Thread Tools | Display Modes |
| Sponsored Links | |
Advertisement |
#2 | |
ok let me be more specific here is what i want at idle i want the same loudness of a mustang with flowmasters(i have an e303 cam so i want to hear it) cruise i want to hear the car but not make it way loud but loud enough you hear it comming Wide open throttle i want to head the turbo spool and scream |
#3 |
open downpipe will sound like flows at idle, but either way u want to use a open muffler not a chamber'd one, so at wot its gonna be loud as crap either way unless u wanna sacrifice horsepower
#4 |
I run a 3" downpipe into 3" y-pipe into 3" tubing back to axle and dumped. No mufflers.
__________________
1986 Mustang GT 306 E303, TEA 185 TW, Quicktime Turbo 67mm, Redneck C4 15lbs boost 525hp/626tq www.skilledit.com |
#6 |
Trader Feedback: (50)
yea i was gonna say stay away from chambered muffs, but someone beat me too it.
Dynomax and magnaflows are popular with turbo's
__________________
04 GT - Comp Orange - Daily Driver - New setup in the works, new numbers soon!! Old numbers/times: 412rw/468tq: 11.64@117.40 98 GT vert - Crystal White - Al P built Aviator 4V swap, CP pistons, Manley Billet rods, Cobra crank, P/P Heads, Sully Intake, Al P cams, Hellion T76 turbo, Pro-flow plate kit, PHP 4R70W w/4500 stall - back burner for now ![]() RIP: 05 GT - 440rw/382tq |
#7 |
Trader Feedback: (46)
My car with 3" DP 2.5" Y pipe into bullets. Wastegate problems so it clearly isnt a full pull. Sounded pretty good though, but its open DP now.
http://s67.photobucket.com/albums/h2...1012150034.flv
__________________
1989 LX- Some stuff. |
#8 |
Best soundclip I have from the track
http://videos.streetfire.net/video/1...308_188841.htm My site has other videos - www.skilledit.com
__________________
#9 |
Here is mine with straight pipes and no muff's.
http://videos.streetfire.net/video/T...sin_141490.htm
__________________
1997 Rio Red Cobra Vert Gone but not forgotten, 1989 TT notch... Best 1/4: 11.35 @ 125.84mph (1.77 60') 489rwhp/527rwtq |
#12 |
Mine was not that loud at all. It was loud enough that I thought cops would bother me, but they did not. I have a dumped 3" hooker max flow now. It is quiet, but would sound better with tails.
__________________
1994 Turbo GT |
#14 |
No way I could drive mine around with the open DP - I wouldn't make it 3 blocks before the police would tow it. Far too loud.
__________________
#16 |
Twin 3" just home made twin 3" in and out s/s straight through muffler with 4" gap in middle where both sides can mix.. This is from cold start at idle..
http://s4.photobucket.com/albums/y14...t=DSCF0237.flv
__________________
1991 XR8 Australian Falcon TFS induction 85 Lb injectors,2 x Bosch 044 fuel pumps. Custom cam ,E11v2 Haltech ecu...4x's 2 coil wasted spark ignition.Twin SC 61-2s with Dart block and 330/4340 Crank, Oliver rods,7.9/ comp c C.P pistons.. 482 rwkw/ 646 rwhp..A.P 4 pot brakes...TKO Tremec |
#17 |
Open downpipe
http://www.youtube.com/watch?v=_wzmsh4AROA 3.5 downpipe, two 3" borlaXS mufflers http://www.youtube.com/watch?v=zVikGVGJiAQ |
#18 |
Hooker AeroChambers or Dynomax Turbos?
I would like something that would give me the sleeper sound. Quite, quite quite yet still flow enough not to inhibit the turbo's efficiency too much.
I will be running the 3 inch Y-pipe and dual 3" exhaust to the muffs then 2.5" to the bumper. 2 mufflers in the stock location Last edited by Hota$$FOX; 02-05-2009 at 09:17 PM. |
#19 | |
The areo chambers are not straight through. I don't think the turbos are either. If you are running exhaust to the bumper, then get something like hooker maxflow, magnaflows or borla xs, all should be sleeper enough. My max flow is pretty quite, and its dumped.
__________________
1994 Turbo GT Last edited by mustangless; 02-05-2009 at 11:19 AM. |
#21 | |
I'm leaning toward the Borlas after that video. Just wonderin what they sound like under WOT. Only down side is the damn price. But i guess if they are the best and never wearout then it will be worth it when you consider the price to replace other muffs if they wear out not to mention the time or paying a muffler shop. The Dyno Max Turbos aren't straight through but they have internal directional tubes that decrease the turbulence when the exh gas has to do a u turn. You get 3 times the baffle surface of a straight through. But they are aluminized and not SS. I think I'll just saveup untill I can afford $130 muffs Ouch! :-( |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
