Thread Tools | Display Modes |
#1 |
I've had a 4" cowl hood for my 86 for a couple years, and I haven't tackled installing it yet cause I wasn't sure where/how to install the hood pins.
I have a hood pin kit from Ford Racing with the over-center type pins with attached cables. If anyone has any info or pictures it would be greatly appreciated.
__________________
1991 Mustang LX - PDub K&N, 1.7 RR's, BBK equal lengths, off-road H, flowmaster 2 cat-back, Pro 5.0 shifter, smog removed 190rwhp 1984 Mercury Cougar rebuilt 3.8L V6 POS w/blown headgaskets, 3.27's, currently rusting into oblivion 1986 Mustang LX 351W .040 over, 10.55:1, Vic Jr. intake, Neil Erickson ported Windsor Sr's, Lunati solid flat tappet cam, 850 QFT carb, 9 inch, C4 w/4500 stall converter, 333rwhp | 11.75 @ 114mph My Stang page My Cougar page ***Check out Mustang Central*** |
| Sponsored Links | |
Advertisement |
#2 |
You should be able to mount the pins where the OE adjustable rubber stoppers are. Then, once they're mounted there, you can fashion up someway to transfer the drilling spot on the hood from the pin.
I dabbed some red paint on top of the pin, then slowly dropped the hood on it gently to transfer a paint mark where to drill. I too have the FRPP pins. After rusting out 2 sets of the MOROSO's or MR GASKET's, I "learned" and got ones that won't rust. I did not use the vinyl covered lanyards, just didn't care for them. Kinda/sorta a lil' dress up tip. I bought some large gauge heat shrink tubing and put over the pin up to the hole. Looks cleaner, and I dressed up the jam bolts/area with a black paint marker(not magic marker) ![]() ![]() ![]() ![]()
#3 |
Everything still sits ok without having the bumper pads in place? Did you put a nut above and below the sheetmetal then? I'll have to go out and look at mine to see if I can get at the bottom of it to put a nut on underneath.
__________________
#4 | ||
I am also STILL using the OE hood latch. I added the pins only for horror stories i've read of aftermarket hoods flying up while on-track. Multiply that with my luck and it was a no brainer to put the pins in. |
#5 |
Yeah I was planning on using the latch as well, cause I don't want people to be able to get into my engine bay. I don't really trust that alone though which is why I got the pin kit.
__________________
#6 |
Mine, I like it. It cost me $10 at Advance Auto Parts, and about 20 minutes of my time....
![]() ![]() ![]() Only way you can see it, is from the front if you look for it.
__________________
"Performance Driven, Race Proven" Kelly Aiken 727-967-3461 |
#7 |
A shot of flat black on the hood pin and retainer clip would make it disappear altogether.
__________________
Eric Anderson Alpharetta, GA At Corner-Carvers, we're not happy till you're not happy |
#8 | ||
Is that metal on the bottom? In the picture it looks like plastic.
__________________
2001 Mustang Bullitt #01992 Quote:
#9 |
It is a very hard composite. (plastic)
I didnt want to have them shwoing on the top of the hood, so I thought of this in about, 2 minutes. lol It is very easy.
__________________
#11 |
Its a matter of preference. Some like it closer to the edge of the hood, some half-way between cowl and endge, some elsewhere...
#12 |
Looks like you didn't put them where the stock bumper pads are at? I might have to look around your site again to see if there are any shots with the hood up.
__________________
#17 |
Kobe > *
I don't have them installed on anything as I'm not running an aftermarket hood yet. However, I've seen several guys at the AutoX with them and they like them a lot especially for the fact that you can lock the latches with a key if you like.
#19 | |
I need to know how you put it in the underside of the hood.. Do you have a write up? And You have 2 pins right?
__________________
1995 Black on Black Gt |
#20 |
I have just 1 pin in. I figure if the hood pops, I will see it, and the 1 pin will be enough to hold it until I stop.
You drill a hole that the pin will fit in....and you make another hole to access the top of the stud to put a washer/nut/lock washer or whatever you use to secure it.....while being able to fit a wrench around it to tighten it.
__________________
#22 |
Trader Feedback: (15)
FWIW, back in the day I had a lift-off 'glass hood using four pins - it was a one-off, home-made cowl induction hood for a Nova (circ '72). At speed, the hood would catch air and move around a little; I couldn't get the pins tight enough to fix this lift (should have used dzus fasteners). Anyway, my solution was four small springs that fit over the pin and pushed back when the hood was pinned down. The nice side benefit is that when I pulled the pins, the hood sort of popped up for easier removal.
#23 |
I have a 03/04 Cobra lift off hood on my ITE car. To set the hood height I went to the local auto parts store and bought some PCV hose. It fits right down onto the four hood pins. I then cut each peice of hose to where it held the hood up at just the right height. Push down on the hood and it doesnt move, pins keep it from lifting. < This will be very important once the radiator ducting is vented out through the heat extractors. Hope this tip helps someone.
__________________
1999 Cobra Coupe 2009 SCCA Salina Region ESP Champ '00 Mustang GT "Yeah, it's just a GT" #26 SCCA ITE NASA AIX |
#24 |
Ditto on the hose...
I used 1/2" rubber fuel line I had left laying around. Set the height, trim, re-measure... till you get the right height. Then insert hood pin while slight pressure on hood. |
#25 |
I ha dhood pins on my old Mach 1 hood.
I drilled new holes in the radiator core support for the studs. I then WELDED the nuts onto the core support and painted them. This way I could have the hood own, and adjust the height of pin-hole, then lift the hood and use a jam nut to keep that height. That AeroCatch looks slick as hell, though!
__________________
1989 GT- Prowler Orange Pearl Engine:331, AFR 185, FTI cam, 90mm LMAF/30 lb, TFS-R intake, BBK LT's, X-pipe, Spintech mufflers Suspension:MM: TA, PHB, Rear LCA's, C/C Plates, H&R Race Springs, Bilstein HD's, SFC's, Moser 28 splines, 3.73's, Cobra brakes,10th Anniv. Cobra wheels |
#26 |
i got a 98 gt with a 2 1/2 cowl hood it flew up the other day and ripped the hinges out i was wandering how i should put those hinges in or should i just leave the stock latch and get hood pins for the front and would the back be ok without the hinges on it or would it fly up anyway?
#27 |
The rear (cowl side) of the hood will flap in the wind.
You need "something" in the rear. You can either get other hinges off eBay... or install 4 pins, 1 in each corner of the hood (replace a hinge with a pin). Seen that done and posted somewhere... |
#28 |
i havent used hoodpins in over 8 years since i put on the hood..and its daily driven... i guess it depends what brand hood you put on....though my hood came with both primary as well as secondary hood latches... HO fibertrends FTW
__________________
www.modularfox.com Let the Fox 4.6 Conversion Begin! wifes ride http://www.hfpc.net/forums/index.php...&CODE=12&CID=5 my fake snake 89 svt cobra- http://www.hfpc.net/forums/index.php...&CODE=12&CID=4 |
#30 |
Do OE hoods have issues with the latches, or is it just the aftermarket hoods (F/G and carbon) that tend to flex more. I've got a '92 LX that I just picked up as my weekend toy/track junkie. I actually have a set of Sparco hood pins kicking around, from a Rabbit project that has since been sold, that I could install if it is warrented. I actually will be doing my first track day with this car in 2 weeks. Uprated brake pads (w/ ducting) and a new radiator will be going in this weekend. Added a new driver seat and Potenza RE-01Rs last weekend. Time to start driving!
__________________
'92 5.0LX Hatch - Bimini? Blue '89 VW GLi 16v - Helios Blue '73 Porsche 914 - Crazy shade of 70's green |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
