A!
2k2GT is offline   Reply With Quote
Old 07-02-2009, 04:56 PM   #3
ROG30Y
that is very very impressive!!!!
no good reason to go to a old 5.0l car anymore.
__________________
1964 Falcon....302/t5....slow right now...
ROG30Y is offline   Reply With Quote
Old 07-02-2009, 04:59 PM   #4
jayfitzy
jayfitzy's Avatar
Thanks for the info. I cannot wait to see the numbers the N/A guys will make with these heads. I might have to see my port 2v heads and get a set!
__________________
1997 Mustang GT Black on Black
MMR 850 Stroker, VT stage II Cams, Fox Lake Stage II Ported PI Heads, Flowtech LT Jet Coated, self ported 75 mm TB and Plenum, BBK CAI, Maximum Motorsports Grip in a Box, tuned by DEZ Racing
jayfitzy is offline   Reply With Quote
Old 07-02-2009, 05:24 PM   #5
Purple Haze
Purple Haze's Avatar
Very nice.
Can you talk about the changes in tuning made from a PI-headed 2v tune to a Trick Flow head tune?
__________________
Originally Posted by mmeans View Post
I have noticed that when Obama does not have his electronic talking nipple he pauses a lot more than Bush ever did.
Michael Means
Purple Haze is offline   Reply With Quote
Old 07-02-2009, 06:16 PM   #6
00perfredgt5s
Looks impressive. Thanks for the info.
00perfredgt5s is offline   Reply With Quote
Old 07-02-2009, 06:26 PM   #7
mystichris@MD
Whenever you're ready to bolt on some more power with the heads give me a call at 1-877-234-5551.
-Chris
mystichris@MD is offline   Reply With Quote
Old 07-02-2009, 06:30 PM   #8
kevman
kevman's Avatar
That's very good results
__________________
Give someone an answer, they learn for that day; introduce them to the search function, they learn for life.
kevman is offline   Reply With Quote
Old 07-02-2009, 06:36 PM   #9
realitygt
realitygt's Avatar
did the car have longtubes or anything else?
really looking into getting a set of these lately... I wanna see what a 5.4 would do with these heads
realitygt is offline   Reply With Quote
Old 07-02-2009, 06:40 PM   #10
Modular Depot
Originally Posted by Purple Haze View Post
Very nice.
Nothing major. Most of the changes were made because of the increase in compression.
__________________
Modular Depot
1.877.234.5551
modulardepot.com
Old 07-02-2009, 06:40 PM   #11
Modular Depot
Yes, It has longtubes but I really think a set with larger primaries would help. These are 1 5/8"
__________________
Modular Depot
1.877.234.5551
modulardepot.com
Old 07-02-2009, 10:06 PM   #12
orangetrak
Am I mistaken or are those LS1/2 numbers with 50 less cubes?
__________________
1999 GT Conv.
Atlantic Blue, White Top, Black Int./Oxford White Leather, 5-speed, every option except traction control.
18" '03/4 Cobra replicas with Goodyear F1 Supercars; Steeda Sport Springs/Tokicos, Dyno Max mufflers, Magnaflow Catted X, 11" Cobra clutch, MGW Shifter
orangetrak is offline   Reply With Quote
Old 07-02-2009, 11:13 PM   #13
2k2GT
2k2GT's Avatar
Old 07-02-2009, 11:30 PM   #14
03mustangGT07
03mustangGT07's Avatar
Can't wait to get some.
__________________
2003 gt. K&N intake, Bassani off road x-pipe,flowmaster catback,steeda under drive pully's,steeda tri-ax short throw shifter, 3.73's ,Trickflow plenum, bbk 70mm t/b, SCT3 tuner, 18 by 9 black saleens.
03mustangGT07 is offline   Reply With Quote
Old 07-03-2009, 01:52 AM   #15
riph22a
riph22a's Avatar
nice numbers but now i won't be able to call bs when some dude comes up in his catback/k&n mustang and says he puts down 330.
__________________
96gt pi motor,C&l intake,hooker lts, dr gas x,dynomax ultraflow ss, msd packs, csprings,70mm tb, udps, x cal 2 tune, 100 shot
riph22a is offline   Reply With Quote
Old 07-03-2009, 02:05 AM   #16
04Ryan
04Ryan's Avatar
Looks like Trick Flow did their homework on these...I imagine a set of these with bigger chambers and a set of blower cams would be right at home on my car. Although I'm afraid my stock shortblock would go into early retirement!
__________________
04' Anniversary Edition GT
70mm On3
621hp/649tq
04Ryan is offline   Reply With Quote
Old 07-03-2009, 02:43 AM   #17
Speeds8erM-1
Trader Feedback: (58)
SAE? 278AH cams? Any clearance issues? Any accessories off for the dyno on either run?
__________________
98 GT, 5 Speed, SVO/Roush Blower @ 5-6 PSI, SVO Heads, PI Cams, FMS Shortys, Mac Pro Chamber, Magnaflows, Recaro Sport Seats, 3.55's, FMS Alum DS, Baer 13" Brakes, Tokico 5 Ways, ROH Snypers w/ Nitto DR's SOLD
Originally Posted by Mr.Blue View Post
Im just some jackass with a Mustang
Speeds8erM-1 is offline   Reply With Quote
Old 07-03-2009, 03:57 AM   #18
97BlackSteed
Thats outstanding....hopefully this will be appreciated by the 2V crowd and Trick Flow will sell hundreds and hundreds of sets.
__________________
1998 GT - Cobra 13" brakes...thats all for now...
97BlackSteed is offline   Reply With Quote
Old 07-03-2009, 04:34 AM   #19
orangetrak
Should not be any clearance issues even with huge cams as Trick Flow moved the intake valve to the opposite side of the chamber for that exact reason. No fly cuts in the pistons required.
__________________
1999 GT Conv.
Old 07-03-2009, 04:35 AM   #20
Speeds8erM-1
Really? Thats good #### then!
__________________
Old 07-03-2009, 07:41 AM   #21
2k2GT
2k2GT's Avatar
Guy here that works at AutoZone told me his 2003 GT special SHELBY Edition put down 400whp....no blower, no nitrous. All motor. Beat that.
Old 07-03-2009, 09:34 AM   #22
Modular Depot
SAE, Comp 278AH's and no clearance issues.
Car does not have A/C
__________________
Modular Depot
1.877.234.5551
modulardepot.com
Old 07-03-2009, 10:30 AM   #23
aggie97
good to see the increase in torque between 4k and 5500....but at that power level, 3350lbs is going to be pretty heavy for an AI car. I would go with a smaller cam and get the power down in the 320/330 range and tune for max torque curve. What was his final compression ratio?
I am sort of glad I didn't become the guinea pig on these....I would have made WAY too much power with my setup!!!
Not often someone is worried about making too much power!!!
If I refresh my big bore motor, I might lower the compression from 12.7:1 and shoot for 10:1 with these heads and be able to run pump gas again.
Keep us posted as I would like to see how these do in a road race environment.
AI#97
__________________
Here's the list for the Silver 2k GT
NASA TX region American Iron #97
VT Big Bore, Full MM catalog and enough skills to blow your doors off!
Turns more corners than going straight and stops like hitting a brick wall.......
Drag racing is for those that rode, or still ride the shortbus!
aggie97 is offline   Reply With Quote
Old 07-03-2009, 11:21 AM   #24
BULLITT1992
BULLITT1992's Avatar
Good stuff!
__________________
2001 Mustang Bullitt #01992
BULLITT1992 is online now   Reply With Quote
Old 07-03-2009, 04:44 PM   #25
SxyNerd
Formerly wolvee123
SxyNerd's Avatar
What kind of ported heads did you have in the Beginning? Home port or Professional port? Stock valves?
If it's just a home port and stock valves those gains are nothing special.
__________________
DFG 96 GT with Vortech, CMS 2.5 Blower cams, MMR800, Foxlake heads, Mac LT's plus a whole lot more. 590rw
SxyNerd is offline   Reply With Quote
Old 07-03-2009, 05:19 PM   #26
Modular Depot
AI#97
Don't worry, were' not done yet.
Need to think outside the box on this one. Car should come in at around 2900 lbs, maybe just a bit more.
__________________
Modular Depot
1.877.234.5551
modulardepot.com
Old 07-03-2009, 05:22 PM   #27
Modular Depot
Well, first off forget the gains, show me any PI headed car at 11:1 compression making anywhere near this power with a stock intake.
They were Fox Lake Stage II heads.
__________________
Modular Depot
1.877.234.5551
modulardepot.com
Old 07-03-2009, 05:28 PM   #28
kevman
kevman's Avatar
What if the first set had been box stock? Think of the improvement from a stock headed standpoint. Maybe 75hp?
Some people are never satisfied.
__________________
Old 07-03-2009, 05:55 PM   #29
2k2GT
2k2GT's Avatar
It's typical Internet Warrior Ideology. Anything you did, someone can ALWAYS do better, cheaper, and last longer. Gets real old, real quick.
Old 07-03-2009, 06:07 PM   #30
stoffer
stoffer's Avatar
I like the gains above 4500 rpms, right where my truck chokes off
__________________
-01 F-150 Lariat, procharged 5.4@15psi - Built Lightning motor swap coming soon - stay tuned
-worlds first snake bite equipped 03 harley truck - shows in stock class 'nuff said
-eddie bauer expy - "procharged land barge in progress"
stoffer is offline   Reply With Quote
Old 07-03-2009, 06:21 PM   #31
wytstang
wytstang's Avatar
WOW great power gains.
__________________
There comes a time when we as a society must value the needs of the many as opposed to the entitlement of the few
wytstang is offline   Reply With Quote
Old 07-03-2009, 06:49 PM   #32
SxyNerd
Formerly wolvee123
SxyNerd's Avatar
A dyno can be made to say or do almost anything a tuner wants it to. You guys at MD should know that better than anyone since you guys run a world class shop. Asking what heads were on there before was in no way an off base question. Asking for as much information as possible is the responsibility of EVERYONE looking to buy a product.
It has nothing to do with not being satisfied; I want clarification and so do most people willing to risk $2k+ for a set of early production new heads. At least with Fox Lake heads they are known for their results.
__________________
Old 07-03-2009, 06:51 PM   #33
aggie97
I have mine at 2970 with my 230lb butt in the seat.
If you are going to get the power down, go to a smaller cam because choking it at the TB or elsewhere is pointless.....especially if he drags it to miller at 4400ft this september! that and choked motors really don't seem to last long in this series so be careful if he goes that direction.
My biggest problem as of late has been dyno consistency. In the last year, I have changed NOTHING on my car it has varied from 304 rwhp, to 330rwhp on 4 different dynos...all 248's except for the mobile one at Mid Ohio last year. Torque from 317 to 340. Granted weather is a big factor and the motor is going on 4 years old but come on....dynos are supposed to be "corrected" right?! LOL!!! I am really tired of putting ballast in and out of the car all the time and having to re-corner weight the car.
__________________
Old 07-04-2009, 03:38 AM   #34
95convgt
95convgt's Avatar
Great #'s any vids of the car ??
__________________
No longer without one. 94 GT Blk 5 sp is now the new toy
95convgt is offline   Reply With Quote
Old 07-04-2009, 03:51 PM   #35
justinschmidt1
Impressive numbers....With the right intake an cams I bet we could be looking close to 400 rwhp n/a
justinschmidt1 is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© 2010 Corral.net
