#1 |
New best In mach1
Finally made it right off the trailor it went in the 10.s
All in all it was a good day, It could have went better the car was coming out strong but was still bogging. Went like this 1.544 60ft 4.521 330 ft 6.966 1/8th 104.35 1/8th mph 9.089 1000ft 10.8 1/4th 126.91 1/4th mph 3 passes into the 10s best 1/8th mph at 105.8 best mph of 126.99 car needs more gear i cant see why it woudnt go 10.5s in the right conditions the car needs to come out higher on the 2 step and needs to be dailed in and possibly a aint roll bar all in all a great day! http://s137.photobucket.com/albums/q...pingatgate.flv http://videos.streetfire.net/video/L...908_185464.htm i race at 7:15 im in the far lane let me know some imput the suspension deff needs to be dailed in
__________________
10.8@127 Last edited by braceyaself; 09-22-2008 at 09:30 PM. |
#2 |
Nice ET, but give us a rundown on the car, engine to current suspension. For the MPH you're pulling right now, looks like you need some suspension to be running mid 10s and 6.60s-6.70s.
__________________
Carl S.: 427ci, AFR 225s, Ported Vic Jr, Holley 850, CircleD 9" 4400 rpm converter, C4, 4.10s, 3000 lbs raceweight. 10.30s all motor/pump gas baby! Sponsors: Smokin Tires Racing, Southern Creationz.net http://i269.photobucket.com/albums/jj77/carlrenee1/sigpic1-1.jpg |
#4 | |
its a stock motor trans clutch mach 1 with a vortech superchager s trim pushing 8 psi. Intercooled the car was coming out at 5000 and was bogging on most passes so i air the slicks up a tad and it started to black track. Reason i aired them up is i forgot my tuner at home and coud not up the 2 step rpm. Suspsension set up is the following baseline uppers wofle lowers d&d k member with 150 pound front springs with stange 10 way adjustables up front and 16 way qa1s out back. everything was set to loose i never adjusted anything because i didnt have a vid of me racing so i didnt know what the car was doing. The car should go 10.5s with the suspension dailed in and the proper launch. Car also has a 6 point cage
__________________
10.8@127 |
#6 |
Trader Feedback: (66)
Nice runs..........is it just me or is the video jumpy
__________________
OOTB TW heads , AFM B4 cam , Systemax , 4.30's 2900w/ driver Best 1/4..... 11.51 @116 mph...1.52 60ft...1933 D/A PeteAndersonRacing.com |
#7 |
Trader Feedback: (32)
So you saying the only mod you made to the engine is just a S trim? Something aint adding up. 8 psi nets you maybe 100 hp. You make 300ish from factory. Cant see a stock engine going that quick qith out more help. Sure the car aint strip down? Congrats though on the time..!
__________________
TOO_NUTS Racing N/A 331= 10.93@123.23 www.toonutsracing.com ,All Cars and Bikes welcome! |
#8 |
Nutzz, base centri kits on a 4v will get you around 415-440rwhp. I'm sure he has exhaust and such as well. Boosted 4v mod motors can make some impressive numbers. I can't wait to put my novi on my car next year.
-Mark
__________________
98 red cobra (N/A Stock longblock) 11.79@114.64 (1.62 60ft )
#10 |
car made 465 threw a fulll exhuast. Yes its fast for its numbers has drag wheels and a full cage 1 race seat. Should be around 3100 pounds
__________________
10.8@127 Last edited by braceyaself; 09-23-2008 at 07:35 PM. |
#16 | |
What is your tire and gear setup. I'm torn between 4.10's and a 26" tire or 4.56's and a 28" tire. I think the 4.56/28 combo would have a little higher rpms at the traps. -Mark
__________________
#17 |
Im using a 28x9 with 410s. If i was going to do i again. I would got atleast 430s with a 28x9 tire. It rolls out to be a 27.3 and lets you keep most of your gear. If you do a 456 that will prolly put you close to redline then i would go with a 28x10.5 tire . youl be near 7k threw the traps with the 456s. Witch is great for drag racing but terrible for motor. so if its just a drag car dont fear the gear lol.
__________________
10.8@127 |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
vids fixed now
Linear Mode
