Go Back   Corral.net : Ford Mustang Forums > General Tech Forums > General Mustang Tech
Thread Tools Display Modes
Old 03-09-2009, 12:40 PM   #1
fbod383
V10 Fox update
For those of you that dont know. I'm stuffing an 05 3V V10 into a 90 LX Notch.. here are some pics... already outdated.. since I had to modify the k member.. you'll notice the engine looks a little crooked, well on mount was in the hole, the other wasn't
Oh.. and the wiring is no longer a mess on the shop floor.. lol its ready to go.
__________________
90 LX Notch, 6.8L V10 Twin Turbo, T56 Magnum
fbod383 is offline   Reply With Quote
Old 03-09-2009, 12:42 PM   #2
Shadrack
Shadrack's Avatar
Dayum!!!! That is awesome! Any mods to the engine?
__________________
'08 F-250 Fx4 Powerstroke
'01 Procharged Z06 Corvette
'90 LX Coupe 347 Stroker
'78 Trans Am T/A 6.6
Shadrack is offline   Reply With Quote
Old 03-09-2009, 12:46 PM   #3
calebcope
calebcope's Avatar
Thumbs up Head Light
Did you have any problems put in those lights?
__________________
"All the bull@#*t stops when the greenlight drops"
_________________________
93 notchback AOD to Tremec swap, Pro 5.0 shifter, Steeda cable kit and padels, 3.73 gears, Crane Cams Fire Ball HI6-S
calebcope is offline   Reply With Quote
Old 03-09-2009, 01:22 PM   #4
fbod383
The engine will be boosted. I have flipped the manifolds and plan on putting two turbos in each corner, relocate the battery of course.
\H-beam rods and forged pistons. Its just a 5.4 with two extra cylinders
As for the headlights
Actually there is a gap in the corners, but its not too bad
__________________
Old 03-09-2009, 04:59 PM   #5
t-top mustang guy
t-top mustang guy's Avatar
thats insane, what are you gonna run for an intake..........
t-top mustang guy is offline   Reply With Quote
Old 03-09-2009, 06:10 PM   #6
eighty8gtfiveo
Trader Feedback: (147)
nice project man. keep us updated.
__________________
1988 coupe- new project
1991 emerald coupe- stroked, caged & sprayed
1987 lx vert- caged and a single turbo
eighty8gtfiveo is offline   Reply With Quote
Old 03-09-2009, 06:46 PM   #7
fbod383
I fabbed up one out of sheetmetal and some tubing.I'll get some pics up
__________________
Old 03-09-2009, 09:11 PM   #8
vinnietbird
vinnietbird's Avatar
Trader Feedback: (40)
That's awesome.What made you take on that task?
__________________
'88 Tbird..GT40-P,T-5,Explorer intake,TFS-1 cam and springs,Ported heads,FMS 1.6 roller rockers,MAC CAI,3G,Mass Air upgrade,65mm t-body,FMS 140 mph speedo,8.8 with 3.55's,BBK shorties,A/C & smog delete,mini starter,Pypes O/R X-Pipe and Flows,17x9-17x10 Cobra wheels,electric fan,CHE control arms
vinnietbird is offline   Reply With Quote
Old 03-09-2009, 09:42 PM   #9
Y2KStangGT
Can't wait to see more of this!
__________________
Mike
'00 Mustang GT Vert: Long gone.
'83 Mustang GLX: T-tops,EFI 5.0L/T-5/8.8 transplant,Ebrock heads/int,F303,15psi Turbo,TwEECer R/T,3.27s,Cobra brakes...
Y2KStangGT is offline   Reply With Quote
Old 03-09-2009, 09:58 PM   #10
NUTTSGT
Unregistered User
NUTTSGT's Avatar
What's the weight difference of the V10 compared to a 302/351 ?
__________________
Eric
TOO MUCH IS...JUST ENOUGH
Originally Posted by Dave88LX View Post
That was a horrible mistake and I am sorry I did not listen to all of you. I made a big mistake.
NUTTSGT is offline   Reply With Quote
Old 03-10-2009, 02:08 AM   #11
ackstang
Cool dare to be diff swap....but the V10...yuck. Was never a fan of those motors.
Good luck with it though, what are your hope for power?
__________________
My old car:
1985 GT with T-tops. Sportsman based 342, AFR 205's into a Vic Jr. and a C&S Billet Aerosol 800 carb fed by a Novi 2K, MSD Digital 7531. Street tune is 582rwhp at 6500rpm . Tube K-member and arms. Built 8.8 with 9 inch ends. Cage and chassis work by DMC Racing. Tuning by SD Concepts.
ackstang is offline   Reply With Quote
Old 03-10-2009, 08:18 AM   #12
Erich
Erich's Avatar
I rented an econoline based truck with a V10 in it and it was pretty sweet. Also some of those F350s with the 10 move out pretty fast-especially considering the weight.
Is there a forged crank in that badboy?
Erich
__________________
97 Laser Red GT-248A Wingless model, Built Lincoln Mark VIII motor-Procharger D1SC, 3 core IC, 60# inj
1989 Sonic Blue Notchback-DIY Twin Turbo, 42# inj, GT40P heads
Erich is offline   Reply With Quote
Old 03-10-2009, 09:14 AM   #13
fbod383
Vinnie: After 3 years of helping my buddy with is 4.6 DOHC swap into a 93 Notch, I figured I had to "one up" him. I know I'll be lucky to hit his numbers 840whp (and he has potential to go higher) Its just more bragging rights lol
Nutts, I dunno what the SBFs weigh, when this was shipped it weighed 695lbs. That was complete, all sensors, fuel rails, everything. Its a little porker. But, if I wanted to go fast I woulda gotten a Teksid 4.6.. not like it will be slow
Ackstang.. I've never been a fan of Mustangs! lol.. hence the Username haha
Erich: The V10s came with a forged steel Crank
__________________
Old 03-10-2009, 09:22 AM   #14
fbod383
here is where I had to cut the cam cover. Its just the PCV baffle, so there are no clearance issues. gotta weld it up now
Moved the motor mounts forward to clear the firewall a little better
engines permanent home
Wiring harness with all the non-essentials removed.. IE Auto trans stuff, PTO, ABS, etc
Did I mention its getting SN95 interior? SN95 pedals
moving the motor forward, the trans is still pretty much lined up
__________________
Old 03-10-2009, 09:24 AM   #15
Doc_G
Sir Loin of Beef
Wow that project was/is/will still be alot of work.
You've got the exact headlights I'm replacing mine with. Other than the gaps how problematic was the install? Also is/was getting them aimed properly a problem?
Doc_G is offline   Reply With Quote
Old 03-10-2009, 10:59 AM   #16
fbod383
They just go right in. no prolems at all. I have not aimed them yet.. since the car really isn't ready for them lol. But I do think they are great lookin lights
__________________
Old 03-10-2009, 02:05 PM   #17
Doc_G
Sir Loin of Beef
I do too, its why I picked em (cause my car is black too) I just wanted to make sure that they were of good quality as the last time I purchased a one piece head light it was a pan in the sitter. I was looking at the ones on AM, is that where you got yours?
Old 03-10-2009, 02:38 PM   #18
Melon
that should be sweet
i just want to see people faces when they ask if it's a 5.0
and you no man it's a v10 they would be like wtf
Melon is offline   Reply With Quote
Old 03-10-2009, 04:41 PM   #19
fbod383
I got them off of ebay, but its the same brand.
__________________
Old 03-10-2009, 07:27 PM   #20
Hack
I like the project, but I'm surprised you didn't take a minute to put tape over the intake ports. You obviously aren't lazy, taking on a project like that.
__________________
Ask me what I think of Met Life Insurance company.
'89 GT w/GT40 top end, Tremec 3550, 3.27 gears, MM panhard, cc plates and LCAs. FRPP lowering springs.
'70 convertible 302/C4
Hack is offline   Reply With Quote
Old 03-10-2009, 08:00 PM   #21
fbod383
Oh, the whole motor is getting torn down. And if I were doing anything over the motor such as grinding or cutting, i'd still cover them.
__________________
Old 03-11-2009, 12:16 PM   #22
Erich
Erich's Avatar
I really like that shot from the front with the intake ports. That motor is so long!
Is it going to be hard to find a place for the turbos?
Erich
__________________
Old 03-11-2009, 12:17 PM   #23
SilverFoxbody
SilverFoxbody's Avatar
I would like to read up on how to do this swap...got any links...like how to get it to run...what eec...ect.
__________________
------------------------- Dan Gilsdorf ---------------------------
SilverFoxTrans.com
WWW-ClickClickRACING-COM
SilverFoxbody is offline   Reply With Quote
Old 03-12-2009, 12:15 AM   #24
panteramatt
panteramatt's Avatar
That is one of the coolest swaps Ive seen. Cant believe a chebby lover is doing it!
panteramatt is offline   Reply With Quote
Old 03-12-2009, 01:30 PM   #25
sawbones25
sawbones25's Avatar
Trader Feedback: (15)
Subscribing.
Can't wait to see this thing finished.
sawbones25 is offline   Reply With Quote
Old 03-12-2009, 09:08 PM   #26
mustangjon
nice project, dont let anyone ever tell you something cant be done lol.
Just a question hasnt someone came up with a master cylinder relocation setup, i swore i seen it done on a fox before. Just seems easier than chopping the covers up.
Keep up the hard work
__________________
1988 lincoln lsc-accel 300+, Fully ported gt40's, ported exploder intake, 1.7 RR, fms ceramic shorties, o/r H pipe, magnadumps, 3:73, v2@8lbs, tko3550 (yes a 5 speed in a lincoln) numbers come soon!!! Still speed density to boot!
1971 mustang in resto limbo- 351 windsor-in bare metal
mustangjon is offline   Reply With Quote
Old 03-12-2009, 09:27 PM   #27
Alexandros
Alexandros's Avatar
I will definitly try that one on a highboy one day, looks like alot of fun.
Alexandros is offline   Reply With Quote
Old 03-12-2009, 10:12 PM   #28
gnvair
gnvair's Avatar
The V10 is actually a 4.6 with 2 more cylinders, not a 5.4.
It shares the same deck height and same rod length as a 4.6.
Super Ford had an article years ago where someone adapted the whole set up from an E350 into an SN95. I seem to remember the intake and throttle body were tricky.
gnvair is offline   Reply With Quote
Old 03-12-2009, 10:29 PM   #29
abrrymnvette
I actually thought about doing this same swap a couple weeks ago since I haven't bought a motor for my notch project yet. But the lack of aftermarket anything made me decide otherwise. But, I didn't know they came factory with forged cranks and that they are just 4.6 w/two more cylinders.
That's what I get for being a chevy guy.
abrrymnvette is offline   Reply With Quote
Old 03-12-2009, 11:37 PM   #30
92notch306
92notch306's Avatar
you talking about this car?
http://www.mustang50magazine.com/fea...ang/index.html
92notch306 is offline   Reply With Quote
Old 03-12-2009, 11:42 PM   #31
92notch306
92notch306's Avatar
and heres a vid of that car
http://videos.streetfire.net/video/A...ang_209567.htm
Old 03-12-2009, 11:47 PM   #32
uchi
this is fantastic, i saw a vid of some of the guys working for ford did a mule, 02 style mustang with a v10 and it was just great. cant wait to see this finished
uchi is offline   Reply With Quote
Old 03-13-2009, 10:50 AM   #33
gnvair
gnvair's Avatar
Originally Posted by 92notch306 View Post
No, it was definitely in Super Ford around 1998-99 and used a 94-96 V6 body as a starting point.
Old 03-13-2009, 12:06 PM   #34
Paulie
5.4 and 6.8 have the same stroke and same deck height. Do the math. Adding 2 cylinders to a 4.6 does not give you 6.8l.
Paulie is offline   Reply With Quote
Old 03-13-2009, 12:37 PM   #35
gnvair
gnvair's Avatar
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
