#1 |
my 347 stang at track
some more vids of my stang at track lakeland fl 05-07-09
http://videos.streetfire.net/video/m...-18_681090.htm
__________________
347,high ports,vic jr,750,c4,373,180 shot 60' 1.39 BEST 1/8 6.43 BEST 1/4 10.46 1/8 mph 108.5 BEST 1/4 125.6 da was 2000 96* Last edited by BLU88GT; 05-08-2009 at 10:31 PM. |
#3 |
racing on a 275
Trader Feedback: (49)
looking good.... killer 60' what cam is in it?
__________________
Boss block 4V turbo build up www.youtube.com/watch?v=OuOY3B5RJ2U creperformance 08/09 NMCA street radial world champ |
#5 |
What size rims are on the back? Looks like they are too narrow and your not getting enough contact patch. First few passes look like you had alot of tire spin on launch.
Rex
__________________
1983 Mustang GT N/A 347 607hp@8000rpms 457ftlbs@6000 9.83@136 1.37 60ft |
#6 |
i am on an 8in rim. will be going to 10in rim befor i go to track again. also will be going coil over on front and back. will also be addind some kind of anti roll in back. the stock sway arm is rear is being overpowered i think.
__________________
347,high ports,vic jr,750,c4,373,180 shot 60' 1.39 BEST 1/8 6.43 BEST 1/4 10.46 1/8 mph 108.5 BEST 1/4 125.6 da was 2000 96* |
#7 |
Looks awsome!!
What's the converter set up if ya don't mind
__________________
94GT-3245lbs with driver - Streetfighter 347 -170ccTW heads -TFS-R -XE282HR-Redneck c4 w/brake -3800 stall -Tweecer - NX Shark nozzle - FMS 3:73 - 28x10.5 et drags 1.54 60ft 7.21@93.71 Na 1.42 60ft 6.60@102.52 N20 |
#8 |
3500 flash on motor. nitrous is around 4200. hard to say with the ol foot brake.
__________________
#12 | |
. need to get suspension worked out befor i go after more power. i keep wating for block to split.
__________________
#14 |
Trader Feedback: (32)
LOL keep it a little rich !! Nice runs !! I guess 347s can run hahaha. One day I will spray again, Maybe. Nice video's.
__________________
TOO_NUTS Racing N/A 331= 10.93@123.23 www.toonutsracing.com ,All Cars and Bikes welcome! |
#15 |
i am currently building a 12.5.1 347 mexican block solid roller. going to use same heads and intake just ported.
i just hope the crank makes it thru unharmed
__________________
#18 |
Geez I could smell the extra fuel from here. Car runs good though congrats
__________________
8.0 @ 88 on motor, old 306 7.0 @ 100 on new engine combo 6.4 @ 108 letting out twice on bottle. 11.2 @ 126 in 1/4 on motor |
#19 |
RICH IS NOT SAFE
__________________
1991 coupe stock bottom end, c4, nitrous, 1.43 6.33@109 9.99@129.3 revlimiter at 8.4 434 highport headed 8.5 car on two kits, 5.24@134.5 1.25 60ft. |
#21 |
looks fun, why is your car all over the track on the big end? Was the track going to crap? saying stock axles may sound cool, breaking them is not,put some 31 splines in there for saftey. lol btw stockers are way illegal at those times anyhow.keep up the good work.
__________________
1969 mustang FE gone, on hold but will return 1991 LX building stages,,going wild 408 dart IE, Procharger F2,mini tubed. Wolfe race craft cage and mini tub kit. 2006 Yamaha VMax with mods. 1994 F150 4x4 5.8 for when my other stuff is broke LOL |
#22 |
out of the box high ports.
the car will be leaned out after wide band is installed. car is all over track due to suspension. need an alingment bad after k member install. it is only cars 2nd trip to track and i did not expect it run this good right off the bat. just bought comp anti sway kit,50 50 shocks, rear coil overs. will get all this installed,cage in and alingment befor i go back to track.
__________________
#23 | |
__________________
Mockstang Racing Team 81 Mustang lx 347ci,Performer Rpm and Vic Jr Intake Stage1,750dp carb,Soild roller 640,1 3/4 header and 3 inch Flow Master muffler,C-4,8-inch converter,5.43 gears,31-14-15 slick,3050lbs w/d and interior.Et-6.666, MPH-102.48,60ft-1.454 *Footbrake & Shifting 6700*N/A |
#24 | |
most 10 and 9 second cars have only 1/2 the stuff needed to run those times btw i have moser axles going in car.
__________________
347,high ports,vic jr,750,c4,373,180 shot 60' 1.39 BEST 1/8 6.43 BEST 1/4 10.46 1/8 mph 108.5 BEST 1/4 125.6 da was 2000 96* Last edited by BLU88GT; 05-12-2009 at 07:31 PM. |
#25 |
Yep that good you are putting some racing axle in your car.Me, I rather do it right the first time then end up breaking alot of crap costing more the 2nd time around buying stuff.Good Luck with your car.
__________________
#27 |
You sure about the stall speed on that converter? It sure sounds more like 5000+ The thing hardly drops any rpm between shifts and launch.
If you are hoping that the crank doesn't get damaged when the block lets go, I would stop spraying so much! You need to jet it down to a 75 shot and it'll live. Trust me you don't want the block to split if you are worried about the crank or heads. It will take out the crank and it will damage some valves! Ask me how I know? <---- sprayed a stock block all forged 347 with a 150 shot, 5 passes and boom! Got lucky the first time and caught it before major damage, 2nd time took out the crank, 2 pistons/rods, and all 8 intake valves. Was running 6.60s at 3100 lbs on the footbrake. Car looks good otherwise.
__________________
Carl S.: 427ci, AFR 225s, Ported Vic Jr, Holley 850, CircleD 9" 4400 rpm converter, C4, 4.10s, 3000 lbs raceweight. 10.30s all motor/pump gas baby! Sponsors: Smokin Tires Racing, Southern Creationz.net http://i269.photobucket.com/albums/jj77/carlrenee1/sigpic1-1.jpg |
#29 |
well found out why it was pulling left. had a friend install cage sat and went to install comp anti roll bar for rear and right upper torque box is damaged. now we will have to rremove rear and fix box. i am lucky it just started to come apart and can be repaired.
__________________
#30 |
Having an overly rich combo is lots of times worse than a lean one. Besides the ets will slow down before damage normally occurs if it's getting leaner than it should be.
__________________
#31 |
i agree. next time i go to track i will focus on leaning it out some. i already went down 81 to a 70 on fuel jet of nitrous kit and still rich as hell. i am running 114 so i guess thats why its one reason its so rich. it will get there just need more time and money.
__________________
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
