Go Back   Corral.net : Ford Mustang Forums > General Tech Forums > General Mustang Tech
Thread Tools Display Modes
Old 02-01-2009, 11:55 PM   #1
Marty White
pro 50 shifter with steeda handle?
wondering if this handle will put the shifter farther back so i don't have to lean forward for 1,3,5 ?
Marty White is offline   Reply With Quote
Old 02-02-2009, 12:00 AM   #2
Redsteeda8
scoot the seat up..........
Redsteeda8 is offline   Reply With Quote
Old 02-02-2009, 12:59 AM   #3
stangin'
Trader Feedback: (15)
that's the combo i've used on the last 2 set of pro 5.0 shifters. it does make it easier to shift compared to the pro 5.0 handle. you will like it.
__________________
1990 LX Convertible Triple Black
462rwhp 438rwtq
1993 Black Notchback
stock
stangin' is offline   Reply With Quote
Old 02-02-2009, 04:39 PM   #4
Marty White
did you use the comfort pro or standard steeda handle-how much further back is it over the pro 50 handle,do you have to lean forward for shifts,i'm 6'2 with long arms,my seat all the way back and i still have to lean forward for 1,3,5
Old 02-02-2009, 06:31 PM   #5
MFE
Super Moderator
MFE's Avatar
Absolutely.
I'm 6-3 and I modified the seat tracks to sit the seat back another inch. I have the Comfort Pro on the lower of its 2 settings. When I'm harnessed in tight I don't have to strain at all to hit 1, 3 or 5, they're right there every time.
http://videos.streetfire.net/video/9...-on_117325.htm
__________________
- '92 5-sp LX coupe, 3.55s, pulleys, Al DS, 1-5/8 EQ shorties, Magnaflow spun metallic cats, 2.5 Borla XS w/Dynomax tailpipes, Steeda Tri-Ax w/ Comfort Pro handle
- GT40 irons, Comp 270 HR cam, Cobra intake, FRPP 65mm TB, Pro-Flow 75mm MAF, 155 lph pump, FRPP oil cooler, Al rad, 130amp alt, Energy mounts
- Autopower 4-point bar, 5-pt harnesses, MM weld-in subs and STB
- MM K-member/A-arms/Coilovers, 425# springs, MM cc plates, Koni Yellow DA's
- MM adj rear LCA's/torque arm/panhard bar, MM 390-430# rear springs, EVM swaybar, Koni Yellow SA's
- Baer track/tour brakes, Midcontinent ducts, 98 Cobra 17x8 wheels, Carbotech XP8 pads
- Regional autocross Street Tire and Street Modified Champion 1999-2002
MFE is offline   Reply With Quote
Old 02-02-2009, 06:55 PM   #6
8950HO
I bought a steel handle from this place for my Tri-Ax.It`s bent like the Tri-Ax handle.
I didn`t care for the aluminum Tri-Ax handle after reading about some people breaking them.
www.konaracing.com
It`s a quality piece.
8950HO is offline   Reply With Quote
Old 02-02-2009, 06:56 PM   #7
Marty White
i noticed pro 50 makes a deluxe handle that looks similar to the tri ax handle-wonder how similar they are?
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
